Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 09-27-2003, 05:23 PM   #1
DRNWAGN
Member#: 44255
10 Scion TC
Default STi Turbo size vs WRX-XT
I have heard that the WRX and XT have the same turbo. Is the turbo on the STI larger? If an upgrade is done, one would have to have some sort of ecu tuning done correct? Sorry, not new to the import tuning game but just to the turbo side of it!
Thanks
DRNWAGN is offline   Reply With Quote
Old 09-27-2003, 09:52 PM   #2
DRNWAGN
Member#: 44255
10 Scion TC
Where are the technical geeks on here? I would think that you guys could answer these basic questions but I can not seem to find them through the search. I know you guys know this stuff.
Old 09-27-2003, 10:11 PM   #3
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Yes TD04
Yes VF39
Depends how far you want to go. 250hp or 370hp using VF39.
Wombat North is offline   Reply With Quote
Old 09-27-2003, 10:19 PM   #4
DRNWAGN
Member#: 44255
10 Scion TC
eventually as far as I can since it would be such a sleeper. The trick will be finding someone that will do the ecu tuning since I have not found anything as of yet. But I am excited to say the least.
Old 09-28-2003, 05:14 PM   #5
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
hell... get a sti tubo, intercooler and ecu parts. Try to swap them and tell us how it works. The block is the same as the sti so you shouldnt have to many problems.
Old 09-29-2003, 12:12 AM   #6
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
try turboXS...they're in MD
http://turboxs.com/
they may be able to steer you in the right direction.
They don't have anything for the Forester XT right now, but maybe they can use your wagon as a "guinia pig" if the market is there for upgrades.
just a thought
z is offline   Reply With Quote
Old 09-29-2003, 07:57 AM   #7
DRNWAGN
Member#: 44255
10 Scion TC
I plan on getting by there in the near future. They are only about 10 miles from my house. I know exactly where they are. If they are willing to work with me I would be more than happy to have them use my car as a prototype. I need to check with them about BOV's anyway. Is anyone running a BOV on their XT's out there? Let me know what you guys have and how they are working out.
Old 09-29-2003, 11:56 AM   #8
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
No it isn't. There was a thread that showed all the part numbers to be different. It's a EJ25, but not a EJ257.
TypeC is offline   Reply With Quote
Old 09-29-2003, 12:21 PM   #9
metoo
Member#: 4764
2004 STi sold :(
forizzle
Ever since they moved to Utah and stopped dealing APS stuff, you rarel hear their name any more, but Cobbtuning already has some stuff for the XT. I'm sure they will have Access for it soon too.
metoo is offline   Reply With Quote
Old 09-29-2003, 12:30 PM   #10
DRNWAGN
Member#: 44255
10 Scion TC
I will be going by Turbo XS this afternoon to have a bov installed since the wife is not familiar with the sounds just yet. In any case, I spoke with them on the phone and was told to bring the car by because they will need to make sure they have everything to fit the bov to the car. They also mentioned that they would be doing a Forester XT as a project car next and it would save them money if they did not have to buy one. So, I gave him my name and number and have to go by their this afternoon. He wants to check out a few things and see what works and does not. He will then check with his boss to see if he has set anything but is 98% sure that he has not. He has the authority to make the decision but does not want to stop on anyone's toes. If they use my car I will have to leave it with them a couple of days at a time but will get a tremendous discount on all the parts and not pay the labor for install or tuning of it. Keep your fingers crossed. Project sleeper might just get off the ground before we thought.
Old 09-29-2003, 12:57 PM   #11
totoherbs
Member#: 7321
.... 122 IggPoints
Realy.... I cant find it all I could find is...
Originally posted by gvmelbrty
According to this "Forester XT technical description supplement" PDF posted on the Subaru Australia web site, the XT heads do have the sodium exhaust valves:
XT Cylinder Head Features
  • Four valves per cylinder in cross flow format with straight tumble airflow being achieved by manifold and intake port design.
  • Tumble Generator Valves (TGV) for good combustion efficiency and low emissions during cold start. After starting, the TGV immediately opens to maintain good airflow and performance.
  • Twin camshaft per cylinder head, with direct valve actuation and Active Valve Control System (AVCS) variable valve timing.
  • Camshaft weight has been reduced 1700g by using a hollow shaft and an assembly of sintered cam lobes.
  • Sodium filled exhaust valve stems for low inertia and improved heat dissipation.
  • Single timing belt with self-adjusting tensioner. (100,000 km replacement interval)
Lots of other interesting XT info in that doc as well.
-tom
http://forums.nasioc.com/forums/show...forester+block
They may have different part numbers, hell even the motor is called something else ej255 vs ej257, but its the same dam thing... the cams may be different tho. The sti cams are the same as deration as the wrx but they have higher lift and avcs gear, so the forester may have the same cams.
Old 09-29-2003, 01:04 PM   #12
gforced
Member#: 38898
The STi block is a semi-closed deck design which makes it stronger. The XT's block is an open deck design I believe.
gforced is offline   Reply With Quote
Old 09-29-2003, 01:09 PM   #13
totoherbs
Member#: 7321
.... 122 IggPoints
read the subaru pdf link page 8
Old 10-01-2003, 08:02 PM   #14
SuperRuWRX
Member#: 4955
2004 FXT
OffRoadSubarus.com
Default ??????????
"The STi block is a semi-closed deck design which makes it stronger. The XT's block is an open deck design I believe."
Are you sure ??????
I think not. Richard
SuperRuWRX is offline   Reply With Quote
Old 10-01-2003, 09:52 PM   #15
blinguskahn
Member#: 39301
STi 05 8cm FPRed
WRX 06 Blue FP20G
Wrong. EJ255 (as stated in my manual).
blinguskahn is offline   Reply With Quote
Old 10-02-2003, 11:21 AM   #16
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Duh, of course it's an EJ255, the point was it wasn't an EJ257. They are ALL EJ25's.
Noob.
Old 10-02-2003, 11:26 AM   #17
blinguskahn
Member#: 39301
STi 05 8cm FPRed
WRX 06 Blue FP20G
Noob? What does that mean? I have never seen that word before on these boards. That an original?
Douchebag.
Old 10-02-2003, 01:33 PM   #18
totoherbs
Member#: 7321
.... 122 IggPoints
Noob.
But... you were wrong so there is no point in a pissing contest...
STi turbo upgrade vs. wrx 06+ turbo upgrade hockeygm General Community 5 03-27-2007 08:55 PM
Turbo RS vs WRX wrx_n_effects Normally Aspirated with bolt-on Forced Induction Powertrain 47 04-19-2002 07:10 PM
Turbo RS vs. WRX imprezive General Forum Archive 26 03-22-2001 06:33 PM
