Old 02-13-2001, 03:18 PM   #1
Camaroman
Member#: 1559
2004 Sierra Denali
Post Foglight switch light bulb replacement
I assume that the foglight switch has a light bulb in it?
Mine went out...and dont get any daylight before or after work to check it out...
So if anyone can generally explain how to remove the switch or get to the bulb...I'd appreciate it...
if no response I can play w/it on saturday
Thanks
Camaroman is offline
Old 02-13-2001, 05:26 PM   #2
AccidenT
Member#: 2024
2005 Legacy 2.5i
Atlantic Blue Pearl
Post
http://www.i-club.com/ubb-files/Forum1/HTML/016078.html
There is a bulb, but I don't know how to remove the switch (I'm in the same boat as you - mine burned out but I haven't had time to investigate switch removal)
AccidenT is offline
Old 02-13-2001, 05:44 PM   #3
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Yeah, pop off the lower dashboard (retainer clip facing door, 2 screws at each bottom corner) and you'll see how to snap out the switch from behind.
RidinLow is offline
HTML code is On
FYSA Accessory switch light bulb part numbers. steven765 Electrical & Lighting 0 09-02-2009 10:44 AM
Door Lock/Unlock Switch Light Bulb? Stylistics18 Interior & Exterior Modification 5 06-20-2009 10:06 PM
Does your Foglight Switch Light up? Uncle Ben Electrical & Lighting 13 06-25-2005 05:36 PM
Light Bulb Replacement au112 Vancouver Impreza Club Forum -- VIC 16 04-12-2001 08:47 AM
Heating - A/C dash light bulb replacement info Peaty Legacy Forum 1 12-09-2000 12:24 AM
Message Board Statistics All times are GMT -4. The time now is 11:36 AM.
