Old 10-01-2003, 03:23 PM   #1
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Default Oil pressure guage
I am trying to install my oil pressure guage and don't know where to tap for oil. I have the rear galley plug used for oil supply to my turbo, and the front already has the stock presure sender. I have a T that I could put in one of the galley plugs, buts its 1/8" NPT not BSPT. To add to the problem, my oil pressure sender is NPT, but if needed I can get an Autometer NPT to BSPT adapter for that. Does anyone know where I can get a 1/8" BSPT T? Or some other way to hook up my oil pressure?
lotusTT is offline   Reply With Quote
Old 10-01-2003, 04:19 PM   #2
pistoffjstr
Member#: 29283
2003 Subaru Forester
Red
http://www.geocities.com/matsut_rpi00/autometer.html
Here you go
i used these "destructions" when i installed mine
have fun its pretty easy
if your local i could help
im in bangor PA
pistoffjstr is offline   Reply With Quote
Old 10-01-2003, 04:27 PM   #3
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Where did you find that adapter on ThinkAutos' website? I didn't see it anywhere. Is there anywhere else that sells the same adapter?
Old 10-01-2003, 04:52 PM   #4
pistoffjstr
Member#: 29283
Red
when you go to thinkauto's site click on "online shop" then again click online shop then youll be able to do a search for the part number "TP8"
try this
i did see it somewere else but i dont remember were ...it took like 7 days for me to get it and i believe it was under $20 shipped
Old 10-01-2003, 08:51 PM   #5
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
Great install instructions. I didn't realize that an adapter was needed for the oil pressure install.
j
ilmaestro is offline   Reply With Quote
Old 10-02-2003, 01:38 AM   #6
pistoffjstr
Member#: 29283
Red
the adapter makes it ALOT EASIER
and no oil light in the dash cause you can still use the stock sensor
WTB: boost, oil temp., oil pressure guages shampy2k NESIC Private Classifieds 2 02-19-2009 11:54 PM
Defi boost, egt, water temp, oil temp, oil pressure guages plycette29 Interior/Dressup/Audio & Security 7 09-22-2008 02:25 PM
Oil pressure guage BlueWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 291 06-16-2007 05:22 PM
Quick ? re: oil pressure guage install gravel Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-28-2003 05:46 PM
Easiest place to tap for Oil Pressure guage. Kwyjibo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-13-2003 06:27 PM
