Old 09-28-2003, 04:05 PM   #1
Ikonosin
Member#: 5914
2010 Legacy 3.6R
Default quick LHD STi projector harness question
Quick question...I'm looking at buying a set of LHD STi projector headlights, and then adding HID after the fact. The headlights do not have a wiring harness, will I need one? Since I'm buying HIDs, can't I just buy a HID setup that plugs into my factory harness and also into the headlights?
If I do need a harness, does anyone know a vender that actually has these in stock right now?
Thanks,
Scott
Ikonosin is offline   Reply With Quote
Old 09-28-2003, 09:00 PM   #2
BlueWRXagon
Member#: 18048
2002 Impreza Wagon
Short answer, no, unless you want to so some wire splicing and headlight hacking.
I'm no expert but I did have the JDM projectors and I needed a harness. Main reason for not doing what you suggest is that the housing requires a H1 type bulb for the main beam and your stock harness is a 9007. If you were thinking about putting that 9007 bulb into the EDM housing, you would have to do some serious chopping...that and when you get the bulb into the housing, the focal point would be off.
Besides all that, if you don't get the harness, you'll have to splice some wires and all that good junk. Unless you're good at it...
Spend the extra 40 bucks and do it right...not worth trying to skimp on that! Thats my thought at least!
BlueWRXagon is offline   Reply With Quote
Old 09-28-2003, 09:21 PM   #3
Ikonosin
Member#: 5914
2010 Legacy 3.6R
Wasn't a matter of the cash, I just wasn't sure if I would even use a harness. It would seem that the HID kit would plug into my factory harness and then into the housing, so what roll would the extra harness serve?
Doesn't really matter I guess, as I think I'm actually going to buy Morettes and then a HID setup from a BMW for my lowbeams If I do it this way, I can always buy new D2S bulbs, so the new ban on HIDs won't bother me as much
Old 09-29-2003, 10:07 AM   #4
White Knight
Member#: 2864
'08 Aspen White STi
'11 Legacy GT
Post
Well you don't need one BUT, if you use one then the look will be cleaner and going back to stock well be just plug & play.
Now for the HID kit you will need and H1 kit that will plug into your JDM lights. You will just have to cut out the cap that goes on the back so that the HID wires can go though. I wish I had a pic to show you better but its only in my head.
If you have not gotten the HID's yet call up http://www.fizzautosports.com/ and tell them what you are looking for and they will help you out nicely.
Hope this helps a little more.
-Mark
SQC#012
White Knight is offline   Reply With Quote
Old 09-30-2003, 10:58 PM   #5
wagons_ho!
Member#: 16574
Default Harnesses
I have harnesses available. No soldering or splilcing required.
45USD shipped. Ones with OEM H1 connectors, 55USD shipped.
Email me for info.
wagons_ho! is offline   Reply With Quote
LHD sti projectors. AndyWRXWG Private 'Wanted' Classifieds 5 11-03-2003 10:37 PM
Gauging interest: EDM LHD STi Projector Headlights ScrambleBoost Bay Area Impreza Club Forum -- BAIC 8 09-14-2003 11:53 PM
FS: UTEC, Remote Switch, LHD STi Projectors and 18" Anthracite P1's w/ S-03s JLMarx Private 'For Sale' Classifieds 28 08-19-2003 09:36 PM
FS: UTEC, LHD STi Projectors, 18" P1's JLMarx Mid Atlantic Impreza Club -- MAIC 26 08-15-2003 08:25 AM
LHD STi projector Plug and play harness subarude Electrical & Lighting 4 03-10-2003 11:09 PM
