Old 09-30-2003, 06:05 PM   #1
BlackAndBlue
Member#: 40617
Exclamation Shift Light only?
Is there a way to only have a shift light connected to the tach and go off at a certain rpm instead of having to buy a bunch of electronics?
and while im at it, can you change the rs instrument panel so that the rpm gage is in the middle and the speedometer is on the side like the sti's?
BlackAndBlue is offline   Reply With Quote
Old 09-30-2003, 09:35 PM   #2
brunetmj
Member#: 8023
2004 2.5 RS
I would think the simple way is to add a tach with a shift light. Even if alternate gauge panels where available (speed and tach reversed) I would doubt they would have a shift light.
brunetmj is offline   Reply With Quote
Old 09-30-2003, 09:53 PM   #3
BlackAndBlue
Member#: 40617
yeah that would be the simple way but i think having two tachs is a little repetitive, and just having the light doesnt take up as much room and can be put in a lot of places
Old 09-30-2003, 10:57 PM   #4
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
You can buy a stand alone shift light. Summit racing should have a bunch of different ones.
lotusTT is offline   Reply With Quote
Old 10-05-2003, 06:41 PM   #5
Charged Performance
Vendor
Member#: 40645
I don't know if UTEC's solenoid switch is only MAP based - but users of XEDE can use the solenoid out as a shift light if it is not used for anything else. As a matter of fact you can use anything that has an analog signal out based on rpm.
Charged Performance is offline   Reply With Quote
Old 10-05-2003, 10:13 PM   #6
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Summit Racing has plenty of shift lights.
Look on the 2nd page under Proform to their adjustable shift light. No seperate pills to worry about, just adjust a rheostat in the back (I'm guessing) to adjust when the light comes on.
For $50 bucks, it can't be that bad. I'm debating mounting on on the steering column to use in my car.
AJ
AJ711 is offline   Reply With Quote
Old 10-06-2003, 10:26 PM   #7
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
I have a proform. Check with them to see if your car puts out enough signal to power it. I've installed a tach in a Neon racecar and the signal would not drive the proform. I've yet to hook it up anywhere successfully, but plan to build a simple amplifier and try again over the winter.
jack
Old 10-07-2003, 05:38 PM   #8
leecea
Member#: 37359
2003 WRX
I have the Axas shift light that plugs into the 12v lighter socket. It works fine and has 4 sequential lights with upper and lower activation points. The light unit is pretty small and can be mounted in view, while the controller can be out of the way. I have it set so that it activates at 5000 and everything it lit up by 6200. It's lots of fun!
leecea is offline   Reply With Quote
Old 10-07-2003, 07:03 PM   #9
BlackAndBlue
Member#: 40617
where'd ya get it, how much...
Old 10-07-2003, 09:20 PM   #10
leecea
Member#: 37359
2003 WRX
Here you go...
http://www.rsversion.com/details.asp?ProdID=271
They are not quick with shipping, but their price was good.
Old 10-13-2003, 12:29 AM   #11
halogen
Member#: 6456
Why not this?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2437025176
I've always prefered japanese stuff.
halogen is offline   Reply With Quote
Old 10-13-2003, 02:25 PM   #12
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
Crystal White Pearl Mica
Texas25RS is offline   Reply With Quote
Old 11-02-2003, 12:22 AM   #13
wrichiex_sti
Member#: 36349
2003 wrx
wrblue
Originally posted by Texas25RS
Just another option....
http://www.harlan-engineering.com/st...hiftlight.html
Does anyone have any experience with these?
wrichiex_sti is offline   Reply With Quote
Ecliptech Shift-I Sequential Shift Light Install and Review. bushflyr Electrical & Lighting 6 10-21-2007 11:37 PM
FS: 'On dash' gear shift indicator display w/shift light RS WRC Private 'For Sale' Classifieds 25 03-10-2006 04:37 PM
'On dash' gear shift indicator display w/shift light RS WRC Interior & Exterior Modification 2 09-29-2005 01:19 PM
Fog Lights with Parking Lights Only blueslsti Electrical & Lighting 5 02-17-2005 08:41 PM
kartboy shift knob, stock uppipes, razo shift light anthonyrb98 Private 'For Sale' Classifieds 14 09-29-2004 01:57 AM
