Old 10-07-2003, 02:58 PM   #1
kschmohl
Member#: 32623
2002 Honda VTX 1800S
06 Odyssey / 97 4x4 Truck
Default Post subject: blinking CEL under WOT, can someone help me with my log pls!
Hey all,
I am trying to learns the "in's and out's" of the UTEC and I am in need of some real help right now and anything you could tell me would be much appreciated.
Below is the log I took this afternoon when running the car. All of a sudden now I am getting a CEL blinking under WOT in 4th gear. When it happens you feel the car bog down for a second and then it kicks back in. I have no clue to the problem. It does it when I run my Stage 2 map and the Stage 2 plus up-pipe map also.
Thanks for the help!
, , , ,Load,Knock, , , , Mod, Mod, , Mod
RPM, MAP, MAF,TPS,Site,Count, AFR, Ign#1, Inj#1, Ign, Fuel,Boost, MAF
, psia, V , % , , , , deg , duty , deg, % ,(CL) , V
2658, -1.8,2.5, 10, 00, 00, 14.6,+31.7, 14.0,ECU. , +0.0,ECU. ,2.5
2686, -1.8,2.6, 10, 00, 00, 14.5,+31.8, 14.0,ECU. , +0.0,ECU. ,2.5
2673, -1.6,2.5, 10, 00, 00, 14.4,+31.8, 13.0,ECU. , +0.0,ECU. ,2.1
2683, -3.2,2.9, 0, 00, 00, rich,+23.9, 12.0,ECU. , +0.0,ECU. ,2.9
2546, -5.5,2.6, 6, 00, 00, rich,+23.2, 14.0,ECU. , +0.0,ECU. ,2.3
2782, -5.9,2.7, 19, 00, 00, rich, +8.4, 16.0,ECU. , +0.0,ECU. ,2.7
3724, -5.7,3.0, 24, 00, 00, 14.2,+25.4, 24.0,ECU. , +0.0,ECU. ,3.1
3572, -2.8,3.3, 62, 10, 00, 15.0,+20.9, 37.0,ECU. , +0.0,ECU. ,3.4
3595, +2.5,3.6, 78, 40, 00, rich, +9.4, 58.0,+19.4, +1.5, 80.00,3.7
3671, +7.4,3.7, 82, 70, 00, rich, +9.3, 65.0,+18.0, +1.5, 80.00,3.7
3691,+11.5,3.7, 82, 80, 00, rich, +9.7, 64.0,+18.0, +1.5, 80.00,3.7
3741,+14.1,3.6, 83, 80, 00, rich,+10.5, 64.0,+18.0, +1.5, 80.00,3.8
3775,+15.3,3.6, 84, 80, 00, rich,+10.7, 65.0,+18.2, +1.5, 80.00,3.8
3853,+14.9,3.7, 85, 80, 00, rich,+11.4, 66.0,+18.8, +1.5, 80.00,3.8
3894,+15.1,3.7, 89, 80, 00, rich,+11.7, 67.0,+19.0, +1.5, 80.00,3.8
3954,+15.5,3.7, 92, 90, 00, rich,+12.4, 67.0,+18.6, +1.5, 80.00,3.8
3982,+15.7,3.8, 92, 90, 00, rich,+12.8, 67.0,+19.0, +1.5, 80.00,3.9
4045,+16.1,3.8, 92, 80, 00, rich,+12.8, 70.0,+20.1, +1.3, 80.00,3.8
4095,+15.7,3.7, 92, 80, 00, rich,+12.5, 70.0,+20.5, +1.2, 80.00,3.8
4105,+15.3,3.8, 92, 80, 00, rich,+12.6, 71.0,+20.7, +0.8, 80.00,3.8
