Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC
Notices
Old 10-04-2003, 10:07 PM   #1
STEALTH-WRX
Member#: 7822
Multi layer snot green
Default Need some help locally with my car. Can anyone help. ECU related
I am having trouble starting my car. It was fine two days ago but i cannot get it to start at all. Can anyone help me out locally. I may have missed something or am not aware. Its pretty frustrating. Thanks
STEALTH-WRX is offline   Reply With Quote
Old 10-04-2003, 11:10 PM   #2
WRXzard
Member#: 14855
Its hard to point you in any direction with out more information.
Did it just cut off or did you leave it over night and it just didnt start the next morning ?
From what I saw on your posts you are using the stock ECU to fire it up the first time. Its hard to say if its a electrical problem or if its a mechanical problem. You need to look for clues. Also be careful in that your running 800cc injectors and if you have been testing it out with the stock ECU it would be running super rich.
Here is what I would look at first.
Check fuses if blown.
Check ECU wiring (slow burnout meaning ran for a few days and stopped could be a fried wire of weak connection.
Check the oil. Just to see of there are any engine issues (coolant
in oil which would point to head or gasket problem.)
Check plug if fouled from injectors.
Check inner cooler setup. (exchanger setup) small leak
Check MAF or MAP sensor setup.
Look at these as starting points. Its hard to call the best starting point. If the above doesnt get you any where. I would use the manual to my advantage. Get a Manual and look at the trouble shooting section and work your way down the list. I know you have a lot of mods but just use it as a reference to guide you through.
WRXzard
WRXzard is offline   Reply With Quote
Old 10-05-2003, 01:10 AM   #3
STEALTH-WRX
Member#: 7822
So far there is no fues blow, no head gasket problem, the intercooler is not hook up at the moment, and there is no maf sensor. It should be fine. I am thinking the plugs are covered in gas. I just got two more sets so i am going to try that first thing in the morning.
Old 10-05-2003, 01:32 AM   #4
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
How far away are you to san diego. I would love to help and share notes. I can help trouble shoot mechanical or wiring. Would you buy me lunch to drive up there?
AWJunkies is offline   Reply With Quote
Old 10-05-2003, 01:47 AM   #5
STEALTH-WRX
Member#: 7822
Hmm i dont know how far exactly. If you would like to come up ill buy lunch. I dont have much money but if its under $10.00, sure.
pm me.
Old 10-05-2003, 02:01 PM   #6
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
Have you checked the obvious things first?
Are you getting Spark and is the Fuel pump working. Are the injectors firing (check with ohm meter).
If you are getting the basics, maybe the timing is off 180*?
When is cranks, does the cranking speed speed up or slow down rapidly?
mattjk is offline   Reply With Quote
Old 10-05-2003, 02:03 PM   #7
mlambert
Member#: 13831
Nick I'll come over and toss ideas off you, if you'll let me
mlambert is offline   Reply With Quote
Old 10-05-2003, 02:03 PM   #8
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
Originally posted by mlambert
Nick I'll come over and toss your salad, if you'll let me
sw00n!!!
Old 10-05-2003, 02:08 PM   #9
mlambert
Member#: 13831
stop decoding my secret messages Mr. JK
Old 10-05-2003, 02:22 PM   #10
STEALTH-WRX
Member#: 7822
cool. i will be working on it at 1:00. cruise on over. plus we can start with the autronic and hone our tuning skills that dont exist yet.
Old 10-05-2003, 02:26 PM   #11
G-force
Member#: 14104
UBER ILikeItLongAndH
ardDeepandSmoothEverSoCoo
i wish i had the ultra-cool mlamby infrared laser chromatic bifocal SCIC love-sick decoder glasses...
G-force is offline   Reply With Quote
Old 10-05-2003, 03:32 PM   #12
WRXzard
Member#: 14855
If you think or see that there may bee an issues with gas on the plugs that could be ring washout. Depending on what you mean by gas. It could be carbon build up or if it is ring washout. Sometimes the gas washes the oil seal from around the rings or worse and causes a compression loss. If you see serious carbon build up then you need to flush/clean it out.
Its really hard to say so many directions to go.
WRXzard
Old 10-05-2003, 03:39 PM   #13
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
just plug the stock ecu in and rev it out slowly until the black smoke disapears, then try again.
Old 10-05-2003, 04:03 PM   #14
mlambert
Member#: 13831
nick if you read this, ill be over after that A's game. Sox just pulled ahead, good game
Old 10-05-2003, 11:03 PM   #15
STEALTH-WRX
Member#: 7822
I just drove the car up and down my street. Mlambert was sitting in the back seat. I am running it with the stock ecu and i dont know how its even running but it is working out okay without the maf sensor. The fuel pressure is a little low to help with the big injectors. Let me say that this car is very very fast. Its set at 12 psi and the water was not pumping through the intercooler at the time. I didnt go over 4500 rpm and this thing pulls harder then my car ever has. I am having complications with my autronic but that will be dealt with this week. Once this thing is dialed in it will be fun.
Old 10-06-2003, 09:09 AM   #16
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Cool beans... what kid of boost did you see and when did it start to spooll?
I bet is sounded bad ass.
I made it from La jolla in like an hour 20... going a "sane" speed.
I need a logo designed for Evail Motorsports can anyone help?? mrtrex Off-Topic 0 10-14-2005 02:16 PM
Need box to ship my hood. Can anyone help me out STEALTH-WRX Southern California Impreza Club Forum -- SCIC 4 04-11-2004 05:51 AM
can anybody help me with my car godfather2112 Rocky Mountains Impreza Club Forum -- RMIC 0 03-29-2004 01:46 AM
I need to borrow two stock wrx wheels, can anyone help? maaw Bay Area Impreza Club Forum -- BAIC 4 12-28-2003 03:00 PM
('93-'01) I need a new carpet for my car, can someone help me? The Wraith Impreza Forum 3 06-08-2001 12:52 AM
