Old 01-31-2001, 05:53 AM   #1
OBSS
Member#: 1421
1997 OBSuperSport
Arcadia Green
Post Both low beams are gone!
Scenario last night:
1. Started car and turned on headlights
2. Within 2 seconds BOTH headlamps went off.
3. Highbeams work in both headlamps
4. Both Corner lights working
5. Both Fog lights working
6. Checked all fuses under dash
7. Checked all fuses and relays under hood
Is it safe to assume that both headlight bulbs lost the low beams at the same time?
Thanks in advance,
Adam
MY97OBSS
[email protected]
OBSS is offline
Old 01-31-2001, 06:11 AM   #2
trojan9x
Member#: 3169
2001 2.5 RS: Holbert
Memorial Winner 2003
Post
i've only heard of that happening when something either in the wire, or wiring harness that plugs into the bulb gets either fried or melts. check the connection between the harness and buld and make sure it is clean from any and all dirt. and check to see if any of the wires like melted. that happened on my old car and i had to get a whole new wiring harness for the light.
Also, are you using stock bulbs? or a higher wattage bulb?
trojan9x is offline
Old 01-31-2001, 06:31 AM   #3
ttoversteer
Member#: 465
2012 GTI
Gray
Post
The same thing happened when I had some Hella H4s. I heard it had something to do with the voltage drop, and a new wire harness was the way to fix it. Of course, I have no electrical skills, so I don't know how to correct the problem.
-Tom
ttoversteer is offline
Old 01-31-2001, 07:08 AM   #4
OBSS
Member#: 1421
1997 OBSuperSport
Arcadia Green
Post
Thanks for the replies, trojan9x and TT.
I've been running a set of Naxos lights, not higher wattage, and also for more than 20k miles with no problems(until now!)
I'll check the harness next.
Adam
MY97OBSS
OBSS is offline
Old 01-31-2001, 08:03 AM   #5
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
definately sounds like a short or wiring issue to me... i lost both my fogs on the GT due to the way i had them wired up...
you are on the right track... check your wiring harnesses...
j.
Subie Gal is offline
Old 01-31-2001, 08:09 AM   #6
Yeoman
Member#: 175
2000 Impreza 2.5RS
2012 Legacy 3.6R
Lightbulb
Same thing happened to me with a pair of Xenon bulbs at about 20000kms. As soon as I started the car, FLASH and then off.
Now let me relay some info,
On our cars as we all know we don't have to shut the lights when we turn off the car, so we leave them on (not anymore!), then we start the car a surge goes to the headlights and theres your probable cause. Makes sense to me so now I turn off my lights almost always when I turn off the car.
Yeoman is offline
Old 02-01-2001, 05:16 AM   #7
OBSS
Member#: 1421
1997 OBSuperSport
Arcadia Green
Post
Coincidence wins!
Both low-beams blew out at the same time! Now running PIAA Super White 60/55(part #15660).
And I will turn my lights of manually before shutting the car off as not to surge the lights when starting.
Adam
MY97OBSS
OBSS is offline
Old 02-01-2001, 06:45 AM   #8
ttoversteer
Member#: 465
2012 GTI
Gray
Thumbs up
Woo hoo! Well, if that's the probable cause, I'll put my new H4s back in the car. If they burn out, I'll let you guys/gals know.
Now if I can only remember to turn off my lights before starting the car...
-Tom
HTML code is On
Both low-beams went out at the same time..help! andron Electrical & Lighting 14 03-03-2011 10:10 PM
low beams are not working but high are? tdiz Electrical & Lighting 5 10-16-2007 10:50 PM
both low beams went out at the same time, huh? pumpkyn Electrical & Lighting 5 08-28-2007 08:12 PM
Help ! High beams and fog lights don' t work ! Low beams are ok. zeroFX Electrical & Lighting 3 12-29-2004 04:45 PM
Both low beams out! Mr. Mercado Electrical & Lighting 5 02-17-2004 10:34 PM