4224,+15.3,3.8, 91, 80, 00, rich,+12.4, 72.0,+20.7, +0.6, 80.00,3.9
4257,+15.9,3.8, 92, 90, 00, rich,+10.8, 72.0,+19.9, +0.5, 80.00,3.9
4312,+15.9,3.8, 91, 90, 00, rich,+10.6, 74.0,+20.2, +0.5, 80.00,3.8
4420,+15.9,3.8, 91, 80, 00, rich, +9.9, 76.0,+21.4, +0.5, 80.00,3.9
4426,+15.7,3.9, 91, 80, 00, rich, +8.1, 78.0,+21.8, +0.5, 80.00,3.9
4559,+15.1,3.9, 91, 80, 00, rich, +8.6, 79.0,+21.9, +0.5, 80.00,3.9
4450,+15.1,3.9, 91, 80, 00, rich, +8.4, 79.0,+22.1, +0.5, 80.00,3.9
4492,+15.5,3.9, 91, 80, 00, rich, +8.5, 82.0,+22.4, +0.5, 80.00,3.9
4662,+15.3,3.9, 91, 90, 00, rich, +8.8, 82.0,+21.4, +0.5, 80.00,4.0
4708,+15.1,3.8, 13, 00, 00, rich,+21.9, 8.0,ECU. , +0.0,ECU. ,3.9
5012, +9.4,3.7, 0, 00, 00, rich, +8.9, 8.0,ECU. , +0.0,ECU. ,3.6
4728, +2.7,3.3, 0, 00, 00, 19.4, +8.9, 8.0,ECU. , +0.0,ECU. ,3.2
4380, -3.8,2.9, 0, 00, 00, lean, +8.8, 8.0,ECU. , +0.0,ECU. ,2.8
4020, -9.6,2.5, 0, 00, 00, 24.2, +9.0, 8.0,ECU. , +0.0,ECU. ,2.4
3667,-10.0,2.3, 0, 00, 00, 24.2,+11.5, 8.0,ECU. , +0.0,ECU. ,2.2
3519,-10.0,2.4, 0, 00, 00, 24.2,+11.4, 8.0,ECU. , +0.0,ECU. ,2.1
3443,-10.0,2.0, 0, 00, 00, 24.2,+11.4, 8.0,ECU. , +0.0,ECU. ,2.0
3408,-10.2,2.1, 0, 00, 00, 24.2,+11.4, 8.0,ECU. , +0.0,ECU. ,2.1
3401,-10.6,2.2, 0, 00, 00, 24.0,+11.4, 8.0,ECU. , +0.0,ECU. ,2.3
3415,-11.0,2.3, 0, 00, 00, 24.2, +9.2, 8.0,ECU. , +0.0,ECU. ,2.4
3384,-11.4,2.4, 0, 00, 00, 24.2, +9.2, 8.0,ECU. , +0.0,ECU. ,2.3
3370,-11.8,2.3, 0, 00, 00, 24.0, +9.3, 8.0,ECU. , +0.0,ECU. ,2.3
3343,-12.2,2.3, 0, 00, 00, 24.0, +9.3, 8.0,ECU. , +0.0,ECU. ,2.3
3387,-12.4,2.2, 0, 00, 00, 24.2,+11.3, 8.0,ECU. , +0.0,ECU. ,2.3
3356,-12.6,2.2, 0, 00, 00, 24.2,+11.4, 8.0,ECU. , +0.0,ECU. ,2.2
3333,-12.6,2.2, 0, 00, 00, 24.5,+11.4, 8.0,ECU. , +0.0,ECU. ,2.2
3326,-12.6,2.2, 0, 00, 00, 24.5,+11.4, 8.0,ECU. , +0.0,ECU. ,2.2
3313,-12.6,2.2, 0, 00, 00, 24.2,+11.4, 8.0,ECU. , +0.0,ECU. ,2.2
3306,-12.6,2.2, 0, 00, 00, 24.2,+11.4, 8.0,ECU. , +0.0,ECU. ,2.2
3300,-12.6,2.2, 0, 00, 00, 24.0,+11.4, 8.0,ECU. , +0.0,ECU. ,2.2
3293,-12.6,2.2, 0, 00, 00, 24.5,+11.3, 8.0,ECU. , +0.0,ECU. ,2.2
3271,-12.6,2.1, 0, 00, 00, 24.0,+11.5, 8.0,ECU. , +0.0,ECU. ,2.2
3267,-12.6,2.2, 0, 00, 00, 24.2,+11.5, 8.0,ECU. , +0.0,ECU. ,2.1
