Old 10-07-2003, 12:36 AM   #1
M32WRXin3seconds
Member#: 36797
Default those of you with a TXS TMIC, what BOV do you use? im having problems..
here is the deal. I have a brand new TXS V2 TMIC. I have a GFB Bov. at first i got some weird sounds. Now with the stock TMIC i never had a leak or anything like that. Im trying to determine whether it is the gasket or the bov itself not being flush with the aftermarket tmic. I tightened the bolts and the sound went away but it sounds like i might get a slight leak at about 3-4psi. how would this effect performance? it seems to pull like crazy and has no problem making boost etc. maybe its just how it sounds with an upgraded tmic? its a very quiet air sound. what would you suggest? its set to 50/50. i dont want to go back to stock + my stocker is broken from tightening. any solutions you can suggest?
thanks for your time
M32WRXin3seconds is offline   Reply With Quote
Old 10-07-2003, 03:24 AM   #2
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
i noticed a slight sound too when i put in my APS tmic, it holds boost, so i'm fairly certain it isnt a leak...maybe it is just the sound flowing through the larger ic?
Kwyjibo is offline   Reply With Quote
Old 10-07-2003, 04:33 AM   #3
M32WRXin3seconds
Member#: 36797
Default that is what i am thinking...
but i just wanted to be certain. i mean that bov is on there tight as a mofo...i have no boost problems. so i have no idea why its happening
Old 10-07-2003, 07:11 AM   #4
9o7wRx7o9
Member#: 23140
02 Subaru WRX
WRBlue
Hmmm couple things...isnt our stock BOV 100% recirc? So changing the way it directs air might change some of the noises? Just guessing on that one...another guess might be you tightened the bolts so hard that you crunched the gasket?
9o7wRx7o9 is offline   Reply With Quote
Old 10-07-2003, 08:18 AM   #5
2.2gotboost
Member#: 22860
It is the GFB BOV. I had the same set up and the bov hits the manifold. I was later told the the GFB was the only bov that had issues with the TXS TMIC. I then went with a TurboXS RFL BOV. If your GFB is the old style (non adjustable) then this is your problem.
Iwas also told you can modify (file) the bov and make it work, but I did not do it. Hope this helps.
2.2gotboost is offline   Reply With Quote
Old 10-07-2003, 10:21 AM   #6
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
I have a V2 IC and bought a GFB Stealth BOV and there was no way it was going to fit. I am not sure it the 50/50 is overall the same size. The mounting flange on the GFB is really think and actaully some what would have prevented proper mating even if there was room. My guess is that one side of the BOV is not sealed and you a getting a slight leak.
roybfr is offline   Reply With Quote
Old 10-07-2003, 11:16 AM   #7
M32WRXin3seconds
Member#: 36797
Default yeah...
i'd say it has a leak. i dont think its because anyone overtightened anything. Because the leak was MUCH worse before it was tightened. so I guess I should just buy a TXS RFL bov.
Old 10-07-2003, 11:16 AM   #8
Chi
Member#: 40311
2004 WRX
You might want to look for a leak where your BOV bolts to the TMIC. I use the Blitz BOV and encountered 2 problems.
- The bolts that I was using would not screw in completely. They were too long or the hole in the TMIC was too shallow. Either way, I used a 1/8" thick washer and solved this problem.
- The Blitz BOV base adaptor that I was using had clearance issues with the TMIC. Even after fixing the bolt issue, I realized that the adaptor would not fit flush with the TMIC. I ended up having a friend CNC machine me a new adaptor plate out of T7075 aluminum.
That quiet air sound that you are hearing is very likely a small leak. Don't forget to check all of your other IC hoses too.
Cheers!
Chi is offline   Reply With Quote
Old 10-07-2003, 11:24 AM   #9
nmyeti
Member#: 4980
Default Re: those of you with a TXS TMIC, what BOV do you use? im having problems..
Some of the GFB flanges Iíve seen are a little wide and don't properly seal with our TMIC. Check this because if you tighten the bolts and the flange is the wrong size either the TMIC or the flange can crack.
-Nathan
www.turboxs.com
nmyeti is offline   Reply With Quote
Old 10-07-2003, 11:43 AM   #10
M32WRXin3seconds
Member#: 36797
Default thanks
i didnt overkill tighten it. so i dont think i have to worry. I will be getting a txs BOV this week from nino. thanks again
Old 10-07-2003, 12:00 PM   #11
M32WRXin3seconds
Member#: 36797
Default ps...
should i just go back to stock for now?
Old 10-18-2003, 08:38 PM   #12
Onederer
I am NOT nice
Member#: 7952
2014 Ford Fiesta ST
I just put on my intercooler and had to go back to stock. My HKS was probably too big, but the base was to thin anyhow and the bolts would stick out like 1/4 inch and not seal.
Onederer is offline   Reply With Quote
What BOV do you suggest elhockey3 Newbies & FAQs 15 08-15-2008 08:27 AM
Txs Fmic, What Map Do I Use?????? subbiedo04 UTEC 1 01-25-2007 12:17 AM
What BOV do you have??? subyguy04 General Community 3 10-02-2006 09:47 AM
what bov do you like godfather2112 Newbies & FAQs 29 04-29-2004 10:01 PM
What Bov Do You Recommend? stache Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-20-2002 02:53 PM
