Old 10-04-2003, 06:47 PM   #1
il96
Gone... But not forgotten
Member#: 13082
Default Timing belt change interval 60k or 100k ?
I have just replaced my timing belt with 64k on the car. I replaced the 2 drive belts along with it. When I removed the old timing belt it was in VERY good shape. It had no cracks, wasn't visibly stretched, and had all the teeth in place. Prior to replacing it I asked service guys @ subaru dealerships and some said 60k , others said 100k. Since it's an interferance engine, I decided not to wait till 100k and change it @ 64k. Now I'm thinking it was probably not necessary.
Have you already replaced your TB, if so how many miles were on the first one ?
Oh yeah, I did everything myself, and I didn't have crankshaft pulley wrench, but after some search on the internet I found a smart tip to remove the crank shaft pulley bolt. Put a piece of pipe on the wrench and lean it agains the metal inside the car. Then go crank the engine with the starter so it makes 1/2 a turn or less.
il96 is offline   Reply With Quote
Old 10-04-2003, 09:59 PM   #2
Cujo31
Member#: 19843
2000 2.5 RS Sedan
Silverthorn Mettalic
Holy Crap! I know there's no way that would work for me. I see visions of my engine torquing itself out of the engine bay and flying through my garage wall....
Cujo31 is offline   Reply With Quote
Old 10-05-2003, 04:15 AM   #3
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
That is how I removed the pulley on my 4EAT RS. I think in the owners manual it says to check the timing belt at 60k for wear and replace if needed, but it should definitely be replaced at 100k.
-Wes
RebelINS is offline   Reply With Quote
Old 10-05-2003, 11:40 AM   #4
il96
Member#: 13082
Dude, don't worry, all you do is turn the key and immediately turn it off. The engine will only turn 3/4 or so.
It's a lot safer than it seems.
Old 10-06-2003, 07:28 AM   #5
spshultz
Member#: 1415
2008 IS350
'13 SantaFe
I removed the bolt in my 4EAT the exact same way. But i placed the wrench on the ground and half a turn later it was off. No biggy. It's getting it back on that was a real pain in the rear.
I replaced mine somewhere between 101k - 106k I don't remember which but it was in really good condition. Will I wait that long again? Probably not.
spshultz is offline   Reply With Quote
Old 10-06-2003, 09:46 AM   #6
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
my 2000 rs is up to 95k miles. GOIng to chane it soon
moogoob is offline   Reply With Quote
Old 10-06-2003, 11:25 AM   #7
C-daleRidr
Member#: 18074
2008 Speed3
I think my owner's manual says 110,000, but I could be wrong. I remember it not being at any of the 30000 mile tune ups.
C-daleRidr is offline   Reply With Quote
Old 10-06-2003, 03:51 PM   #8
Julian
Member#: 1182
MY00 RS
BRP
The Maintenance Schedule says 105K miles for replacement.
Julian is offline   Reply With Quote
changing the timing belt, change bearings or whole idler wheels/pulleys? NicEJ25 Service & Maintenance 15 12-28-2010 06:46 PM
Timing belt change at 60k due to Texas (Austin) heat? erichollins Texas Impreza Club Forum -- TXIC 20 01-08-2007 01:01 PM
Timing belt change at 60k due to Texas heat? erichollins Legacy Forum 19 01-05-2007 08:44 PM
EJ22 has shorter timing belt change interval? pieces Service & Maintenance 3 04-15-2005 03:02 PM
Need advice: '02 Timing belt: 60k or 100k? strohausii New England Impreza Club Forum -- NESIC 9 10-17-2004 10:46 PM