3255,-12.6,2.2, 0, 00, 00, 24.2,+11.4, 8.0,ECU. , +0.0,ECU. ,2.1
3264,-12.8,2.1, 0, 00, 00, 24.2,+11.4, 8.0,ECU. , +0.0,ECU. ,2.1
3220,-12.6,2.1, 0, 00, 00, 24.0,+11.5, 8.0,ECU. , +0.0,ECU. ,2.1
3220,-12.8,2.1, 0, 00, 00, 24.0,+11.6, 8.0,ECU. , +0.0,ECU. ,2.1
3223,-12.6,2.1, 0, 00, 00, 24.2,+11.5, 8.0,ECU. , +0.0,ECU. ,2.1
3220,-12.6,2.1, 0, 00, 00, 24.2,+11.5, 8.0,ECU. , +0.0,ECU. ,2.1
2635,-13.0,2.1, 0, 00, 00, 24.2,+11.8, 8.0,ECU. , +0.0,ECU. ,2.1
2647,-13.0,2.1, 0, 00, 00, 24.2,+11.7, 8.0,ECU. , +0.0,ECU. ,2.1
2662,-13.0,2.1, 0, 00, 00, 24.0,+11.8, 8.0,ECU. , +0.0,ECU. ,2.1
2574,-13.0,2.1, 0, 00, 00, 24.2,+11.9, 8.0,ECU. , +0.0,ECU. ,2.1
2352,-13.2,2.0, 0, 00, 00, 23.7,+12.0, 8.0,ECU. , +0.0,ECU. ,2.0
2088,-13.0,2.0, 0, 00, 00, 24.2, +9.9, 8.0,ECU. , +0.0,ECU. ,2.0
1947,-12.6,2.3, 11, 00, 00, 24.2,+20.2, 7.0,ECU. , +0.0,ECU. ,2.6
2447, -9.8,2.5, 31, 00, 00, 14.1, +7.2, 22.0,ECU. , +0.0,ECU. ,2.6
3745, -6.5,2.9, 59, 00, 00, 13.4,+31.0, 25.0,ECU. , +0.0,ECU. ,3.1
3501, -2.4,3.2, 66, 10, 00, 14.1,+20.8, 6.0,ECU. , +0.0,ECU. ,3.3
3501, +2.3,3.5, 72, 30, 00, rich,+13.7, 47.0,ECU. , +1.5, 82.00,3.6
3538, +5.9,3.6, 83, 60, 00, rich, +9.5, 64.0,+19.2, +1.5, 80.00,3.7
3595, +9.4,3.7, 89, 70, 00, rich, +9.1, 64.0,+18.0, +1.5, 80.00,3.7
3631,+12.1,3.7, 90, 80, 00, rich, +9.4, 63.0,+18.0, +1.5, 80.00,3.6
3703,+14.1,3.7, 89, 80, 00, rich,+10.0, 64.0,+18.0, +1.5, 80.00,3.8
3783,+14.7,3.7, 92, 80, 00, rich,+10.5, 65.0,+18.0, +1.5, 80.00,3.7
3813,+14.9,3.7, 93, 80, 00, rich,+10.8, 66.0,+18.4, +1.5, 80.00,3.8
3903,+15.5,3.7, 92, 80, 00, rich,+11.3, 66.0,+18.8, +1.5, 80.00,3.8
3862,+15.3,3.7, 94, 80, 00, rich,+11.8, 66.0,+19.0, +1.5, 80.00,3.8
3903,+15.7,3.8, 94, 90, 00, rich,+12.0, 67.0,+18.4, +1.5, 80.00,3.8
4006,+15.9,3.7, 92, 90, 00, rich,+12.8, 66.0,+18.8, +1.4, 80.00,3.8
4070,+15.7,3.8, 93, 80, 00, rich,+12.7, 70.0,+20.1, +1.5, 80.00,3.8
4115,+15.5,3.8, 92, 80, 00, rich,+12.3, 70.0,+20.3, +1.2, 80.00,3.8
4130,+15.3,3.8, 93, 80, 00, rich,+12.6, 71.0,+20.6, +1.0, 80.00,3.8
4198,+14.5,3.8, 92, 80, 00, rich,+12.4, 70.0,+20.8, +0.9, 80.00,3.8
4219,+14.9,3.9, 92, 80, 00, rich,+10.7, 72.0,+21.0, +0.5, 80.00,3.8
4262,+14.7,3.9, 92, 80, 00, rich,+10.5, 72.0,+21.2, +0.5, 80.00,3.8
