Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 10-07-2003, 11:11 AM   #1
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
Default Low/rough idle?
Okie, car has ~150k on it.
Within the last couple days, whether the motor is warm or cold, it's been having a pretty severe vibration at idle, whether in gear or neutral/park (it's a 4EAT). It's idling at about 500-550 rpms, and it feels like there's a load on the motor when I try to rev; give it gas and it still feels like it's got load, but it's not vibrating.
Based on past experience with other cars, I'm thinking spark plugs/wires/rotor/cap.
Any other suggestions or ideas? It does it in and out of gear (obviously worse in gear) so I think it's a motor issue as opposed to a tranny one, and I'm thinking it's not getting clean spark 100% of the time and so is having to push dead cylinders, which is why it's feeling like it's got load on it at idle and vibrating so bad........
sybir is offline   Reply With Quote
Old 10-07-2003, 12:22 PM   #2
Doug DeRosa
Member#: 22209
1998 Legacy GT Wagon
Rio Red
I had similar symptoms with my 98 GT -- rough idle and acceleration, poor gas mileage, but ran okay at speed. It turned out to be the coil, and I was told by the garagae that this is a fairly common problem with Legacies of this vintage.
Pull the plug wires at the coil and see if the terminals at the coil are burnt. If they look fried, suspect the coil. I waited til the "check engine" light came on, and took it in and was basically scalped on the repair. Looks like a real easy job, so I can only hope I might be saving someone else some time and money.
dpd
Doug DeRosa is offline   Reply With Quote
Old 10-07-2003, 12:32 PM   #3
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
Ah, thanks. So you're talking the sparkplug wire contacts on the distributor looked burned?
hmmmmmmm
Old 10-07-2003, 01:01 PM   #4
subster
Member#: 40847
2008 2000 2.5 RS
1995 SVX
Default No my friend.
Subarus have distributorless ignitions. It's the coil he's talking about on top of the engine, the little black block.
subster is offline   Reply With Quote
Old 10-07-2003, 01:24 PM   #5
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
Doh, that's what I meant. Just replaced a coil pack on my friend's car yesterday, so I'm not thinking right
Old 10-07-2003, 01:42 PM   #6
subster
Member#: 40847
2008 2000 2.5 RS
1995 SVX
Default I thought so.
I figured you knew better.
Old 10-07-2003, 02:36 PM   #7
Benjamin Tang
Member#: 4496
2009 Forester
red
i posted something similar a few weeks back:
http://forums.nasioc.com/forums/show...hreadid=429076
could we both be having the same problem, despite having different motors?
Benjamin Tang is offline   Reply With Quote
Old 10-09-2003, 12:32 AM   #8
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
Well, ran it bya local Scooby guy, and he went over it with a fine toothed comb before confirming spark plugs
$40, 4 NGK's and a bunch of cuss words (it really sucks to lose your extension between the head and the crossmember ) later, it's runnig like a champ, and revving like it hasn't in a long-ass time
Thanks for the advice; Occam's razor, eh?
Old 10-09-2003, 09:27 AM   #9
subster
Member#: 40847
2008 2000 2.5 RS
1995 SVX
Default That's great!
Good job! You're a real do-it-your-self-er!
Old 10-09-2003, 10:16 AM   #10
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
Yeah, that or cheap.........
Drove it this morning, it's still there a little bit, but i'll swap out wires tonight, and then the coil.
Word of advice. To switch out spark plugs, use a 5/8 spark plug socket, then a swivel extension, then a 1/2 inch extension. It'll give you just enough length to attach the ratchet, but not so much that you can't get it off again, and it flexes, so you can angle it out. This is an important consideration, given the following.
DO NOT: use a 3 inch extension on the spark plug socket, then attach the ratchet. It'll require ~42 minutes of prying with a screwdriver to detach the component pieces from each other, then you have to fish everything out with a magnet, at which point your socket will roll down in between the heads and the crossmember
Old 10-09-2003, 10:21 AM   #11
subster
Member#: 40847
2008 2000 2.5 RS
1995 SVX
Talking LOL
That's funny! Yeah the ones on the passenger side are easy but the drivers side sucks. You have to take out the windsheild fluid resevoir and the battery. You are going to swap the spark plug wires tonight?
Old 10-09-2003, 10:58 AM   #12
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
Affirmative, gonna swap 'em out tonight.
I didn't pull the battery, that one was pretty easy to reach, it was the firewall end on the driver's side that was giving me grief with the extensions
I'm gonna swing by the recycler and pick up some wires off a low mileage car to test, and then go from there
Old 10-09-2003, 11:00 AM   #13
subster
Member#: 40847
2008 2000 2.5 RS
1995 SVX
Default cool beans.
Is that still cool to say? Oh well, anyways cool man. Have fun!
Old 10-11-2003, 02:10 PM   #14
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
I've had two coil packs go out on the two GTs one under warranty, the other just over the emission control warranty so had to buy it. Both times, the spark plug wire to coil pack terminals were carboned up big time. Suggest replacing your wires at the same time because often the coil is trying to send juice through a wire/wires that have too much resistance (breaking down) and ends up burning itself up trying. You'll also end up with one or more fouled plugs so it's a good idea to at least pull them and clean them, or alternatively if they're worn, replaced.
For what it's worth, I always pull the intake box and the windshield washer box and on the DOHCs the battery before changing out the plugs. It's a ton easier to "turn" and "pull/work" the plug wires loose when you can actually get your hand/fingers on it then it is to try and leverage them off with God knows what jammed down in there between all that stuff and the valve cover. Plus, it's a simple, straight in shot with a 5/8" plug socket and you can actually bend over and "see" in there if you need or want to. Adds about 5 minutes per side to take the stuff out and adds years to the environment because you're not replacing all the air around you with cussing and swearing blue smoke. Just my .02 worth.
Three other things that you'll want to look at/check is the idle air control valve, the throttle body and the grounding mod. I've done a pretty straight forward, detailed writeup on all of these if you just do a search on my screen name.
Br, Dale
Subietonic is offline   Reply With Quote
Old 10-11-2003, 02:40 PM   #15
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
I'll check out the IAC, searching now. The plugs I pulled were clean, just worn (ie big gaps). The terminals, from what I can see, look brand new, but that's just from what I can see, so who knows.
One of my thoughts was the IAC, but I didn't know how to screw with it; the rough idle goes away if I even breathe on the throttle, so it's a possibility.
Thanks for the advice. What, in your opinion, would I be looking for in the throttle body?
Old 10-11-2003, 02:55 PM   #16
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Sybir,
Here's the Throttle Body post. It gives you a pretty good idea of what to look for.
The Idle Air Control Solenoid writeup is in that same post as above, just further down in the threads.
HTH.
Br, Dale
Old 10-11-2003, 10:11 PM   #17
atabert
Member#: 45107
1992 Legacy L
Green
Default rough idle
you could also have a faulty injector somewhere
atabert is offline   Reply With Quote
Rough idle, intermitent and rough cold starts... carter_wrx Pre-2002 Factory Turbo Powertrain 26 10-28-2009 01:03 PM
How Rough is a Rough Idle Go350zGo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 10-22-2009 11:28 PM
High Idle, Rough Idle? Brettweiser Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-09-2007 11:10 PM
low/rough idle on warm starts raginbull74 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 01-23-2006 06:23 PM
Low/rough idle? sybir Bay Area Impreza Club Forum -- BAIC 12 10-09-2003 12:42 AM
