Notices
Old 09-28-2003, 11:19 PM   #1
scoobydrew06
Member#: 32951
Default Grounding Kit??
I just saw this on the mods site. My car has 126k on it so if it does everything it says it does i guess this would help a lot. Has anyone used this and know exactly what you are supposed to get out of it? The box on the pic said HP gains and a bunch of other ****.
drew
scoobydrew06 is offline   Reply With Quote
Old 09-29-2003, 07:45 PM   #2
DanThom
Member#: 23396
2003 WRX Sedan
Default Re: Grounding Kit??
It wouldn't be unreasonable to expect brighter lights, quicker starting and smoother idle. Don't be terribly surprised if the engine feels smoother at speed and if your fuel economy improves, but don't expect it either. And finally, don't expect any noticeable power increase, but be happy if you do notice one.
How's that for being noncommital?
But seriously, a friend has a 1.8 Impreza and we regrounded the car in an attempt to clear up a charging problem. The factory grounds were so corroded that his charging system couldn't muster any more than 12.9 volts at full boil. Cleaning all of the connections (which may have fixed the problem by itself) and supplementing the pathetic factory grounds brought it up to 13.8.
-Dan
DanThom is offline   Reply With Quote
Old 09-29-2003, 07:55 PM   #3
scoobydrew06
Member#: 32951
thanks for the help, i'm going to do this. but i'm not paying for a kit, i'll just pick up some good quality wire somewhere
Old 09-30-2003, 05:16 PM   #4
scoobydrew06
Member#: 32951
I just purchased 4 gauge High voltage, high current wire at some amazing audio store. It was 24 bucks for 12 Ft., I also picked up gold plated terminals too, i didn't want the gold ones, but it was all they had, those ended up costing me 15 bucks. So now all i have to do is borrow a solder iron from the engineering department here at school and put my grounding kit together. Oh i guess i'll have to purchase a ratchet set too since all my tools are at home.
Old 09-30-2003, 08:44 PM   #5
LinuxGuy
Member#: 17270
1998 Fender Bender
Holds 1000lbs.
Ah, very cool, the grounding kit was a good mod.
I didn't see the sense in spending $100 for pre-cut wires, so I bought 10' of 8GA insulated copper wire at home depot, then soldered on some loop connectors I had hanging around the house, a snip here, some solder there, 45 minutes later I had a grounding kit on my car.
LinuxGuy is offline   Reply With Quote
grounding kit freeze Electrical & Lighting 18 06-10-2011 05:36 AM
SoCal : Sun HotInaZma Ground Kit & Split Fire Japan Hyper Voltage Kit!!!!! outcast Engine/Power/Exhaust 10 12-20-2006 08:14 PM
F/S: SunAuto voltage kit and HKS circle earth grounding kit swift2fly SCIC Private Classifieds 0 10-25-2006 09:55 PM
grounding kits stock ground points spdracr00 Legacy Forum 4 10-30-2005 10:05 PM
intake/ground kit Orville Cote Legacy Forum 1 03-21-2003 11:05 PM
