#1 |
Member#: 6772
Vehicle:03 WRB WRX Cobb Stage 2 |
I don't understand. Another WRX was completely stock and ran a 15.02. And he had an excellent launch. Is there something wrong with my times? Or is my car screwed up?
First Run 60....2.513 330....6.757 1/8....10.170 MPH....72.46 1000....13.070 1/4....15.537 MPH....90.99 Second Run 60....2.170 330....2.490 1/8....9.600 MPH....72.79 1000....12.519 1/4....15.020 MPH....90.63 My car is totally stock aside from the UTEC being tuned for max 16 PSI.
#2 |
Member#: 36318
NWIC
Vehicle:2002 wrx sold :( |
your trap speed seems kinda low. Dont stockers trap around 93mph? Even if u had a 1.8 s 60' the best u can do is probably 14.5-14.6. That dont seem right.. I assume u are not at sealevel and the weather is really bad. Is that correct?
#3 |
Member#: 8179
you just need some practice behind the wheel judging from your 60' times...the trap isn't that far off from what it should be.
#4 |
Member#: 13890
TXIC
Vehicle:2007 Mazda CX 7 Icy Blew |
well i must say that ur prolly the first person i know who got a UTEC as there first mod. with that money u spent for the UTEC u could of had an up pipe, DP, mbc, and a cat back.
is ur UTEC tuned? wt reductions? full tank of gas? also ur 60ft times are terrible. well the 1st one is anyways. if u can get those times to 1.8; 1.9 ur 1/4 times would be way better. also ur shifting is important and make sure u go thru the trap in 4th gear. keep practicing and keep modding. u will get there. |
#5 |
Member#: 6772
My UTEC isn't tuned. No weight reduction. My tank was at 3/4. It was very humid.
Shouldn't my MPH be way higher than 90-91? |
#6 | |
Member#: 22554
South East
Vehicle:2007 Corolla no PW! WHITE miss my WRX :( |
and you 60' times are very bad they should be the best 1.8xx to 1.9xx-2.0xx |
#7 |
Member#: 23676
NESIC
Vehicle:. |
yeah man its your launch. 2+ 60" times are miserable.
<<been there done that |
#8 |
Member#: 16771
Vehicle:12.9 @ 102MPH 1.784 - Stock Turbo |
god damn, its so annoying...
why must every single person on this board complain about their horrible times, when its ALWAYS the 60'... ALWAYS!!!!! this is last time, i swear... 1. pulse revs 4-6k 2. slip/drop clutch as fast as possible w/out lettin the clutch go bak on its own weight 3. no more complaining ![]() |
#9 | |
Member#: 13890
TXIC
again get that UTEC tuned even tho u have a stock car, u really dont need the UTEC anyways ![]() |
#10 |
Member#: 2389
Vehicle:'98 Impreza L Wagon '90 Talon TSi AWD |
How can you guys say that a UTEC is worthless on a stock car? Granted, it's a LOT more expensive than a MBC, but the TurboXS stage 1 (UTEC alone) is advertised at 275hp. This is probably optimistic, but let's say 260hp. Cobb advertises their stage 1 reflash (for a stock car) at 255/260hp, depending on which octane map you go with. It's around 30hp more than stock, and the car is tuned to handle higher boost properly.
#11 |
Member#: 13890
TXIC
he said his UTEC was untuned
#12 |
Member#: 33370
Vehicle:2002 Impreza WRX Blue now w/ 6 fun flavors |
any chance this car had a slush box?
I also see a high degree of driver error + inexperience + not knowing how to tune the UTEC or not having someone else tune it... this equals times more than 1sec slower than a good driver in a stock car. |
#13 |
Member#: 2389
I know he said it was untuned. In that case, it is useless.
I was saying that it's not useless to have one on a stock car, since you can raise boost and control fuel and timing with it to get more power out of a 100% stock engine. |
#14 |
Member#: 35081
NESIC
Vehicle:2012 WRX WRB |
Good point ^ could be an Auto!
#15 |
Member#: 16856
NESIC
Vehicle:"I work until BEER O clock" Stephen King |
Is you car actually running 16psi of boost? Do you have a boost gauge? If so you should be trapping at a higher mph even with bad driving.
Jim |
#16 |
Member#: 6772
The car isn't an auto, I don't have a boost gauge but measure it in the UTEC. I'm going to tune the UTEC from scratch today. It came preloaded with a tuners map but I guess it's not working for me.
jimgldn, I thought the same thing. Shouldn't my MPH be way higher than that? |
#17 |
Member#: 9090
Vehicle:09 Forester Gump 02WRX->04STi->09Gump |
Your mph should be higher, but your down in FL so keep that in mind.
My car was about .5 and 5mph slower at Moroso raceway in FL as opposed to New England Dragway in NH. I ran 14.0@93 iirc and when I got home the car went back to running 13.5 at a best of 98mph without changing anything. That was with an MBC, and a K&N filter Mind you i drove 43 hours (19hrs down and 23hrs back home, btw thats 1475 miles each way if you want to do the math) with the MBC on the whole time. Never skipped a beat. But still I wouldnt be all too happy. The car should run those times stock. Did you call Turbo XS? ~v6 Last edited by V6TurboTA; 10-06-2003 at 06:55 PM. |
#18 | |
Member#: 16856
NESIC
Jim |
#19 |
Member#: 33458
Vehicle:Your BOV sounds lame 93 RX7+09 Forester |
Even an untuned stage1 should be good for 13s. I ran 14.1 stock so the extra power should, as i said, be capable of 13sec times.
#20 | |
Member#: 9794
TXIC
Vehicle:02 2.5LWRX-Retired 335i w/twins |
Serisouly though, Unichips/UTEC, etc don't fare well as first mods. They usually run the same times as a mbc only car (which is still 13.7-8@97 with a 1.8 60'). I'd work on the launch first, then go from there. |
#21 | |
Member#: 16771
#22 |
Member#: 9090
I actually HAVE a unicycle
![]() ~v6 |
#23 | |
Member#: 16771
but lets see.. 3ft = 1yrd... i ran the 50yrd dash in like 7-8sec... so thats 150ft... hhhhmmm... i figure i can run 60ft in like 3sec... which is PRETTY close to you 60', which means im FAST! ..................wow i have a lot of free time |
#24 | |
Member#: 9794
TXIC
X10 |
#25 |
Member#: 6772
OK, I get the idea.
But you really think my 60ft times are going to make that big a difference? A full sec. in the 1/4? Seems a little much for me? By the way, I cut a 2.17 60 ft. (still really crappy, I know) on my second run and my MPH was still low. |
| Thread Tools | |
| Display Modes | |
| Not too happy with my ATP 35R | Simes | Built Motor Discussion | 8 | 04-23-2010 05:20 PM |
| Not real happy with my P Zero Neros | zzzzzxx | Tire & Wheel | 11 | 08-03-2006 10:15 AM |
| timing + or - to get the best spoolup with my Utec? | SleeperWRX | Engine Management & Tuning | 2 | 01-20-2004 10:28 AM |
| Is anybody not happy with the UTEC? | 2000vfr800 | Engine Management & Tuning | 29 | 10-04-2002 09:33 AM |
| ('93-'01) i'm not to happy with my car right now | juggalo | Impreza Forum | 16 | 03-14-2002 10:24 PM |
