Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 10-07-2003, 12:17 PM   #1
sybir
Member#: 4615
05 STi, 97 Leg OB
Default Low/rough idle?
Okie, car has ~150k on it. 97 OB, 2.5 DOHC, 4EAT.
Within the last couple days, whether the motor is warm or cold, it's been having a pretty severe vibration at idle, whether in gear or neutral/park (it's a 4EAT). It's idling at about 500-550 rpms, and it feels like there's a load on the motor when I try to rev; give it gas and it still feels like it's got load, but it's not vibrating.
Based on past experience with other cars, I'm thinking spark plugs/wires/rotor/cap.
Any other suggestions or ideas? It does it in and out of gear (obviously worse in gear) so I think it's a motor issue as opposed to a tranny one, and I'm thinking it's not getting clean spark 100% of the time and so is having to push dead cylinders, which is why it's feeling like it's got load on it at idle and vibrating so bad........
sybir is offline   Reply With Quote
Old 10-07-2003, 12:39 PM   #2
Stanley
Member#: 7374
2137 Studebaker
BlingBlingBlue
air filter?
loose ground?
Air flow sensor?
Good luck!
Stanley is offline   Reply With Quote
Old 10-07-2003, 12:46 PM   #3
sybir
Member#: 4615
05 STi, 97 Leg OB
Checked grounds, including aftermarket ones. Changed filter. Need to check MAF, but it runs much worse when that's broken
I'm going to swap back to my stock airbox and see what happens.
Thanks.
Any other ideas? One of the Legacy guys thinks it might be the coil pack, wheeeeee : )
Old 10-07-2003, 12:48 PM   #4
SSFWRX
Member#: 31789
Now with 100% more
V8 Spec C and 6MT
I will most certainly recommend to you, to inspect your sparking system. I had a plug wire go bad on an old car, which threw the motor into violent vibration at all times, and provided virtually no power. Inspect them wires, and come back if it isnt that.
SSFWRX is offline   Reply With Quote
Old 10-07-2003, 01:00 PM   #5
sybir
Member#: 4615
05 STi, 97 Leg OB
Yeah, that's what I'm swapping out tonight, plugs and wires. Thanks I'm hoping that works
Old 10-07-2003, 03:58 PM   #6
mikkyo
Member#: 25399
2003 Impreza WRX
It probably will, unless you have sticking alternator or A/C compressor or something else bad.
mikkyo is offline   Reply With Quote
Old 10-07-2003, 04:05 PM   #7
sybir
Member#: 4615
05 STi, 97 Leg OB
Yeah, alt was swapped out ~20k ago, so that's probably fine. Didn't even think about the AC compressor, and don't want to....
It does it whether the AC is on or off, too.
Old 10-07-2003, 09:46 PM   #8
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
what about your fuel lines?
did you check the filter?
do your ecu throw a CEL?
SD
suby_dude is offline   Reply With Quote
Old 10-07-2003, 11:07 PM   #9
sybir
Member#: 4615
05 STi, 97 Leg OB
Yeah, I'm getting fuel, it revs fine, too, it's just the idle in gear that's a real problem.
No CEL's, and an update: I'm not dropping $260 on a coil, plugs and wires to test and see if it works, I'll wait till it really breaks
Thnaks for your help, guys
Old 10-07-2003, 11:43 PM   #10
suby_dude
Member#: 17397
WRB, White
if you really want to know what's wrong w/ it take it to kevin at carlsen or our boy genius mcgyver (adam) from i-speed.
its the little things that can lead to big expensive things when not take care of right away.
SD
Old 10-08-2003, 12:01 AM   #11
sybir
Member#: 4615
05 STi, 97 Leg OB
Yeah, I know it. Unfortunately, both of those guys are a little far away
I'll probably swing it by a couple of Scoob shops tomorrow and see what I can find, as I know about what little things can do
Old 10-08-2003, 04:05 PM   #12
stevedood
Member#: 13841
02 WRX WAG
Sounds like plug wires? Check em with an ohmeter.
stevedood is offline   Reply With Quote
Old 10-09-2003, 12:42 AM   #13
sybir
Member#: 4615
05 STi, 97 Leg OB
Well, it would appear to have been the plugs. Big thanks to Joe Brazil for the help on this....
Rough idle, intermitent and rough cold starts... carter_wrx Pre-2002 Factory Turbo Powertrain 26 10-28-2009 01:03 PM
How Rough is a Rough Idle Go350zGo Factory 2.5L Turbo Powertrain 11 10-22-2009 11:28 PM
High Idle, Rough Idle? Brettweiser Factory 2.5L Turbo Powertrain 3 04-09-2007 11:10 PM
low/rough idle on warm starts raginbull74 Factory 2.5L Turbo Powertrain 7 01-23-2006 06:23 PM
Low/rough idle? sybir Legacy Forum 16 10-11-2003 10:11 PM
Message Board Statistics All times are GMT -4. The time now is 01:32 AM.
