Old 09-29-2003, 12:52 AM   #1
LinusRebar
Member#: 44066
1995 Legacy L Sedan
Question Antenna Problems
Alright, I'm not a very educated person when it comes to car mechanics, so I'm hoping that someone can help me.
I have a 1995 Subaru Legacy L Sedan and just yesterday the antenna stopped working. I didn't hit it or do anything weird to it, it just refuses to go down. I can hear the motor running, but it stays up. I can push it down a little, (a little more than an inch) but when the motor runs for the antenna to come back up, it stays down.
Can anyone tell me how to fix this? Thanks.
LinusRebar is offline   Reply With Quote
Old 09-29-2003, 01:38 AM   #2
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
Have you ever put any lubrication on it? It might be binding due to none.
If not, try some graphite lubrication, like the garage door stuff. It's a 'dry' lube, and doesn't get dirt on it(much).
Speedwagon is offline   Reply With Quote
Old 09-29-2003, 10:36 AM   #3
smagoun
Member#: 30754
Wait a couple of weeks, and the motor will burn out. Then you won't have to worry about it. That's what happened to mine. Forunately the radio still (mostly) works with the antenna half-up.
If that doesn't sound appealing, yeah try the lube.
smagoun is offline   Reply With Quote
Old 09-30-2003, 02:11 PM   #4
Oquipah
Member#: 9689
1998 Legacy GT
Same problem, but I don't want to live with the antenna always in the 'up' position. Lube did not work.
How difficult would it be to remove the stock antenna and put in an antenna like the ones on Ford Focus' and VW bugs?
I may have my sunroof replaced next spring which would involve the removal of the entire headliner so could be accessible at that time.
Wiring issues?
Peace,
Oquipah
Oquipah is offline   Reply With Quote
Old 09-30-2003, 02:45 PM   #5
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Wiring would be a snap with the headliner out.
On the other hand...if the motor is still running, but not moving the mast, most likely the toothed belt inside the mast has broken near the bottom. It's fairly easy to remove the entire assembly, pulling out the old mast and broken off belt piece inside, and replace the mast with new part. Once the motor assembly is reinstalled, without mast, turn radio on, letting motor move to "up" position, insert the end of the new belt/mast assembly down into the hole, and have someone else turn radio off. As the motor rewinds it should engage on the new toothed belt and pull the mast down into position. Then tighten locking ring onto mast assembly and you're done.
Glenn O
nuburu2 is offline   Reply With Quote
Old 09-30-2003, 09:57 PM   #6
LinusRebar
Member#: 44066
1995 Legacy L Sedan
Thanks a lot guys.
Antennae Problems hangman Car Audio, Video & Security 1 04-10-2008 03:56 PM
Antenna Problems, please help 4bangers4life Car Audio, Video & Security 15 07-18-2007 12:57 PM
04 OEM Headunit Antenna Problem njc200 Car Audio, Video & Security 9 07-11-2005 02:36 PM
Power Antenna Problem - 97 GT - I already did a search... BoardRider Legacy Forum 15 04-14-2005 12:50 PM
02 GT antenna problem truman Car Audio, Video & Security 0 06-05-2002 03:25 PM
