Old 10-02-2003, 11:42 AM   #1
Ricter
Member#: 18619
'05 WRX Wagon
World Rally Blue
Default Proper Tire sizes...
I have a 2000 legacy GT Sedan... with stock suspension.
I'm looking at a set of 17"x7" wheels withw offset of 48.
The vendor in question recommends 215/50/17 wheels for my car. Is that the best fitment?
It seems that 225/45/17 would have a closer diameter size to stock then what the vendor is recommending, but might end up being to wide with a section width of 8.9 as opposed the stock 8.1.
Should I go with the vendors recomendation, or is 225/45/17 safe on my car?
Thanks,
Ricter
Ricter is offline   Reply With Quote
Old 10-02-2003, 01:08 PM   #2
AGscooby
Member#: 4242
1999 BD SUS GRN/GLD
gimme Legacy TPH wagon!
Arrow
I was under the impression that BE's have quite a bit of wheel well to work with, and I'm sure there are plenty of people running 225/45-17s, even with lowering springs. The only reason to go with 215/50s would be lower tire cost and taller gearing for lower-rpm cruising. Unfortunately, there also isn't that great a tire selection in that size. I've checked since it's closer to the 99 OE Outback size than the GT size. I'd say go with the 225 unless you can't float the extra money.
FWIW, the vendor is probably recommending 215s because of the 7" wheel width. I've seen the 225/45s fit on 17x7s before though without issue. There are some WRX's running 225/45 on the UK 17x7s, and they look good. Nice vertical sidewalls.
AG
Driven by guts inside!
AGscooby is offline   Reply With Quote
Old 10-02-2003, 01:15 PM   #3
Ricter
Member#: 18619
'05 WRX Wagon
World Rally Blue
Thanks alot.. I was leaning towards the 225's anyway, I just wanted to be sure they wouldnt end being a bit too wide and causing rubbing problems.
Thanks,
-Ricter
Old 10-02-2003, 01:28 PM   #4
AGscooby
Member#: 4242
1999 BD SUS GRN/GLD
Lightbulb
Before you finalize the transaction, if the vendor is local, see if you can test fit one wheel with a tire mounted on each location to check for rubbing, just in case. There really shouldn't be a problem unless you get an unusually thick tire in a 225. They vary sometimes. Have fun!
AG
Old 10-02-2003, 01:42 PM   #5
tora
Member#: 5851
09 Forester XT
+ NA Miata
Providing you have the right offset for the wheels 225's are no problem. I'm going to 245's on my car for next summer.
tora is offline   Reply With Quote
Old 10-02-2003, 02:54 PM   #6
aross
Member#: 831
11 Blurple WRX
03 BH MBP
I am running the 225/45/17 on my BH wagon with no issues - except at full lock on steering..
Wheels are Factory Subaru GTB Rims
You should be good to go.
aross is offline   Reply With Quote
Sprint Hart wheels.... need proper tire size??? 1993wrxBOI Tire & Wheel 8 10-08-2009 10:19 PM
Just bought JDM STI wheels... proper tire size? txl146 Tire & Wheel 5 07-22-2007 02:49 PM
Proper tire size? VetteVert Tire & Wheel 3 08-07-2003 08:42 PM
17x7 OZ P1, anyone knows the proper tire choice & size? TIA bensonwrx Brakes, Steering & Suspension 12 05-31-2001 02:14 AM
Proper tire size for 15" rims... STiShawn Brakes, Steering & Suspension 16 12-15-2000 11:47 AM
