Welcome to the North American Subaru Impreza Owners Club Wednesday April 1, 2015
Old 10-03-2003, 03:59 PM   #1
Radio Flyer
Member#: 374
'98 2.5 GT Wagon
Rio Red
Default Help me w/ fuel economy / sanity
I'm seeing 23 mpg fuel economy in my mostly freeway commute. This compared to 30+ mpg for the same commute in my '90 Integra. Driving the same quasi-aggressive style.
I expected slightly worse mileage, say 26-27, but 23 has me re-thinking the whole "I'll sell the Acura and keep my beloved Subie" thing.
I've got 47K miles on the car, and the only not-from-the-factory items in there are a fuel filter (~15K on it) and an AMSoil air filter (cleaned <1K ago). Well, there is the removed snorkus too, but I don't think that matters much.
Any suggestions? Recommendations? Help me, as I'm seriously thinking of selling the Radio Flyer and buying a 4-dr 5-spd Integra GS-R.
TIA,
&nbsp;&nbsp;- Eric
&nbsp;&nbsp;&nbsp;&nbsp;Lil' Red '98 2.5 GT Wagon - Pics
Radio Flyer is offline   Reply With Quote
Old 10-03-2003, 05:25 PM   #2
Jarvis
Member#: 8267
2010 MB E63
Black on Silver
What were the stated fuel economy #'s for that year?
Jim
Jarvis is offline   Reply With Quote
Old 10-03-2003, 06:08 PM   #3
richeich
Member#: 1353
2001 Impreza 2.5RS
Hey Eric, that's about what I get with mine. I have a 17 mile commute, with 1 mile of city streets at each end, and 15 miles of highway in-between. The highest I've ever gotten was just under 29mpg on a road trip. I'm not so sure there's a whole lot left there for you, mileage-wise.
Rich
richeich is offline   Reply With Quote
Old 10-03-2003, 06:48 PM   #4
Paul H
Member#: 21842
2004 WRX Wagon
Black with Dents
I find with my 2001 GT that varying the my driving "style" gives me the worst gas mileage. If I driver like granny I get 30 city, drive agressive I get 25, start doing a little of both 23. Might be the ECU trying to adjust to the driving.
Paul H
Paul H is offline   Reply With Quote
Old 10-03-2003, 11:41 PM   #5
biggreen96
Member#: 12535
vf39 93 Legacy Wagon
92 Legacy Rally EG33'd
Yeah your honda was a 1.6 liter gas sipping lighter wieght car, you drive a 2.5 liter few hundred lb more sedan. theres not much you can do.
biggreen96 is offline   Reply With Quote
Old 10-04-2003, 10:36 AM   #6
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Get a Tornado.
IronMonkeyL255 is offline   Reply With Quote
Old 10-04-2003, 07:37 PM   #7
biggreen96
Member#: 12535
Originally posted by IronMonkeyL255
Get a Tornado.
sorry I had to.
Old 10-05-2003, 01:50 AM   #8
Radio Flyer
Member#: 374
'98 2.5 GT Wagon
Rio Red
Thumbs up Thanks, all.
A Tornado....
I just realized another issue here that could make some change in mileage... In Hotlanta, I was near sea level. Here in Albuquirky, I'm a mile high... Hmm... No. Stochiometric ratio....
Never mind. I'll likely just replace everything: tranny oil, diff oil, fuel filter, spark plugs, etc. See what becomes of it.
Should I replace the plug wires?
By the way, I always keep my tires at 35f 32r, so I doubt there's any problem there. Also, over 47K miles, they've worn evenly, so no hint of alignment problem either.
Thanks, all!
&nbsp;&nbsp;- Eric
Old 10-05-2003, 01:42 PM   #9
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Tire pressure could help, even though they wear evenly they could still be a bit low. Also, I have a 98 gt wagon with 100k miles and a big, packline fiberglass roof box on top and with only highway/freeway driving I will get at least 25mpg. If you do some searching you will find that those that have done the snorkusectomy acual found that gas mileage went down. So, with the snorkus issue and the tire pressure you might have your fix, although if I recall correctly the snorkus is kind of a permanent deal. Oh, and my only changes are a K&N drop in panel, Magnecor plug wires and NGK copper plugs.