4385,+14.9,3.8, 92, 80, 00, rich,+10.4, 75.0,+21.2, +0.5, 80.00,3.8
4357,+15.1,3.9, 94, 80, 00, rich,+10.2, 77.0,+21.5, +0.5, 80.00,3.9
4312,+13.3,3.6, 0, 00, 00, rich, +9.0, 39.0,ECU. , +0.0,ECU. ,3.9
4432, +8.0,3.6, 0, 00, 00, 13.9, +9.0, 39.0,ECU. , +0.0,ECU. ,3.4
4156, +1.9,3.1, 0, 00, 00, lean, +8.8, 39.0,ECU. , +0.0,ECU. ,2.9
3840, -4.3,2.5, 0, 00, 00, 24.2, +9.0, 39.0,ECU. , +0.0,ECU. ,2.4
3512, -8.7,2.2, 0, 00, 00, 24.2,+11.4, 39.0,ECU. , +0.0,ECU. ,2.2
3336, -8.9,2.0, 0, 00, 00, 24.5,+11.6, 39.0,ECU. , +0.0,ECU. ,2.3
3300, -9.1,2.1, 0, 00, 00, 24.2,+11.6, 39.0,ECU. , +0.0,ECU. ,2.1
3220, -9.4,2.0, 0, 00, 00, 24.2,+11.4, 39.0,ECU. , +0.0,ECU. ,2.0
3245, -9.8,2.0, 0, 00, 00, 24.2,+11.4, 39.0,ECU. , +0.0,ECU. ,2.1
3198,-10.4,2.2, 0, 00, 00, 24.0,+11.6, 39.0,ECU. , +0.0,ECU. ,2.3
3198,-10.8,2.3, 0, 00, 00, 24.2, +9.2, 39.0,ECU. , +0.0,ECU. ,2.3
3198,-11.6,2.3, 0, 00, 00, 24.0, +9.3, 39.0,ECU. , +0.0,ECU. ,2.3
3156,-12.0,2.3, 0, 00, 00, 24.2, +9.3, 39.0,ECU. , +0.0,ECU. ,2.3
3150,-12.4,2.3, 0, 00, 00, 24.2, +9.3, 39.0,ECU. , +0.0,ECU. ,2.2
3126,-12.6,2.2, 0, 00, 00, 24.2,+11.6, 39.0,ECU. , +0.0,ECU. ,2.2
2386,-12.8,2.1, 0, 00, 00, 24.0,+11.9, 7.0,ECU. , +0.0,ECU. ,2.1
2379,-12.8,2.1, 0, 00, 00, 24.2,+11.8, 7.0,ECU. , +0.0,ECU. ,2.1
2374,-13.0,2.1, 0, 00, 00, 24.5,+11.9, 7.0,ECU. , +0.0,ECU. ,2.1
2272,-13.0,2.1, 0, 00, 00, 24.2, +9.7, 7.0,ECU. , +0.0,ECU. ,2.1
2025,-13.0,2.0, 0, 00, 00, 24.2, +9.9, 7.0,ECU. , +0.0,ECU. ,2.0
1782,-13.0,2.2, 6, 00, 00, 24.0,+16.7, 16.0,ECU. , +0.0,ECU. ,2.4
2164,-10.6,2.4, 16, 00, 00, rich, +3.3, 12.0,ECU. , +0.0,ECU. ,2.4
2955, -7.7,2.6, 18, 00, 00, 14.0,+13.8, 16.0,ECU. , +0.0,ECU. ,2.7
4528, -5.3,2.9, 19, 00, 00, 13.7,+31.3, 26.0,ECU. , +0.0,ECU. ,3.0
4522, -2.4,3.3, 23, 00, 00, rich,+25.6, ---.-,ECU. , +0.0,ECU. ,3.5
4559, +0.0,3.8, 58, 00, 00, rich,+13.3, 77.0,ECU. , +0.0,ECU. ,4.0
4522, +3.5,4.0, 71, 50, 00, rich,+10.7, 90.0,+23.0, +0.5, 80.00,4.0
4734, +8.0,4.0, 73, 70, 00, rich,+11.6, 91.0,+22.8, +0.5, 80.00,4.0
4789,+12.1,4.0, 79, 80, 00, rich,+12.0, 91.0,+23.2, +0.4, 80.00,4.0
4923,+14.3,4.0, 83, 80, 00, rich,+13.4, 91.0,+23.5, +0.3, 80.00,4.0
5089,+14.7,4.0, 84, 80, 00, rich,+13.9, 94.0,+24.0, +0.2, 85.00,4.0
