Old 02-13-2001, 05:23 PM   #1
kaos200
Member#: 2692
Post Extra Plug in engine bay! (by water bottle) HELP!
Hello,
I wish to attach something to this plug and was wondering if any one has done so or knows how to?
I need to know where the plug leads to..
if it is ignition switched?
it is 12volts right?
PICTURES would be very helpful..
any tips/ suggestions would be welcome as well!
Thanks all...
Kian S.
kaos200 is offline
Old 02-13-2001, 05:49 PM   #2
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Post
Yes, pictures would be very helpful, what plug are you talking about?
Jim
Edit: Are you talking about the extra plug that's on the same wiring harness as the fuild sparyer motor? That's the only one that I can think of right now.
[This message has been edited by Impreza Rider (edited February 13, 2001).]
Impreza Rider is offline
Old 02-13-2001, 05:51 PM   #3
kaos200
Member#: 2692
Post
look nect to the windshield spray bottle and follow the wire, there will be a unused/greasefilled plug just sitting there ;I
kaos200 is offline
Old 02-13-2001, 06:08 PM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Post
That plug is for the second washer fluid pump on the Impreza Wagon and the OBS.... it traces back to the bottom of the windshield wiper control stalk on the steering colum.
Brian
AIM: NUrsalia ICQ: 84483950
http://members.nbci.com/_XMCM/northu...reza/index.htm
Come See The Magic World Inside the Abandoned Refrigerator!
North Ursalia is offline
Old 02-13-2001, 06:09 PM   #5
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Post
Gummy bear is right. Its for the second water sprayer pump.
Imprezer is offline
Old 02-13-2001, 06:14 PM   #6
Gerry
Member#: 1829
Post
I believe that is the plug that goes on the 2nd motor "on the washer bottle" for the water injection...Gerry
Gerry is offline
Old 02-13-2001, 06:23 PM   #7
kaos200
Member#: 2692
Post
anyone know the colors and location of the wire(further down from the stalk/ maybe next to the fog light switch?)
kaos200 is offline
Old 02-13-2001, 07:02 PM   #8
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Post
Depends on the model year, so quoth the Gummi Bear.
Brian
Old 02-13-2001, 07:30 PM   #9
kaos200
Member#: 2692
Post
2001
should be exact same as 2000
kaos200 is offline
Old 02-13-2001, 07:33 PM   #10
Member#: 67
1999 Outlasting
the competition.
Post
its where you get the 12V power for the tec-2
tom@kartboy is offline
Old 02-13-2001, 07:47 PM   #11
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Post
Dark blue with a black stripe... you will find it at the very base of the wiper control stalk (you have to remove the steering wheel cover to get at it).
Brian
Old 02-13-2001, 07:48 PM   #12
kaos200
Member#: 2692
Smile
hehehe... "too bad" i'll be running a Wolf 3D hehehe...
kaos200 is offline
Old 02-13-2001, 07:50 PM   #13
kaos200
Member#: 2692
Post
Hey North Ursalia, that's the power wire right, do I just ground to the closest black?
or directly to frame somewhere?
thanks...
kaos200 is offline
Old 02-14-2001, 12:03 AM   #14
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Post
kaos200, it's technically the power wire, but just remember, subaru switches ground instead of power (power travels when ground is applied) so pick a good grounding spot.
Brian
Is that a chicken up there? Nope, just the way he's holding the grapefruit!
Old 02-14-2001, 09:24 PM   #15
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Post
I have pics of where the wire ends up on the AZScooby.com site under the headlamp washer mod section. It's kind of hard to see but I think I described how to find it. Brian is right. Ground that blue with black stripe wire and it will give you power to the plug. Read through the install directions here:
http://www.azscooby.com/mods/AZScoob...mpwasher.shtml
I had to pull the steering colmun apart under the wiper stalk and trace the wire back to the plug under the dash.
[This message has been edited by Peaty (edited February 14, 2001).]
Peaty is offline
HTML code is On
Seibon CF Hood and Water in Engine Bay Columbia1991 Interior & Exterior Modification 8 05-21-2010 12:27 AM
Unknown broken OEM plug in engine bay jblaine Electrical & Lighting 4 01-07-2009 11:42 AM
water in engine bay-Problem????? reedodafreedo Normally Aspirated Powertrain 35 03-04-2005 09:16 PM
Help - Leaky Battery. Corrosion of Metal Bits in Engine Bay Thug New England Impreza Club Forum -- NESIC 6 11-10-2002 07:46 PM
extra wire harness in engine bay Murray Normally Aspirated Powertrain 1 05-12-2002 07:27 PM
