Old 09-30-2003, 01:43 PM   #1
grndc2gsr
Member#: 42070
2007 S2000
gpw
Default greddy boost gauge install=easy?
i want to get the greddy 60mm boost gauge part #16001212. the greddy web site says you simply plug it into the intake manafold, how do u do this is it simple i do not want to mess up my car. i was going to get the black gauge that lights up green, does any one know if this matched our car well thanks for the help
grndc2gsr is offline   Reply With Quote
Old 09-30-2003, 06:32 PM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Installing a boost gauge is pretty trivial - you put a T fitting in the line off the BOV or the one off the front of the intake manifold, run the vacuum tube to the gauge inside the car (or, if it's electronic, to the sender, then run the wires from the sender into the car), tap power somewhere gauge illumination, and you are good.
If you do a quick search (or look on scoobymods) there are a bunch of threads on how to do this.
Old 09-30-2003, 06:48 PM   #3
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Default Re: greddy boost gauge install=easy?
Ask and ye shall receive....
Zola is offline   Reply With Quote
Greddy boost gauge install for 2 year old catdogr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-17-2003 01:29 AM
Greddy boost gauge install doppelganger Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-01-2003 04:02 PM
Defi Center Dash Pod & Greddy Boost Gauge Install Imprezin Newbies & FAQs 8 10-05-2002 06:44 PM
greddy mechanic boost gauge installation D&D Tuning Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-15-2002 09:22 PM
Help: GReddy Electronic Boost Gauge Installation GOT_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 11-06-2001 06:14 PM
