Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 10-07-2003, 05:52 AM   #1
Costanza
Member#: 22172
Question drivable with injectors + turbo + no tune?
would it be safe to drive my car to work for a few days with upgraded turbo, injectors, and fuel pump on the stock ecu? I'm getting my car tuned at the end of the month, but can't get off work to get everything installed the day before the tune (a Saturday). I also need to drive an hour+ to the place I'm getting my car tuned at. If I can drive it, any advice? Like staying below a certain rpm? Thanks.
Costanza is offline   Reply With Quote
Old 10-07-2003, 07:29 AM   #2
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
the car will run a little rich obviously, but dont go above ~60% throttle. As long as you stay in open loop mode(less than 60% throttle) the car will adjust the fueling based on the front O2 sensor information. If you go wot then it will run based on predetermined maps, running really rich. So idle it everywhere and you will be ok, but it will probably run just a little rough.
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 10-07-2003, 01:14 PM   #3
Costanza
Member#: 22172
thanks for the info
injectors with no tune? 07gixxer Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 05-16-2010 06:20 PM
2004 WRX driving to tuner Wed with catless turboback.. no tune sLicK 2004 General Community 4 11-09-2009 06:57 PM
upgraded injectors with no tune bova80 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 02-01-2008 06:08 PM
Is the car drivable with modded injectors, pump, but no vf34? Cusson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-31-2006 12:17 AM
Local opinions: drivability of modded stock injectors prior to tune Panic Tri-State Area Forum 12 09-29-2006 12:56 PM
