Old 02-15-2001, 01:38 PM   #1
subee_love
Member#: 4093
01 Impreza
BRP
Exclamation Backfire Problem!
Ok, here is my situation;01 Impreza RS, Brospeed muffler and mid-pipe, removed silencer on stock intake, have reset ECU. I am getting a single "pop" backfire, sometimes two, when I let off on the gas. This happens at about, 2.5 to 3.5K RPM's, also sometimes when I shift gears! It does't happen at high RPM's, just the low range. Is this a problem I should take up with the Dealer, or is this just because of the mods I have done?! Any help on this would be greatly welcome. Thanks, Shawn
subee_love is offline
Old 02-15-2001, 01:46 PM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
happens w/any modded exhaust "i think"
used to happen on my GT w/my old set up..
and now on my RS w/the Scoobysport...
think it's pretty common and nothing to stress out about... i am no tech head as far as exhausts go tho.. i know someone here will have the explanation as to "why" it happens....
j.
Subie Gal is offline
Old 02-15-2001, 01:49 PM   #3
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Post
Backfires are fun, especially when you can get the vehicle to do it on queue.
I remember back in elementary school our soccer team had a beat up old ford van that we went to all our games in that would backfire on high acceleration. Our coach would do it right next to people on the sidewalk, he made one crackhead fall off his rusty bicycle. It was funny, we laughed.
remarcable is offline
Old 02-15-2001, 01:51 PM   #4
Lord-Atak
Member#: 3339
2002 Impreza WRX
Blaze Yellow
Post
My rs used to do it alot. Now only in cold weather about 3000rpm
Lord-Atak is offline
Old 02-15-2001, 02:04 PM   #5
Duva
Member#: 1733
2000 Impreza 2.5 RS
BRP
Post
I can't find the other thread on this, but I think it has to do with a slight delay (when you let off the gas) between the throttle closing up and the injectors injecting less fuel. If this is true, then there is still the higher level of fuel coming in to a cylinder once or twice without all the extra air needed to burn it. The extra unburned fuel is pushed out into the exhaust where it contacts the hot headers. It explodes on contact causing the popping you hear. I think the other thread said this is very common, but the stock exhaust is super-effective and muffles it out.
Wow... I just reread that. I hope it makes some sense. Someone please correct me if I'm wrong.
Duva is offline
Old 02-15-2001, 02:10 PM   #6
SanjuNana
Member#: 3314
2001 Impreza 2.5 RS
BRP
Post
You'er fine ... here's another thread that discussed the backfires (this one has a little more tech info on why the backfire is occurring).
http://www.i-club.com/ubb-files/Forum1/HTML/018695.html
SanjuNana is offline
Old 02-15-2001, 02:52 PM   #7
RotrPwr
Member#: 1506
1993 RX-7
Competition Yellow Mica
Post
Also could be that the modifications you have performed have caused your engine to run a little rich in the rpm range you mentioned. Sometimes a rich running engine will backfire. If this were the case there isnt much you can do to remedy this short of buying a AFC and trimming the fuel curve a little in the midrange. Of course you could always advance the timing a bit but that is not suggested since advancing the timing effects the entire rpm range and i bet your engine is running spot on on top, which advancing the timing would cause your engine to burn lean on the topend(read: detonation). Just a suggestion though.
Darril
RotrPwr is offline
Old 02-15-2001, 03:18 PM   #8
thepas
Member#: 817
Post
it's NORMAL, the car runs rich. Get used to it or get a Fuel controller and lean the car out a little.
Kyle
thepas is offline
Old 02-15-2001, 03:23 PM   #9
Lord-Atak
Member#: 3339
2002 Impreza WRX
Blaze Yellow
Post
Also forgot to ask why you think its a problem. I personaly like it.
Old 02-15-2001, 03:44 PM   #10
subee_love
Member#: 4093
01 Impreza
BRP
Post
Was just a little perplexed. I kinda like it myself as well. I'm glad it's not hurting anything!! Thanks for ALL the input
Old 02-15-2001, 05:25 PM   #11
Kissifur
Member#: 721
Post
its just because the exhuast flows more freely. its like breathing out through your mouth compared to breathing out through a straw...
Kissifur is offline
Old 02-15-2001, 07:13 PM   #12
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Post
Mine does it with stock exhaust. I like it.
Kinda reminds me of 'Uncle Buck'
CosmoTheCat is offline
Old 02-15-2001, 10:09 PM   #13
Freeskier
Member#: 3962
2001 F250 7.3L TD
2011 STi
Post
Mine does it with stock exhaust too but I hear it coming from the front of me on the right hand side (like just in front of the passenger)
Isn't it supposed to come from the back???
Stefan
Freeskier is offline
Old 02-15-2001, 10:45 PM   #14
meebs
Member#: 3251
2009 WRX Hatch
Post
Stefan, exact same thing with me too. The only thing i have done is remove the silencer.... but it was there with the silencer on also. It sounds like it's coming from under the bonnet rather than the back... I've never been on the outside of my car though as it went by... so I don't know what it sounds like out of the car.
-Mitch
meebs is offline
Old 02-16-2001, 03:23 AM   #15
ivbdn
Member#: 2736
2001 Impreza 2.5RS
Post
Nothing to worry about. Mine backfires and I too enjoy it.
ivbdn is offline
HTML code is On
2.5 Backfire problem Cooljo2.5rs Normally Aspirated Powertrain 10 04-29-2004 06:02 PM
Any one else have a backfire problem? hayscoob Normally Aspirated Powertrain 26 10-19-2001 07:55 PM
('93-'01) backfire problems anyone 2swft Impreza Forum 8 05-19-2001 10:38 AM
Backfiring problem? Boom New England Impreza Club Forum -- NESIC 0 05-18-2000 01:40 PM
