Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 10-07-2003, 01:08 PM   #1
Jeff_DML
Member#: 32018
2008 M3 Sedan
Interlagos Blue
Default Gauges that fit in stock 3 gauge housing
Hi,
As far as I can tell the only gauges that will fit without modifications in the OEM 3 gauge housing that replaces the clock are Omori, is this correct? They are not selling directly to the US now so it seems like a pain and expensive to get them
I would like gauges for my WRX but I want them clean and stock looking so any other suggestions?
I think the Oem ones might be the best bet for me.
thanks
Jeff
Jeff_DML is offline   Reply With Quote
Old 10-07-2003, 01:59 PM   #2
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Default Re: Gauges that fit in stock 3 gauge housing
Originally posted by Jeff_DML
Hi, As far as I can tell the only gauges that will fit without modifications in the OEM 3 gauge housing that replaces the clock are Omori, is this correct? They are not selling directly to the US now so it seems like a pain and expensive to get them
thanks
Jeff
I believe any 45mm gauge will fit without modifying the housing. Personally, I went with 52mm Omoris with a face plate I made out of 1/8" aluminum. I had to shave arches into the housing to make them fit flush.
btw, Omori is distributing to the U.S. again thru vendors such as J-Spec Tuning and Gruppe-S. J-Spec is a registered vendor on this website and Thaison has been quite helpful from what I can tell. Check out their website:
http://www.j-spectuning.com/omorimain.htm
- Kean
Kean is offline   Reply With Quote
Old 10-07-2003, 02:23 PM   #3
Jeff_DML
Member#: 32018
2008 M3 Sedan
Interlagos Blue
Default Re: Re: Gauges that fit in stock 3 gauge housing
- Kean
thanks for the info, your gauges looks good
why did you decided on the 52mm? Increase visibility?
thx
Old 10-07-2003, 03:31 PM   #4
Kean
Member#: 25187
'08 Foz Prem TGM
Default Re: Re: Re: Gauges that fit in stock 3 gauge housing
thx
Thanks for the compliment. Increased visibility was one of the reasons, but I also wanted the "warning light" feature (not on the 45's). That pic was when I was fitting them into place. In the final installation I took them out and rearranged them so they were more user friendly (boost, oil press, & volts). I want to move the boost gauge next to the tach for more convinience. I just have to find a set-up that doesn't stick out like a sore thumb.
- Kean
Old 10-08-2003, 01:31 AM   #5
J-Spec Tuning
Member#: 32267
2005 PSM STi
2009 Black 335i Coupe
Kean - I have to tell you that so many people have seen your setup and have tried to replicate it. It is a very nice setup but how did you dremel the pod so smoothly. I have two customers that tried to replicate it and screwed their pod up because frankly, its just not easy.
So how'd you do it? Any hints.
For folks thinking about this, the Subaru pod opening is 50mm. The gauges Kean has in there is 52mm.
Hence the handy mod job.
Thaison
J-Spec Tuning is offline   Reply With Quote
Old 10-08-2003, 02:00 AM   #6
Kean
Member#: 25187
'08 Foz Prem TGM
Thaison
Thanks Thaison. I had no template to follow so most of it was done "freehand" with a Dremel. Once I had the arches roughly "Dremeled", I used a piece of wood (wrapped in sand paper) that was the same diameter of the gauge (the outer lip / widest part). This produced a close fit and allowed the gauges to sit flush against the face plate. I'm considering a new aluminum faceplate......one that will fit a bit better to get rid of the gaps you see above the two bolts in the top corners. I would have liked a cleaner look without the bolts, but I wanted a secure, tight fitting set-up that wouldn't rattle. I know that I could get a tighter fit/look if I had it to do all over again. As with any project of this type, I'm always finding ways that I "could have done it better" (you know how it goes). I appreciate your compliments Thaison.
- Kean
Old 10-12-2003, 12:37 AM   #7
J-Spec Tuning
Member#: 32267
2005 PSM STi
Ahhh, that's the trick, a piece of cylindrical shaped wood wrapped in sandpaper...thanks for the tip Kean.
Spoiler that fits in stock mounting holes? Steve.804 Interior & Exterior Modification 7 06-02-2009 01:51 AM
What size gauge will fit the stock boost gauge location? BGPKR Interior & Exterior Modification 7 10-27-2004 01:39 PM
Gauge that fits in hazard light/defroster spot jodathmorr Interior & Exterior Modification 1 11-10-2003 09:33 AM
Fuel pressure, Oil pressure, and Oil temp gauges that fit in a single din? annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-23-2002 11:40 AM
omori gauge in stock boost gauge housing? savka Interior & Exterior Modification 1 06-28-2002 08:34 AM
