Old 10-01-2003, 06:38 PM   #1
pat3
Member#: 38154
2004 WRX Sedan
Default AC/Defrost Stinks...suggestions??
i have a 2004 WRX and I noticed a problem this morning heading in to work. I was running the defrost for a couple of minutes, which initiates the AC motor, to draw out the moisture to better aid the defrost process. I later parked the car and got back in about an hour later and smelled a funky mold like odor coming from the fresh air vent. I then turned the recirc with the fan on high on and the smell dissipated. Then turned recirc back off and the odor came back but not as bad, later disappearing all together. I heard that mold might be the cause from previous searches. Was wondering if that sounds about right and whether anybody else with an 04 wrx...or heck anybody with a wrx that uses the defrost with the AC has had similiar problems with a funky smell. It's not a gas or oil smell, but definitely more like a funky moldish smell...any suggestions on how to alleviate this problem would be most appreciated....thanx!
pat3
pat3 is offline   Reply With Quote
Old 10-02-2003, 06:02 AM   #2
Subie Nut
Member#: 4821
2004 STI
Blue on Gold
Default Lysol
Turn the vents on fan on high switch to fresh air. Go outside of the car and just below the wipers you should see some slats, those are the fresh air vents hit them with some Lysol and that should take care of yourproblem. To keep this form happening in the future turn off the compressor and switch on the heat five minutes before you get out of the car. This is what I have done with all of my cars and none of them have ever smelled.
Subie Nut is offline   Reply With Quote
Old 10-02-2003, 10:52 AM   #3
pat3
Member#: 38154
2004 WRX Sedan
thanx for the info...will try it out...
Old 10-03-2003, 11:40 AM   #4
impRSa
Member#: 6521
Default AC smell
impRSa is offline   Reply With Quote
has anyone in the area done the AC/Defroster microswitch mod? alacrity024 New England Impreza Club Forum -- NESIC 32 02-13-2007 03:04 PM
How to disable AC when defroster is on DickWRX Interior & Exterior Modification 5 06-02-2004 06:54 AM
Sti - Kill the AC on defrost? WRX-72 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 10-22-2003 11:11 AM
AC/Defrost Mod from Scoobymods Schleppy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 04-19-2003 01:11 PM
AC on with defroster? Thats dumb! jasonmolinari Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 01-16-2003 05:07 PM
