Welcome to the North American Subaru Impreza Owners Club Sunday August 2, 2015
Old 09-29-2003, 11:18 PM   #1
03ShrtBus
Member#: 43757
2003 WRX Wagon
Sonic Yellow
Question Switch
Welp this is my first post and it most likely won't be the last........have had my car 3 weeks and 2 days.......got it with like 36 miles on it and now have close to 3,300.........anyway........I am looking for a momentary toggle switch..............want a rocker or a push botton that will fit in one of the blank factory switch spots...........any help will be appreciated thanks..........BK
03ShrtBus is offline   Reply With Quote
Old 09-30-2003, 04:34 PM   #2
Synx
Member#: 43712
60's B-52H
03 WRX WRB
I was/am also looking for such a switch. I was thinking maby of getting a factory fog lamp switch and re-stensiling it for my needs, however after being quoted $26 or something insane like that from the dealer i quickly thought better of it. I would prefer to keep the factory look, but i may just have to end up doing the radioshack thing . Tell me what ya find.
Synx is offline   Reply With Quote
Old 09-30-2003, 11:11 PM   #3
BOFslime
Member#: 23845
2015 FLAT SIX
first thing: Welcome!
2nd: dont.....do.......this.....please
Its almost as bad as all caps. There's a guy at my work that types up his tickets using commas as spacers for his mumbling sentence fragments. It is quite annoying.
The less you annoy, the more responces you'll get.
For your question, what is this switch for? blinging underbody lights? Flashing strobes when you win a street race?
haha.. ah, i'm just kidding.
here's a 'nanna
BOFslime is offline   Reply With Quote
Old 10-01-2003, 10:00 AM   #4
03ShrtBus
Member#: 43757
2003 WRX Wagon
Sonic Yellow
Question
Welp sorry for the annoying text. I am hooking up a car alarm as a siren. When wired to a momentary toggle switch you can make the alarm whistle. As for the stock fog light switch, that is not a momentary toggle switch. I need a switch that turns off when i release the pressure on it. Once again thanks for any help.
P.S. Thanks for the NASIOC English 101 Lesson haha
Old 10-01-2003, 12:49 PM   #5
satrya
Member#: 5887
2002 GDAA
797
Lightbulb if you're out of options...
In case you couldn't find a reasonably priced switch that matches the blank, you could always get a momentary toggle switch that is threaded on the outside and comes with a nut. Then, it's a matter of cutting a thin sheet of metal (say, aluminum), drilling a hole for the switch, and bending the edges to make it look somewhat round and clip onto the existing trim. You can paint the sheet metal to blend in if you want. Here's an example, but not with the type of switch that you need:
satrya is offline   Reply With Quote
Old 10-01-2003, 03:02 PM   #6
pistoffjstr
Member#: 29283
2003 Subaru Forester
Red
AAAHHHHH YES the ole car alarm horn trick been there done that WHAT FUN that was
if you do it right you can get the whistle going you know the "wolf whistle" like when you see a good looking girl or guy in some cases fun fun fun
pistoffjstr is offline   Reply With Quote
Old 10-01-2003, 07:46 PM   #7
skivvie
Member#: 29719
'06 WRX Wagon
Don't know about the fitment, but here are some cheap switches:
http://www.sciplus.com/category.cfm?...4&category=141
skivvie is offline   Reply With Quote
Old 10-01-2003, 09:43 PM   #8
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
I have been using this one from Radio Shack for my garage door opener - fits inside one of the blanks - works well, and doesn't stick out like a sore thumb.
Part. no. 275-644
$2.29 each
Old 10-02-2003, 12:47 AM   #9
03ShrtBus
Member#: 43757
2003 WRX Wagon
Sonic Yellow
Question
Thanks for all the suggestions. I am a fan of the Radio Shack switch. As for the Sheet metal I am trying to do everything low profile on this car. Granted there will be a button or rocker switch there but it's not like a standard toggle that just "flaps in the wind" per say. But once again thanks and if anyone else has any suggestions they would be appriceated
Old 10-02-2003, 10:43 AM   #10
satrya
Member#: 5887
2002 GDAA
797
I'm not into making things too flashy, and imho, the sheet metal seem to blend in ok with the fake brushed aluminum trim of the GD/GG interior. As I also stated, it can also be painted trim black or some dark color too. Either that or drill one of the blanks, which is a one-way ticket imho.
Old 10-02-2003, 11:10 AM   #11
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
I believe the stock cruise control switch is a momentary pushbutton. So you could potentially get another one of those and change the label somehow.
I'm not 100% positive, but I do believe switches from other generations of Impreza, Legacy, Forester, Baja, etc. will also fit in, even though they will look different from the rest of your stock switches.
vrg3 is offline   Reply With Quote
Old 10-02-2003, 01:53 PM   #12
03ShrtBus
Member#: 43757
2003 WRX Wagon
Sonic Yellow
Question
Welp thanks for all the suggestions. I stopped at Radio shack today and got the switch. Tonight I will do the install. As for the Cruise control but it is not a momentary toggle. If it was then that would mean you would have to hold that button in when you wanted the cruise control on. But that's just a side note. Once again thanks for all the help and I am sure I will be asking more questions down the road.
Old 10-02-2003, 02:05 PM   #13
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
I'm pretty sure the cruise control is a momentary switch.
It sends a signal to the cruise control computer. The computer is responsible for turning cruise control on and off and it has an internal latch.
Take an ohmmeter to your switch and find out.
Edit: I wrote "toggle" but mean "momentary" originally.
Old 10-02-2003, 02:39 PM   #14
03ShrtBus
Member#: 43757
2003 WRX Wagon
Sonic Yellow
That is true but at the same when I push the cruise control button the indication light on the switch stays on which means there is still power goin to the switch till you click the cruise control off. I guess the only real way to find out is to put the tester to it like you said.
Old 10-02-2003, 02:44 PM   #15
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
The indicator light is on a separate circuit. It's actually driven by the computer as well.
I've taken apart cruise control switches from BC/BF Legacies, BD/BG Legacies, and GC/GF Imprezas and they all operated this way.
Old 10-03-2003, 12:27 AM   #16
03ShrtBus
Member#: 43757
2003 WRX Wagon
Sonic Yellow
Question
So here's the question then. If I go to subaru tomorrow and order a cruise control switch, I could use that as my momentary toggle switch. The second part is my brother owns an 04 STI and the DCCC switch appears to be a momentary toggle to switch from the computer to the driver control part. Would that be the better way to go? Once again I thank you for all your help
Old 10-03-2003, 10:57 AM   #17
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
I'm not that familiar with DCCD... I thought it was more than just a switch, though. Doesn't it also contain a dial to let you choose the amount of lockup?
Old 10-04-2003, 02:58 PM   #18
03ShrtBus
Member#: 43757
2003 WRX Wagon
Sonic Yellow
Dial yes. The two are sperate though. You have to push the button to activate or de-activate the system and then dial let's you choice where the power goes
Switches Switches Switches!!! snowcrzy Interior/Dressup/Audio & Security 14 02-25-2010 02:53 PM
ABS Switch using the OEM foglight switch redobs Electrical & Lighting 2 08-11-2003 06:01 PM
Mounting a UTEC remote switch in a switch blank Rich10 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-10-2003 09:32 PM
To switch or not to switch?? hairband Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-03-2002 09:49 AM
Where can I order the IC spray switch and a rear fog switch? Schleppy Interior & Exterior Modification 2 04-04-2002 07:31 PM
