Old 10-04-2003, 07:51 PM   #1
sovereignmk1
Member#: 11858
1998 Silver Legacy
Default Replacing O2 sensors....
1) Anyone have good pics of this install?
2) Should I stay OEM or like NAPA brand, etc....
3) Best place to get'em at
//Mark
That's all for now I think
sovereignmk1 is offline   Reply With Quote
Old 10-04-2003, 10:23 PM   #2
NiTRoN
Member#: 30556
2000 Legacy GT (BE)
over 250,000 Miles
My 00 BE has 2 oxy's one before cat-conv and one after 2nd one.. I couldn't get them anywhere but dealer (Bosch brand).. rear one for some reason was more expensive.. you will need some extention on your wrench to loosen it up.. I don't know on your model if you have 1 or 2 sensors.... Just make sure you unplug the cable at the connector before you try to loosen it up.. also.. don't plug cable before you screw it in.... Overall isn't that hard... If the sensor threads don't have any grease on it.. buy high temperature antiseize greese and put some on the threads.. Took about 30min per sensor to replace.. Good luck
NiTRoN is offline   Reply With Quote
Old 10-04-2003, 11:30 PM   #3
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
I did my front one recently--bought a Bosch sensor at Autozone. They also loaned me a special socket tool that fits over the wire. My biggest problem was that the old sensor was stuck--I had to soak it overnight in PB Blaster.
Mike Wevrick is offline   Reply With Quote
Old 10-05-2003, 01:38 AM   #4
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Legacy777 is offline   Reply With Quote
Old 10-05-2003, 09:29 PM   #5
sovereignmk1
Member#: 11858
1998 Silver Legacy
Thanks!
//M
ej20g replacement o2 sensor what usdm part replaces it GregBolby Pre-2002 Factory Turbo Powertrain 16 03-28-2010 01:39 PM
CEL CODE, dealer replaced O2 Sensor... dhdsman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 01-08-2007 05:45 PM
replacing O2 sensor kodakeos Normally Aspirated Powertrain 4 10-22-2004 06:14 PM
Best place to get a replacement O2 sensor? TreyS Service & Maintenance 4 09-28-2004 11:55 PM
Must dealer replace O2 sensor? dingo dave Service & Maintenance 8 02-28-2003 12:48 AM
