Old 05-23-2003, 09:22 PM   #1
Mildmanneredman
Member#: 29962
Default Lotek gauge pod
I wasn't sure if this is the right forum, so if I'm in the wrong place please let me know. I had 3 gauges installed in a lotek pillar gauge pod and the guy who installed them put the gauge pod on top of the existing pillar cover. He said that was what the instructions said. He did show me how it doesn't fit correctly in some places. I though it was supposed to replace the existing cover. Does anybody know?
Mildmanneredman is offline   Reply With Quote
Old 05-24-2003, 08:44 AM   #2
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
AFAIK they only make pillar replacements. I have the two pod LoTek unit, and it sure was a replacement unit. http://www.gaugepods.com is their site, might be able to get more info there.
Paul
Snowphun is offline   Reply With Quote
Old 05-26-2003, 02:14 PM   #3
jjunior887
Member#: 16738
2015 WRX Limited
CWP
Yeah it's a replacement not a cover. I've had two of them, one was a 2 pod 52mm and the current one is a 3 pod 60mm. Neither of them fit perfectly and it kind of messes with the rubber that runs along it in some places. It's mainly just looks though, it doesn't cause any air leaks or anything that i've noticed.-James
jjunior887 is offline   Reply With Quote
Old 07-02-2003, 12:59 AM   #4
xylem007
Member#: 25179
2002 Impreza WRX
Default Dremelling?
Did anyone else have to dremel around the 60mm openings to get 60mm defi gauges to fit? I can't see why they didn't drop in..
xylem007 is offline   Reply With Quote
Old 10-04-2003, 07:41 PM   #5
mosfet
Member#: 35921
2003 WRX
Always Bet On Black
So, what did you screw it into? Mine came with 2 screws in it and there's really nothing to screw them into... I'm getting tired of it coming loose and having to push it back in place.
mosfet is offline   Reply With Quote
Old 10-04-2003, 08:29 PM   #6
jjunior887
Member#: 16738
2015 WRX Limited
CWP
You have to drill holes, I'm pretty sure it said that in the instructions. And Yes you have to dremmel it a bit for the 60mm to fit but it really isn't that bad if you take your time. -James
Old 10-04-2003, 09:34 PM   #7
mosfet
Member#: 35921
2003 WRX
Always Bet On Black
Drill holes into the metal? I didn't get instructions, btw...
Old 10-04-2003, 10:24 PM   #8
jjunior887
Member#: 16738
2015 WRX Limited
CWP
Oh well I got mine a year or so ago and I'm pretty sure it came with them then. Anyway I just drilled a hole in the metal for the top one since the bottom one was a PITA with the drill I had. It seems to hold up fine. Just use a bit that's a bit smaller than the screw and you should be okay, they're self tapping screws so it won't be too bad. -James
Old 10-04-2003, 11:00 PM   #9
FryRice
Member#: 38402
2004 WRX~vf34 SOLD
EVO MR
Default Re: Dremelling?
i did and made them fit but there are gaps where the gauge meet the pod all around! U-G-L-Y........
So i end up carving words on the pod with the dremel HAHHAAHA LOTEK = LOW TECH worth less piece of crap i have ever spend!
FryRice is offline   Reply With Quote
Old 10-05-2003, 10:08 AM   #10
jjunior887
Member#: 16738
2015 WRX Limited
CWP
I didn't have too much of a problem with mine
Lotek Gauge Pod Token-Negro North West Impreza Club Forum -- NWIC 4 09-06-2005 01:58 AM
Lotek Gauge Pod lukek Private 'For Sale' Classifieds 7 01-05-2005 02:14 AM
*BRAND NEW* Lotek Gauge Pod bluerex1564 Private 'For Sale' Classifieds 3 12-10-2004 06:08 PM
Lotek Gauge Pods Strictly Driven Vendor 'For Sale' Classifieds 15 02-24-2004 10:33 PM
Lotek gauge pod Mildmanneredman Interior & Exterior Modification 4 05-25-2003 10:53 AM
