Old 10-01-2003, 06:02 PM   #1
maharashii
Member#: 41022
Default Stock foglight installation (98 OBS)
Hi guys,
I picked up a set of stock fog lights & the switch to install in my 98 OBS.
Looking under the hood, I can't find any harness to go to the lights. I found the harness for the switch under my dash (brown connector plugged in to a blank) , but I can't find anything for the lights themselves.
I checked behind the headlights, and I unwrapped the wire harness on the drivers side from under the car, but I don't see anything in there either.
Since I appear to have the wiring for the fog light switch, I would assume I have the wiring for the lights themselves, right?
maharashii is offline   Reply With Quote
Old 10-03-2003, 03:12 PM   #2
avk
Member#: 17252
'06 WX8
59E
Do you have a cruise control? If yes, the plug you've found must be for the fog switch. If no and there's only one plug, it's for a cc switch.
avk is offline   Reply With Quote
Old 10-03-2003, 04:12 PM   #3
kermit
Member#: 7661
1999 Legacy GT
If I remember right when I installed my foglights, there is a white connector up on the left front corner of the car right by the horn and the battery where the fog light harness connects into. Then there is a relay that you have to install under the dash as well as the switch. I have a 98 L and the fog lights are the same.
kermit is offline   Reply With Quote
Old 10-03-2003, 04:46 PM   #4
maharashii
Member#: 41022
I have two connectors under the dash - one for cruise and the other I assume is for the fog lights.
I'll look for the white connetor by the horn. I don't have the relay in the fog lights that I bought - how can I find out what I need?
Old 10-03-2003, 06:02 PM   #5
kermit
Member#: 7661
1999 Legacy GT
The two connectors under the dash are for the cruise switch and the other is for the foglight switch. The relay part number is 82501AA130. I will look this weekend to see if I still have my installation instructions. I will let you know probably monday.
Old 10-04-2003, 02:12 PM   #6
maharashii
Member#: 41022
hey kermit ! thanks for your help - I appreciate it.
I took a look around the horn but didn't see any connectors (it was dark out).
I'll be working on the cars a bit today so I'll look closer for that white connector.
-maharashii
98 OBS stock foglights lacdaddy Electrical & Lighting 0 12-17-2009 01:45 PM
JDM Foglight Install Questions on a 98 Legacy GT 2.5WagonGuy Legacy Forum 1 05-20-2006 06:55 PM
FS: wrx sedan stock rear sway bar and stock foglights nekoball Bay Area Impreza Club Forum -- BAIC 5 01-29-2003 10:25 PM
looking to get rid of stock audio parts? (99 OBS) renduy Rocky Mountains Impreza Club Forum -- RMIC 3 02-03-2002 11:04 PM
Hella 500 Install to Stock Foglight Locations: Experience and Maybe a Lesson Learned. Yotsuya Interior & Exterior Modification 14 04-13-2001 10:23 AM