5050,+14.5,4.0, 87, 70, 00, rich,+17.9, 95.0,+24.0, +0.2, 85.00,4.0
5274,+14.3,4.0, 88, 80, 00, rich,+18.5, 97.0,+24.0, +0.2, 85.00,4.0
5232,+13.7,4.0, 88, 80, 00, rich,+19.0, 95.0,+24.0, +0.2, 85.00,4.0
5402,+13.5,4.0, 87, 70, 00, rich,+19.3, 96.0,+24.0, +0.2, 85.00,4.1
5473,+13.1,4.1, 85, 70, 00, rich,+20.1, 95.0,+24.0, +0.3, 85.00,4.1
5910,+12.9,4.1, 38, 00, 00, rich,+22.2, 28.0,ECU. , +0.0,ECU. ,4.0
6038, +7.8,3.7, 0, 00, 00, rich, +8.8, 67.0,ECU. , +0.0,ECU. ,3.5
5592, +2.1,3.4, 0, 00, 00, rich, +8.8, 67.0,ECU. , +0.0,ECU. ,3.3
5265, -2.2,3.5, 53, 00, 00, rich,+19.0, 46.0,ECU. , +0.0,ECU. ,3.7
3840, -3.8,3.8, 84, 10, 00, rich,+12.3, 64.0,ECU. , +0.0, 80.00,3.8
4055, +1.5,3.8, 88, 60, 00, rich,+12.8, 72.0,+21.3, +1.1, 80.00,3.8
4040, +7.8,3.8, 88, 80, 00, rich,+12.6, 72.0,+20.1, +1.4, 80.00,3.8
4115,+12.9,3.7, 89, 80, 00, rich,+12.7, 69.0,+20.5, +0.9, 80.00,3.8
4214,+14.5,3.8, 88, 80, 00, rich,+12.5, 71.0,+20.5, +0.6, 80.00,3.8
4273,+14.7,3.8, 88, 80, 00, rich,+10.6, 73.0,+20.9, +0.6, 80.00,3.8
4312,+14.7,3.9, 88, 80, 00, rich,+10.6, 73.0,+21.0, +0.5, 80.00,3.8
4323,+14.3,3.8, 89, 80, 00, rich,+10.3, 74.0,+21.4, +0.5, 80.00,3.8
4415,+14.7,3.9, 89, 80, 00, rich,+10.3, 76.0,+21.5, +0.5, 80.00,3.9
4432,+14.9,3.9, 90, 80, 00, rich,+10.1, 77.0,+22.0, +0.5, 80.00,3.9
4541,+14.7,3.9, 90, 80, 00, rich,+10.7, 79.0,+21.9, +0.5, 80.00,4.0
4623,+14.7,3.9, 90, 80, 00, rich,+10.9, 81.0,+22.2, +0.5, 80.00,4.0
4610,+14.7,3.9, 90, 80, 00, rich,+10.7, 82.0,+22.2, +0.5, 80.00,4.0
4572,+14.7,4.0, 89, 80, 00, rich,+11.1, 84.0,+22.8, +0.5, 80.00,4.0
4880,+15.1,3.9, 27, 00, 00, rich,+22.5, 4.0,ECU. , +0.0,ECU. ,3.8
5058, +9.8,3.8, 0, 00, 00, rich, +8.8, 37.0,ECU. , +0.0,ECU. ,3.6
4714, +3.5,3.3, 0, 00, 00, 16.4, +8.7, 37.0,ECU. , +0.0,ECU. ,3.2
4368, -3.0,3.0, 0, 00, 00, lean, +8.9, 37.0,ECU. , +0.0,ECU. ,2.8
4035, -9.4,2.6, 0, 00, 00, 24.2, +9.0, 37.0,ECU. , +0.0,ECU. ,2.4
3741,-10.2,2.3, 0, 00, 00, 24.2,+11.3, 37.0,ECU. , +0.0,ECU. ,2.3
3508,-10.2,2.4, 0, 00, 00, 24.2, +9.2, 37.0,ECU. , +0.0,ECU. ,2.1
3233,-10.0,2.0, 0, 00, 00, 24.0,+11.4, 37.0,ECU. , +0.0,ECU. ,2.0
3486,-10.2,2.0, 0, 00, 00, 24.2,+11.5, 37.0,ECU. , +0.0,ECU. ,2.1
