Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 09-30-2003, 07:02 AM   #1
BlackIce
Member#: 3164
Default Am I the only one??
whose rear wiper has crapped out?
I have a '98 GT Wagon with ~65K miles. I've cleaned and repacked the rear wiper gearbox once already because it had corroded and jammed up. It's stopped again and I'm looking for a more permanent fix before I tear up the the interior again.
Anyone else been into the the tailgate and fixed this?
Thanks,
Dave
98 GT Wagon,
01 Forester S
77 911S
BlackIce is offline   Reply With Quote
Old 09-30-2003, 10:36 AM   #2
sooberoo
Member#: 33302
2005 Leggy GT Sedan
Brilliant Silver
When its cold mine just makes a horrible squeaky groaning noise, but has yet to crap out. II've debated "going in" to check it out. So I'd appreciate any comment as well
If you do get into it, maybe replace it with a used one from a wrecker?
sooberoo is offline   Reply With Quote
Old 09-30-2003, 01:15 PM   #3
subster
Member#: 40847
2008 2000 2.5 RS
1995 SVX
Default Probably a stupid question but,
did you grease the gears in there? I would just call the service shop and get their advice. Unless it's "Well, it'll be $100 just to look at it." I have a 96 wagon and mine's fine.
subster is offline   Reply With Quote
Old 09-30-2003, 03:36 PM   #4
BlackIce
Member#: 3164
$100 is about what I'd expect. It takes a good 15-30 minutes to get it all apart.
I should probably disassemble it first and see how bad it's gotten internally.
New motor from the local dealer is $120 + tax. Off the web, I've seen new for ~$100 + shipping and used for about the same. For the cost difference I'll probably buy new locally to save time and hassle. Can't see buying used for no discount.
I was hoping someone had a great fix to keep the water out of the bushings and gearbox.
Dave
Old 09-30-2003, 03:39 PM   #5
subster
Member#: 40847
2008 2000 2.5 RS
1995 SVX
Default I wonder
Why you are having this water leakage problem and I am not? It hasn't been damaged?
Old 09-30-2003, 03:43 PM   #6
BlackIce
Member#: 3164
Don't recall noticing any damage last time I had it apart. I'll look more carefully this time.
Dave
Old 09-30-2003, 03:51 PM   #7
subster
Member#: 40847
2008 2000 2.5 RS
1995 SVX
Default Hmmmmm....
Try some household sealant from the hardware store for a couple bucks. When I had my old Honda my windsheild was leaking and that worked like a charm. When you put it back on use that around the seals and it might work. If that's what the problem is.
Old 10-01-2003, 06:53 AM   #8
BlackIce
Member#: 3164
Default Opened it up last night
The corrosion was limited to the outer inch of the gearbox housing just below where the shaft attaches to the wiper arm.
Was a bear driving the shaft back out of the housing, but it cleaned up OK.
Gearbox was clean and dry (and well lubed).
I packed the shaft housing with light waterproof grease and used more under the little plastic hat that covers the large mounting nut and then some more when I re-assembled the wiper arm to the shaft and a little more under the little plastic cover that covers the nut that attaches the arm in place.
Should last for a while.
Dave.
Old 10-01-2003, 09:13 AM   #9
subster
Member#: 40847
2008 2000 2.5 RS
1995 SVX
Thumbs up cool
Am I the only one that has just one key to their car? delongedoug Off-Topic 20 11-14-2008 11:20 AM
Am I the only one fed up with this one wingless wrb STi always waving at me? LotusDriftx Mid Atlantic Impreza Club -- MAIC 65 02-02-2006 02:42 PM
Am i the only one who thinks Lucas should direct only Mexican novelas? HighWayDrifter Off-Topic 10 05-20-2005 11:21 AM
AM I the only one that loves Only the Strong? WR-REX Texas Impreza Club Forum -- TXIC 8 12-10-2001 01:03 AM
