Old 10-07-2003, 10:35 AM   #1
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
Unhappy Help...car won't start
My GF '96 Legacy will not start. It's acting as if the battery is dead or the connections are corroded.
With a new battery and cleaned connectors it's still not getting enough electrical power to turn it over.
The dash lights and dome light are dim as if something is putting a load on the electrical system.
I also pulled the alternator and it tested fine.
I'm not sure what to test next
maciek is offline   Reply With Quote
Old 10-07-2003, 12:24 PM   #2
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Seems like a bad starter is the probably cause. Not sure how you would verify it, though. Can you hear a click from the starter solenoid? Does it turn over at all?
ws6fiero is offline   Reply With Quote
Old 10-07-2003, 12:37 PM   #3
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
The dash lights are dim to begin with...even with jumper cables hooked up.
As soon as you turn the ingnition...it sounds like it wants to move the starter for a fraction of a second but the power drains out.
Everything goes dead as soon as you turn the ignition to the starter position.
Old 10-07-2003, 01:13 PM   #4
subster
Member#: 40847
2008 2000 2.5 RS
1995 SVX
Try new cables? They may look fine externally but they may be corroded inside.
subster is offline   Reply With Quote
Old 10-07-2003, 01:29 PM   #5
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
Jumper cables?
I tried a brand new battery and still no go.
Old 10-07-2003, 01:44 PM   #6
subster
Member#: 40847
2008 2000 2.5 RS
1995 SVX
Default battery cables
The positive and negative cables. The one that goes to the starter and the one that goes near the starter. Also clean all connections.
Old 10-07-2003, 02:21 PM   #7
subarurabbit
Member#: 4083
2011 OB 3.6R
is it in neutral?
subarurabbit is offline   Reply With Quote
Old 10-07-2003, 02:24 PM   #8
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
A few days ago the car almost died while coming to a stop..the ABS light came on and the strereo turned off then back on again.
This is wierd since the alternator tested fine.
I'll check all the connections after work to see if it's loose or corroded.
Old 10-07-2003, 02:24 PM   #9
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Yeah, I agree with subster, check the actual battery cables a little closer. I had one freak incident where the terminal was clean, but there was a bad connection between the terminal and cable.
Old 10-07-2003, 02:38 PM   #10
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
I'll check the wires closely later.
Is there anything else I should look at? The car is stuck 45 min away, so I'd like to check as many things as possible while I'm there.
Old 10-07-2003, 02:43 PM   #11
subster
Member#: 40847
2008 2000 2.5 RS
1995 SVX
Default ummmm...
I can't think of anything right at this moment. Just check and clean all of the connections and make sure they are connected tight. OH! Fuses! Check your fuse box! You might have a faulty or burnt fuse. I f you have time take out some fuses that have to do with the ignition system.
Old 10-07-2003, 02:44 PM   #12
subster
Member#: 40847
2008 2000 2.5 RS
1995 SVX
and examine them. Sometimes they look fine but are burnt out.
Old 10-11-2003, 10:45 AM   #13
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Any update??
Old 10-12-2003, 06:10 AM   #14
HomeSlice
Member#: 6081
MY93 Legacy
Sonora Sand ej22t
its prob a bad ground cable
HomeSlice is offline   Reply With Quote
Old 10-12-2003, 11:59 PM   #15
atabert
Member#: 45107
1992 Legacy L
Green
Default cables
try running a jumper cable from the positive on battery to starter, the cables might appear to be good and have continuity thru it but it cant move the amps it needs, if it starts right up you have a bad cable good luck and dont let out the factory smoke
atabert is offline   Reply With Quote
Old 10-13-2003, 10:32 AM   #16
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
Finally went to look at the car over the weekend.
First thing I did was take apart the positive connector to see if it was corroded. From the exterior it looked fine, but when I opened the metal that holds the wires in....holy crap. There was not a single piece of exposed metal....everything was covered with a green flaky solid.
As soon as I cleaned it off with some sand paper, the car got enough power to start.
Thanks for all your help guys.
Old 10-13-2003, 01:21 PM   #17
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Time to replace both of those bad boys. It's amazing how much corrosion can accumulate inside those wire sheaths. You'll also want to check the lug/connectors at the starter motor itself. They are a "known" corrosion/incidence/failure piece. Check this starting problem link and this starter problem link for references.
Br, Dale
Subietonic is offline   Reply With Quote
Old 10-21-2003, 10:57 PM   #18
Schludwiller
Member#: 22066
1999 BD-GT 30Yr Std
I was having a bunch of weird things happening to my car. ABS warning lights, headlights dimming with the use of the brake pedal, irregular starting problems, etc.
My positive terminal was corroded as well. I didn't think it was the problem as I had cleaned it about 3 weeks previously. I must have some leaking from the battery post and will be replacing it soon.
BTW, pour a can of coke on the corrosion powder and it will be gone in seconds. Just have something underneath like a glass bowl to catch everything before it gets further down into your engine compartment.
Schludwiller is offline   Reply With Quote
Old 10-21-2003, 11:34 PM   #19
subster
Member#: 40847
2008 2000 2.5 RS
1995 SVX
Default Two websites:
http://www.startercontacts.com/
and
http://home.austin.rr.com/samuraistarter/Clicky2.htm
I got new contacts and a new plunger from the first guy.
His name's Larry. Nice guy.
He told me to also check out the second website.
That guys name is David and I just got HIS product today and will install it tomorrow.
Either way pass these two websites along to EVERY Suby owner you know.
The first or second website might save you or some one you know a lot of trouble and money.
These are both regarding the dreaded "Clicky Starter".
Congradulations Maciek!
Hope this helps if you don't already have it figured out!
Noah
HELP!!!! Car won't start chandy Electrical & Lighting 2 08-05-2003 09:57 AM
Need help! Car won't start! Turbotegra North West Impreza Club Forum -- NWIC 9 04-07-2003 04:56 AM
help! car won't start... details inside! Poe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-01-2003 09:41 PM
Please help... car won't start... tnt_rocks Bay Area Impreza Club Forum -- BAIC 6 08-25-2002 04:03 AM
please help... car won't start PrinceWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-01-2002 07:14 PM
