Old 09-29-2003, 06:52 PM   #1
generalwrx
Member#: 34742
2005 STI
Question Le Mans Headlights
What do i need to do to get my headlights to look like the Le mans cars have it...yellow.
generalwrx is offline   Reply With Quote
Old 09-29-2003, 09:38 PM   #2
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Either use a can of stained glass spray paint or get colored lens protection sheets. The downside of the stained glass spray paint is it will be difficult to make it smooth. The downside of the colored lens protection sheet is that applying it on a curved surface such as the headlight is much harder than applying it on the foglight.
There may be some legal concerns regarding coloring the headlight lens too.
satrya is offline   Reply With Quote
Old 09-29-2003, 09:41 PM   #3
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Here's how the texture can look like up close. Note the granularity of the painted surface.
Old 09-30-2003, 08:05 PM   #4
generalwrx
Member#: 34742
2005 STI
I thought they only used yellow bulbs...and black plastic around it or maybe carbon fiber. Are yellow lights even legal? Are projector lights better in your opinion?
Old 09-30-2003, 08:39 PM   #5
LinuxGuy
Member#: 17270
1998 Fender Bender
Holds 1000lbs.
If your really just looking for the look of yellow fogs, just buy some yellow window tint, (Xtreme Colors Window Tint, 24" x 78" roll, about $17) cut two circles of it, and place on foglamp.
LinuxGuy is offline   Reply With Quote
Old 09-30-2003, 08:48 PM   #6
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Yellow low/high beams might not be legal in some states. Yellow foglights should be legal.
Given the same bulb, good projectors are better than current reflector design in the sense that you can achieve a good vertical cutoff, which is relevant for low beams & fog lights. Also, the projector design would most likely be more compact. Other than that, I'm not sure if it has any advantages. One thing for sure, I wouldn't bother using a projector for a high beam or any middle-of-nowhere lighting.
Old 09-30-2003, 09:49 PM   #7
tgingrich
Member#: 44343
I run Hella all weather bulbs in the winter - they are pretty yellow and I've never had a problem with law enforcement. Full yellow headlights I believe are only legal in France.
http://www.rallylights.com/hella/yellowstar_bulbs.asp
tgingrich is offline   Reply With Quote
Old 10-01-2003, 01:00 AM   #8
Penguinking
Member#: 9422
2002 silver
wrx R.I.P.
what is the benefit of yellow lights?
Penguinking is offline   Reply With Quote
Old 10-01-2003, 02:01 AM   #9
tgingrich
Member#: 44343
Fog/rain/snow they do not reflect back as badly as white light
Old 10-01-2003, 11:37 AM   #10
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
www.lamin-x.com
They have precut yellow protective covers that work perfect. I'm ordering a set of those, and a replacement for my blown yellowstar bulb.
They yellowstars aren't that yellow, IMO, but the 85W ones are definitely bright on the low end and on the ground.
I dunno how the yellow on a white car will look, but I'm willing to give it a shot...
ScreaminFast is offline   Reply With Quote
Is anyone getting ready to watch the 24hrs. of Le Mans... Cigar2 Motorsports 13 06-15-2001 10:19 PM
American Le Mans series at LSIR in October bri99RS Bay Area Impreza Club Forum -- BAIC 4 08-29-2000 12:47 AM
NE1 going to Le Mans/GT races this weekend at sears point? HomerJay Bay Area Impreza Club Forum -- BAIC 6 07-21-2000 02:37 AM
Prodrive tipped for Le Mans entry nativo General Forum Archive 2 07-06-2000 12:24 AM
The worst Le Mans in the history of motorsport 22B_WannaBe General Forum Archive 16 06-20-2000 06:34 PM
