#1 |
Member#: 4615
BAIC
Vehicle:05 STi, 97 Leg OB |
Okie, car has ~150k on it. 97 OB, 2.5 DOHC, 4EAT.
Within the last couple days, whether the motor is warm or cold, it's been having a pretty severe vibration at idle, whether in gear or neutral/park (it's a 4EAT). It's idling at about 500-550 rpms, and it feels like there's a load on the motor when I try to rev; give it gas and it still feels like it's got load, but it's not vibrating. Based on past experience with other cars, I'm thinking spark plugs/wires/rotor/cap. Any other suggestions or ideas? It does it in and out of gear (obviously worse in gear) so I think it's a motor issue as opposed to a tranny one, and I'm thinking it's not getting clean spark 100% of the time and so is having to push dead cylinders, which is why it's feeling like it's got load on it at idle and vibrating so bad........
#2 |
Member#: 7374
Vehicle:2007 MazdaCopMagnet dusty |
air filter?
loose ground? Air flow sensor? Good luck! |
#3 |
Member#: 4615
BAIC
Checked grounds, including aftermarket ones. Changed filter. Need to check MAF, but it runs much worse when that's broken
I'm going to swap back to my stock airbox and see what happens. Thanks. Any other ideas? One of the Legacy guys thinks it might be the coil pack, wheeeeee : ) |
#4 |
Member#: 31789
Vehicle:Now with 100% more V8 Spec C and 6MT |
I will most certainly recommend to you, to inspect your sparking system. I had a plug wire go bad on an old car, which threw the motor into violent vibration at all times, and provided virtually no power. Inspect them wires, and come back if it isnt that.
#5 |
Member#: 4615
BAIC
Yeah, that's what I'm swapping out tonight, plugs and wires. Thanks
I'm hoping that works ![]() |
#6 |
Member#: 25399
Vehicle:2003 Impreza WRX Black |
It probably will, unless you have sticking alternator or A/C compressor or something else bad.
#7 |
Member#: 4615
BAIC
Yeah, alt was swapped out ~20k ago, so that's probably fine. Didn't even think about the AC compressor, and don't want to....
It does it whether the AC is on or off, too. |
#8 |
Member#: 17397
BAIC
Vehicle:many '02 Rex,'13 FRS WRB, White |
what about your fuel lines?
did you check the filter? do your ecu throw a CEL? SD |
#9 |
Member#: 4615
BAIC
Yeah, I'm getting fuel, it revs fine, too, it's just the idle in gear that's a real problem.
No CEL's, and an update: I'm not dropping $260 on a coil, plugs and wires to test and see if it works, I'll wait till it really breaks ![]() Thnaks for your help, guys ![]() |
#10 | |
Member#: 17397
BAIC
its the little things that can lead to big expensive things when not take care of right away. SD |
#11 |
Member#: 4615
BAIC
Yeah, I know it. Unfortunately, both of those guys are a little far away
I'll probably swing it by a couple of Scoob shops tomorrow and see what I can find, as I know about what little things can do ![]() |
#12 |
Member#: 13841
Vehicle:02 WRX WAG |
Sounds like plug wires? Check em with an ohmeter.
#13 |
Member#: 4615
BAIC
Well, it would appear to have been the plugs. Big thanks to Joe Brazil for the help on this....
| Thread Tools | |
| Display Modes | |
| Rough idle, intermitent and rough cold starts... | carter_wrx | Pre-2002 Factory Turbo Powertrain | 26 | 10-28-2009 01:03 PM |
| How Rough is a Rough Idle | Go350zGo | Factory 2.5L Turbo Powertrain | 11 | 10-22-2009 11:28 PM |
| High Idle, Rough Idle? | Brettweiser | Factory 2.5L Turbo Powertrain | 3 | 04-09-2007 11:10 PM |
| low/rough idle on warm starts | raginbull74 | Factory 2.5L Turbo Powertrain | 7 | 01-23-2006 06:23 PM |
| Low/rough idle? | sybir | Legacy Forum | 16 | 10-11-2003 10:11 PM |
