Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 09-28-2003, 08:00 PM   #1
Ikonosin
Member#: 5914
2010 Legacy 3.6R
Default replace projector on Morette?
In light of the recent ban on HID kits, I was thinking about taking a set of morettes and replace the projector with a unit that accepts D2S bulbs. This way I wouldn't have to worry about getting replacement parts (bulbs). I was thinking about this kit HERE from Hella. Part #68139 is the D2S setup. There are also a ton of kits on eBay from various BMWs, Audis, and Mercedes that can be had fairly cheap.
Does anyone know the measurements of the Morette projector offhand? I just want to make sure this will be a direct replacement.
Scott
Ikonosin is offline   Reply With Quote
Old 09-29-2003, 07:42 AM   #2
daverup
Member#: 3708
2015 WRX Ltd Sedan
ISM
Post
The D2S or D2R will fit in the morrettes with a little modding, as long as they are H7 replacements.
The problem with the morrettes and HID isn't the projector lens, it's the shield which gives the e-code _/ pattern and creates a "rainbow" effect. If you do a little searching on hidforum.com you can figure out how to construct a new shield which will eliminate the "rainbow" effect and make the beam more like the oem HID's on Audi's etc.
The worst job remains either way you go, you will still have to open the valeo plastic case to get to the projector assembly. It is glued and has plastic clips which break very easily. Heating them helps, but they are still trouble.
To disassemble the projector itself you will need "tamper proof torx" tools.
daverup is offline   Reply With Quote
WTB: Replacement Valeo Projectors for Morette Headlights PSI_XTC Private 'Wanted' Classifieds 1 09-23-2007 09:37 PM
JDM BD/BG projectors versus Morettes Kraziken Legacy Forum 20 12-08-2005 09:17 PM
my left morette died today! where can i get a replacement bulb on the cheap? db97 Electrical & Lighting 3 12-29-2004 10:17 PM
Replacement projector for UK300 / triplus light? dobavz Electrical & Lighting 2 04-22-2003 01:15 AM
Replacing one shattered lens on morettes- how much? SinhCredible Interior & Exterior Modification 3 04-07-2003 12:00 PM
