Old 09-30-2003, 10:41 PM   #1
ButtDyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 05 Saabaru
Default Where do you put the ball of your foot for heel toe?
Coming back from work on an empty road, I decided to try a couple 4->3 downshifts heel-toe double clutch style. I already (very slowly) double clutch downshifts and figured I'd give it a shot.
Just testing in the parking lot, it was pretty much impossible for me to have the ball of my foot on the brake and make my heel hit the gas pedal - it was actually going a little too far and hitting the raised part of the floor to the right of the gas pedal. I had to aim for the top-right corner of the brakes and then it was easier (but still felt a little funny).
My question is - is the top right of the brake pedal the right place to aim w/ the top of my foot? And how "on" the brake pedal should I be, should I be covering up an inch wide of the pedal, 2, barely any, etc etc...
I managed to get two 4->3's in smoothly before I got home, just looking for a little guidance. Thanks.
-bd
ButtDyno is offline   Reply With Quote
Old 09-30-2003, 10:48 PM   #2
dowroa
Member#: 17498
No More Subarus :(
Only a truck, for now. ;)
Default Re: Where do you put the ball of your foot for heel toe?
-bd
Man, I have a hell of a time doing heel toe downshifts without going a brisk pace. The result is from not having to depress the brake pedal as far, and I wind up slamming the brake in order to move my heel over to get a good slap on the gas pedal.
I would suggest trying to at a speed where you can get more brake pedal so the brake is actually depressed lower than then gas. Then it is easier to roll over and blip the gas.
Someone else will have better over all advice, I am sure. I just thought I would interject my point of view with heel toe. Good luck!
- dow
dowroa is offline   Reply With Quote
Old 09-30-2003, 11:27 PM   #3
STIRS
Member#: 16731
2002 Impreza WRX
WR Blue
I can do it driving slow or fast without problems, what works for me when im driving "spiritedly" is pressing the brakes not with the top of your foot but a little lower towards the middle of your foot, that way its easier to hit the gas with your heel and give it more gas. Sometimes when im just driving normally I press the brakes normally and hit the very bottom left corner of the pedal to blip it just a little but because im not going that fast. If you are hitting the raised part of the floor just move your foot up a little so you end up hitting the gas pedal at a higher point.
STIRS is offline   Reply With Quote
Old 10-01-2003, 03:55 AM   #4
xenonk
Member#: 18823
2011 :dunno:
monochrome?
Lightbulb NOTHING LIKE VISUAL AID!!
I have a video for you!!! It's a video of my footwork that you are probably looking for (hope you dont mind starring at my hairy legs in the process).
If you want the technical write-out, just goto www.howstuffworks.com or just pick up the book GOING FASTER by Skip Barber Racing School ($35 at www.amazon.com ).
I hope this link works for ya, just click on the Salazar Racing Video
Footwork Video
Keefe
xenonk is offline   Reply With Quote
Old 10-01-2003, 09:05 AM   #5
ButtDyno
Member#: 17301
is the "dark side"
Default Re: NOTHING LIKE VISUAL AID!!
Footwork Video
Keefe
All I get is
Server Application Error
The server has reached the maximum recovery limit for the application during the processing of your request. Please contact the server administrator for assistance.
-bd
Old 10-01-2003, 09:13 AM   #6
Slowpoke
Member#: 19879
2004 WRX
Java Black
I press the brake in exactly the same spot as I do when braking regularly. To heel toe I just rotate my foot. I don't blip the throttle with my heel, I actually use the outside edge of my foot about halfway down. That part of my foot hits the upper half of the throttle pedal.
It takes a bit of practice to be able to modulate brake and throttle independently. But once you get it you will be able to do it regardless of whether you are braking lightly or heavily, and you will be able to do it without jabbing the brake when you blip.
Slowpoke is offline   Reply With Quote
Old 10-01-2003, 10:09 AM   #7
reks
Member#: 9567
2005 Legacy GT Wagon
It is proper to put the ball of your foot on the brake and the heel on the gas pedal.
However, my size 11 1/2 shoes also allow me to put the ball on the brake and the right outside part of the shoe on the gas if I roll my foot from left to right.
Depending on how big your feet are and how the pedals feel in your car, one may work better for you than the other.
reks is offline   Reply With Quote
Old 10-01-2003, 11:49 AM   #8
Lazy
Member#: 43917
95 Nissan 240sx
Heel-Toe is such a crappy term.... you dont litterly have to do it that way many ppl like stated use the same part of there foot just inside on the brake and outside part on the gas i do that becuase my size 13 shoe and in my 240 the gas pedal is short so i have to almost get it completly sideways to literaly heel-toe. so yea i say get in there play around with a couple diffrent foot positions and see what feels most natural and comfortable for you.
Lazy is offline   Reply With Quote
Old 10-01-2003, 12:04 PM   #9
Badkarma
Member#: 42641
2004 GTO
Red as Hell
Yeah, it's niced to be blessed with big feet . I can't count the number of times I've "accidentally" h/t with my 13s
I can put the left edge of my shoe on the brake and the right edge on the gas at the same time. All I have to do is rotate my foot.
I still suck at it though.
Badkarma is offline   Reply With Quote
Old 10-01-2003, 08:17 PM   #10
Caddy Daddy
Member#: 11070
2004 SG9, '77 R100/7
'00 Ducati ST2
i dont have the slightest where you guys are finding the room to rotate your foot. I can barely fit both my legs down there, much less start turning my right.
my right knee keeps on hitting the center console, and has no room to go any direction except down onto the accelorator (with it still pressing against the console).
maybe the newer models have more legroom? id think smaller feet would be easier to do this with.
Caddy Daddy is offline   Reply With Quote
Old 10-01-2003, 09:03 PM   #11
Badkarma
Member#: 42641
2004 GTO
Red as Hell
My brother is 6'4" oh about 230lbs or so. He had the seat back all the way and was reclined a good bit.
He fit, but I'd say a 2 hour trip would be his max.
I'm 6'0" 200lbs and I'm just as comfortable in the rex as I was in my trailblazer.
Parents: How do you protect the back of your STi seats? jojotherider Interior & Exterior Modification 37 04-28-2009 10:28 AM
Do you hate the sound of your voice? DilferJr Off-Topic 41 09-19-2006 02:30 AM
Where do you put your greasy ball when not in use? CosmoTheCat Off-Topic 23 06-24-2006 08:59 PM
Where do you put your nasioc.com sticker? Sputt Interior & Exterior Modification 23 07-10-2005 11:47 AM
Poll: Where do you put your wallet?? O2-GGA Off-Topic 31 09-30-2003 04:04 PM
Message Board Statistics All times are GMT -4. The time now is 05:37 PM.
