Old 09-28-2003, 09:38 PM   #1
ScoobyTime
Member#: 21857
1987 Barbie Corvette
Yeah Baby
Default gc8 6 spd.
was there a 6 speed made for the gc8 style imprezas? i would like one in my car and i'm wondering if a jdm 6 would be easier (and probably cheaper ) than the new sti box. thanx
ScoobyTime is offline   Reply With Quote
Old 09-29-2003, 03:08 AM   #2
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
No factory GC8 6spds. All 6spds for the suby are dimentionally the same USDM/JDM/EDM they fit with a little "tunnel work" and other parts.
mr2guru is offline   Reply With Quote
Old 09-30-2003, 01:44 PM   #3
ScoobyTime
Member#: 21857
Yeah Baby
so what would be one or two of the best options for a 6 spd? where would i find them and about how much would they cost? thanks
Old 10-07-2003, 08:56 AM   #4
geronimo66
Member#: 26929
2000 Impreza
with Gremilins
i-speed has done these swaps, NO tunnel work, I think that you should be able to get the whole set up for 6k, frt&rr LSD, trans everything.
I am thinking that for all the options that this is the best. The 5spd is just a poor trans for much'o power.
geronimo66 is offline   Reply With Quote
Old 10-09-2003, 06:12 PM   #6
Z1 Performance
Member#: 9327
Yep - not sure where the tunnel work runour started, but there is none needed
Adam
Z1 Performance is offline   Reply With Quote
Old 10-29-2003, 01:52 PM   #7
soob102
Member#: 43353
1999 2.5 impreza
Default tranny
yes i also wanted to do a wrw swap to my gc8 but am not sure where i could find an engine or what tranny to use so i will not have troubles in the long run so if ne one help me out that would be great and also im converting it from an auto to an manual if that will be a factor thx
soob102 is offline   Reply With Quote
Old 10-29-2003, 05:45 PM   #8
lukkur
Member#: 31348
2001 Impreza RS 4dr
Have the same prob. and question as soob102.
lukkur is offline   Reply With Quote
Old 10-29-2003, 06:22 PM   #9
dcoty
Member#: 3149
01 V7 GC/R32 sky
A cheaper alternative that will give you good results are the gears from an STi RA. But ti is a 5sp.
You can get just the gears for around 1200$ and it fits in the stock casing. But i believe you need a new main shaft and pinion shaft becuse I was told you would otherwise get whining in 1st and 2nd gear. I think this is the way I am going.
Dan
dcoty is offline   Reply With Quote
FS (NC/RTP Area): 60k 05STI 6 spd and 24k 05STI 6 spd CyborgX_CZ Drivetrain 12 07-05-2009 02:22 PM
6-spd into GC8 Homemade WRX Subaru Conversions 25 08-01-2007 03:19 AM
04 sti swapped gc8 with Tranny 6 spd problems NotoriousD Subaru Conversions 3 05-02-2006 10:39 AM
WTT: USDM 6-spd from STi for JDM 6-spd non-dccd o2sys Tri-State Area Private Classifieds 8 02-03-2006 11:25 AM
Where do have to hammer to get the 6-spd into a GC8 underground-mpyre Subaru Conversions 3 07-11-2003 03:40 AM
