Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 02-14-2001, 04:55 PM   #1
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
Post how acurate would a 4eat rs be with the awd fuse pulled be on a 2 wheel dyno?
bye this i mean putting it in front wheel drive and putting it on a 2 wheel dyno?
thanks
Greg
GregBolby is offline
Old 02-14-2001, 05:15 PM   #2
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
It'll be accurate...for your front two wheels. Then when you put it back to awd you have to factor in drivetrain losses.
Use it to gauge the progress you make with each mods. And use the numbers for your car only.
I've done it, but only to see how much power I'm making with turbo, with my current NA setup, etc.. I don't compare it with anyone else's numbers.
Keiho is offline
Old 02-14-2001, 05:19 PM   #3
GregBolby
Member#: 498
1981 jdm swapped gc
sniklfritz
Post
what would stock hp be around on the dyno?
in front wheel mode
Greg
Old 02-14-2001, 05:25 PM   #4
NebScoob
Member#: 2646
Post
Id be VERY carefull...
As far as I know the AWD fuse controls the electirc clutch mechanism which lock up the rear wheels. The default power split is still 90/10 which means the clutch will be draging while you do it, and could possibly damage it. You could drive the car like that, since the rear wheels will be moving, but when one side rotates and the other doesn't... could be trouble.
It's the same reason you can't tow the car with the rear wheels on the ground.
NebScoob is offline
Old 02-14-2001, 07:57 PM   #5
CRZ_MSL
Member#: 1610
Post
If you look in the owner manual you will see directions on how to use the fuse to make your car FWD.
Right under that is another paragraph warning you that although you can do it, you really really really shouldn't unless it is for emergency/short short distances.
Or unless you want to replace bits of your drivetrain.
CRZ_MSL is offline
HTML code is On
dose awd drivetrain pull right on hard launch grocerygetter303 Newbies & FAQs 13 01-26-2009 08:44 PM
how reliable would a 99 rs w/ 110K miles be? hendo2.5 General Community 39 04-18-2007 10:35 AM
What is the red wire with the pink fuse for in the HU wiring harness? Krelkor Car Audio, Video & Security 3 08-29-2002 11:05 PM
Any way to tune a WRX on a 2-wheel dyno? oldmansan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-02-2002 11:45 PM
Attn. all who will be with the early crowd for CT. on sunday scoobyruman New England Impreza Club Forum -- NESIC 17 08-17-2000 12:37 AM
