Old 02-13-2001, 10:13 AM   #1
the spacecowboy
Member#: 765
Post two plugs under dash Q
i was under my dash looking and there two green plugs that go together but they are unhooked....
3 prong plug
what is this for...
thanks,
space
the spacecowboy is offline
Old 02-13-2001, 10:28 AM   #2
efoo
Member#: 80
Post
don't hook them up. it makes your car act wierd and you'll be running around for days wondering what the heck happened to your car. trust me, i know.
some have speculated that they are connected to force the ECU into running in some special mode while the cars are being transported off the ships and onto trucks and stuff, but no one knows for sure.
-Edwin
efoo is offline
Old 02-13-2001, 10:34 AM   #3
donjuan
Member#: 2248
2012 C63
2012 Silverado HD
Post
A stereo shop plugged them together on a friend's RS when they installed his alarm. He got a CE light and his car wouldn't go above 3K rpm until he did an ECU reset.
donjuan is offline
Old 02-13-2001, 10:59 AM   #4
ScoobyRoo
Member#: 2167
Post
A sneeky hunch tells me to ask a mechanic, he probably knows.
ScoobyRoo is offline
Old 02-13-2001, 01:59 PM   #5
Ian Cook
Member#: 1228
1993 Group N Impreza
White (Mostly) ;)
Post
Hehehehehehe
On the UK cars, there are 2 black plugs and 2 green plugs under the steering column/dashboard, i suspect from reading some of the posts that you have the same on the later cars !
They are used for diagnostics, if you get a check engine light come on, you can plug them together, swithc the ignition on, and count the flashes on the immobiliser light and this gives you the error code, of course if you have a subaru select monitor this is pointless as they plug in and tell you all this plainly
Another usefull little use for these is you can reset the ECU's error codes by pluggin both sets together, cant remember the exact procedure for this, its been a while !
As someone else mentioned, do NOT leave them plugged together as it puts the ECU into get you home/to the dealer mode cos it thinks theres a serious problem somewhere
Hope this helps, oh and BTW this method means you dont have to reset any codes in your car stereo, and the best method to reset the error codes, is to use the Subaru Select monitor to do it, cos you plug it in and say reset, and its done LOL
Ian Cook is offline
Old 02-13-2001, 02:06 PM   #6
timatwood
Member#: 2920
Post
When I plugged them together my check engine light came on and flashed repeatedly. It seemed to be a pattern. Does it dump fault codes from the ECU (like an audi)? I unplugged them and the car ran fine without any reset.
timatwood is offline
Old 02-13-2001, 02:17 PM   #7
Ian Cook
Member#: 1228
White (Mostly) ;)
Post
CE light flashing repeatedly is normal when the connectors are plugged together !
Our cars use the immobiliser light to flash the error codes, i dont even know if you have the immobiliser light in yours, i never looked while i was over D'OH!!!!
Ian Cook is offline
Old 02-14-2001, 12:49 AM   #8
Fred Fredburger
Member#: 2539
2005 STi WRB/Gold
Now w/Íhlins... Yessss!!!
Post
Cowboy> check out these two posts...
Which ECU reset is better?
Can't find one ECU Check Connector...
If anyone can help me find the last ECU Check connector I would be terribly grateful.
Thanks!
Geoff
Fred Fredburger is offline
HTML code is On
06 wrx green plug under dash? hookedontronics Interior & Exterior Modification 3 07-20-2009 11:06 AM
two green mystery plugs under dash yeos Electrical & Lighting 10 09-23-2008 09:50 PM
Green plug under dash? snapperswrx Electrical & Lighting 2 08-06-2007 02:10 AM
3 plugs under dash? dubRexn Newbies & FAQs 1 06-27-2002 12:08 PM