I run my tires around 38psi.
for what its worth....
Jared
gtwagon941 is offline   Reply With Quote
Old 10-06-2003, 08:58 AM   #10
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
Your tire pressure is way to low.
HIHO is offline   Reply With Quote
Old 10-06-2003, 12:17 PM   #11
Radio Flyer
Member#: 374
'98 2.5 GT Wagon
Rio Red
Pray tell, HIHO, what would you then recommend the pressures be set to for street?
Sticker in the door recommends 30 all the way around (or is it 32?). I had been running 38f 34r for a couple years, but when looking at the tires, the centers are more worn than the edges, so I backed the pressures down a bit.
&nbsp;&nbsp;- Eric
Old 10-06-2003, 05:58 PM   #12
HIHO
Member#: 7624
BD5; family sedan
Well Radio Flyer what the hell does that have to do with the tires that are on your car now? Most people go by the tires specs not whats printed on the door jam. You should run 36-40 psi in most tires bought these days. I run 38 all around and haven't seen any uneven tread wear.
Old 10-06-2003, 08:16 PM   #13
subefriek
Member#: 11214
2001 legacy Gt
titanium
Default Gas milage
Radio Flyer, gas milage is a subjective thing, (1) you cannot compare gas milage between your Integra and your Subie this is not even apples and oranges, you have to factor in weight difference, this is the biggest difference it is no accident that car makers spend literally millions of dollars trying to shave just a few pounds off of cars just to increase gas milage.
(2) your Subie has all wheel drive which your Integra does not, plus your Integra is a lightweight compared again to the Subie, and lastly if you got a hundred legacy drivers together their gas milage would be all over the map I would be really surprised if any two drivers got the same gas milage.
To close after having owned Honda's for many years before buying my GT, if I was up to my ass in snow I know what car I would want to own regardless of gas milage.
(clue) it would not be a Honda.
Pat
subefriek is offline   Reply With Quote
Old 10-07-2003, 01:27 PM   #14
Radio Flyer
Member#: 374
'98 2.5 GT Wagon
Rio Red
Thanks for your help, gang. Like I said above, I'll go in and change the fluids and spark plugs. I'm simply not convinced that I should be getting 23 mpg with a daily 20 miles of open freeway commute. I remember doing better than that (25-27) in Atlanta. (Bear in mind that four years ago, I handed the keys over to my wife so she could use the wagon to haul our kids around; and she handed me the keys to the Integra. We just got a minivan, and sold the Acura, so at long last the Subie is all mine again. My memory of mileage past could be warped, but it seems reasonable to expect 25 mpg or better like I remember getting in Atlanta)
I'm driving to Las Vegas next weekend, and will report on what I get as all highway mileage.
&nbsp;&nbsp;- Eric
HIHO - I'm not trying to start a flame-war here. Your original message was simply not very helpful at all.
What does it have to do with the tires that are on my car now? I am still running the original equipment RE92s.
They are only now getting near the wear bars. I just ordered some Hankook Ventus K102s yesterday, in fact. They'll be on the car by the end of the week.
Tree needs to help the economy, help me find a TV The Tree Off-Topic 44 03-04-2009 10:17 AM
Sanity Check.....Help me out! YourMother'sLover Texas Impreza Club Forum -- TXIC 18 11-28-2007 01:39 AM
Looking for fuel economy help Radio Flyer Normally Aspirated Powertrain 7 10-05-2003 01:25 AM
I think my fuel guage is messed up...or fuel economy GooseMan Service & Maintenance 6 05-02-2003 03:52 PM
Help me out, Fuel Persure Defi gauge. WRBLUEWAGON Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-24-2002 02:32 PM
