Old 10-05-2003, 05:02 PM   #1
wrxpa
Member#: 24369
Default Omori EGT gauge wiring
OK, I have wired up my gauges, but the elec. egt gauge has a brown wire with it that I can't figure out is needed for. There isn't anything in the instructions about this brown wire either, any guesses?...
wrxpa is offline   Reply With Quote
Old 10-05-2003, 05:34 PM   #2
Charged Performance
Vendor
Member#: 40645
It is not used. Omori electric gauges use a standard 5 pin power wire - red, white, 2 black, brown on all electric gauges - no Omori that I am familar with use the brown wire and the 2 black are connected internally.
Charged Performance is offline   Reply With Quote
Old 10-09-2003, 10:38 PM   #3
Dick Fitzwell
Member#: 25684
iirc, the harness or wiring for the omoris are all the same for all gauges. the brown wire is meant for the 60mm gauges that have the peak/hold/warning feature. the brown wire can be used to light up an external led.
Dick Fitzwell is offline   Reply With Quote
Old 10-09-2003, 11:20 PM   #4
Charged Performance
Vendor
Member#: 40645
Ah, that is right it is an ground output - none of my installations have used it. Omori just uses the same harness on all electric meters whether they are needed or not. However for instance mech boost gauges just have a black and white for the lighting - no harness.
Ed.
FS: Autometer Gauge Bezel / Omori Boost Gauge / Omori EGT Gauge RChampion Interior/Dressup/Audio & Security 28 10-06-2007 04:23 PM
Omori EGT Probe/Wire Wrapping Nat Interior & Exterior Modification 8 08-23-2007 10:01 AM
Omori EGT Guage wiring mandrOid Southern California Impreza Club Forum -- SCIC 10 04-02-2004 01:39 PM
Omori EGT Guage Wiring mandrOid Electrical & Lighting 6 04-02-2004 03:25 AM
Omori EGT gauge in stock WRX gauge pod Rich10 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 12-18-2003 02:30 PM