3429,-10.4,2.2, 0, 00, 00, 24.2,+11.4, 37.0,ECU. , +0.0,ECU. ,2.3
3350,-10.6,2.4, 0, 00, 00, 24.2, +9.2, 37.0,ECU. , +0.0,ECU. ,2.4
3411,-11.0,2.3, 0, 00, 00, 24.2, +9.3, 37.0,ECU. , +0.0,ECU. ,2.4
3346,-11.8,2.3, 0, 00, 00, 24.2, +9.1, 37.0,ECU. , +0.0,ECU. ,2.3
kschmohl is offline   Reply With Quote
Old 10-07-2003, 04:48 PM   #2
tEkkGOD
Member#: 10110
Default Re: Post subject: blinking CEL under WOT, can someone help me with my log pls!
Code:
fixed it for u
tEkkGOD is offline   Reply With Quote
Old 10-07-2003, 04:54 PM   #3
kschmohl
Member#: 32623
Default Thanks Tekk
Thanks man...
Any idea what is going on???
I got some good info. from someone telling me that the bogging is my car reacting to knock but they said they saw nothing in my log to show knock...???
Also, I have not had any problems before, why am I getting them now? Something possibly be wrong?
Old 10-07-2003, 05:05 PM   #4
tEkkGOD
Member#: 10110
Default Re: Thanks Tekk
Originally posted by kschmohl
Thanks man...
from what i understand, the utec is pulling timing when the cel flashes so as to avoid getting knock.
im no expert though
Old 10-07-2003, 05:09 PM   #5
kschmohl
Member#: 32623
Default good point
Yeah that is true, pull timing no knock... just wonder why it is happening now and how do I fix it... I am going to try and pull some logs tonight and see is Nathan or Phil will spare me sometime to take a look at things because i am at a loss...
Old 10-07-2003, 07:15 PM   #6
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Can't answer your knock question, but was your foot to the floor on those runs? I'm asking because I see that at no point did you hit 100% TPS. You probably want to calibrate the UTEC so you will hit 100% TPS (instructions are in the manual).
Joel
Zola is offline   Reply With Quote
Can someone help me analyze my log wrx88 Commercial ECU Reflashes 4 12-25-2006 11:14 PM
i hate deer, can someone help me with my susp/steering? audioize North West Impreza Club Forum -- NWIC 15 11-26-2003 10:12 PM
Can someone help me with my laptop?? inthememof911 Mid Atlantic Impreza Club -- MAIC 12 11-04-2003 05:39 PM
can someone help me with my math homework? MaxPower Off-Topic 3 10-07-2003 03:12 AM
