Old 10-01-2003, 06:29 PM   #1
panman91
Member#: 37524
Platinum Silver Metallic
Default RHD JDM headlights (horizontal adjustment)
which way do i turn the screw for left adjustment
and which do i turn for right adjustment.
panman91 is offline   Reply With Quote
Old 10-02-2003, 12:21 AM   #2
pityr
Member#: 31719
probably unscrew it to lower and screw it in to make it go higher.
so left to lower and right for higher.
Could always point them at a wall or something flat and experiment.
pityr is offline   Reply With Quote
Old 10-02-2003, 03:31 PM   #3
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
either way for aligning, I'd say find a wall or a house with a flat surface to aim that way
it's pretty obvious which way does what when you do it that method...
speed safely
Brian
Slvrblt is offline   Reply With Quote
Old 10-02-2003, 03:42 PM   #4
panman91
Member#: 37524
easier said than done.
there is no room to adjust horizontally with these headlights on the car.
Old 10-02-2003, 04:55 PM   #5
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
In my experience the horizontal adjustment screws are the easiest to reach. Are you taking off the snorkel on the passenger side? That will free up some space. Also, you may want to invest in a ratcheting 8mm wrench.
Zola is offline   Reply With Quote
Old 10-03-2003, 10:37 AM   #6
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
key to making it easy
speed safely
Brian
RHD and LHD JDM headlight difference? Tomado Interior & Exterior Modification 20 10-17-2009 05:04 PM
***Damaged RHD JDM Headlight dubluv17 Private 'Wanted' Classifieds 1 06-13-2006 02:15 AM
JDM rhd STI headlights hiwrx Private 'Wanted' Classifieds 0 02-15-2004 06:47 PM
STI RHD JDM passenger side headlight! baxterwrx Private 'Wanted' Classifieds 1 11-17-2003 09:48 AM
RHD JDM Headlights Alignment Hedge Interior & Exterior Modification 2 12-31-2001 10:21 AM
