Old 10-03-2003, 11:18 AM   #1
impRSa
Member#: 6521
Question Heater - no heat
Hi, my friend's '91 Legacy's heater works (the fan blows air) but he's not getting any hot air? Any ideas. Thanks in advance.
impRSa is offline   Reply With Quote
Old 10-03-2003, 11:48 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If the mode switch in the HVAC unit is working properly and the air is coming out of the heater vents like it's supposed to but just isn't hot, it's possible the heater core is clogged or the thermostat isn't working properly. Does the temp gauge read normal, or lower than normal?
Old 10-03-2003, 12:04 PM   #3
impRSa
Member#: 6521
The temp gauge is lower than normal, actually doesn't climb much at all.
Old 10-03-2003, 12:06 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Then it sounds like a classic case of a thermostat that is stuck open. Replace the thermostat and both problems should be solved.
Old 10-03-2003, 12:08 PM   #5
impRSa
Member#: 6521
Thanks mulder - will tell him.
Old 10-03-2003, 01:14 PM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
definitely needs a thermostat, they are built to stick open, not closed. most people don't even notice till the winter when it's time for the heat to come back on.
Jeremy
So we have no heat... Any temporary heating solutions better than Kero heaters? AcquaCow Off-Topic 104 02-16-2010 06:19 PM
heater no worky (?) help nuhga Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-22-2005 07:39 PM
No heat when idling, heater core? elhalisf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 01-19-2005 02:24 PM
NO HEAT AT WORK: grounds for leaving early? touch New England Impreza Club Forum -- NESIC 29 12-03-2002 11:26 PM
No heat at idle, only when moving, and long warm up period? Need4Boost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 12-01-2002 12:01 PM
