Old 10-07-2003, 07:40 PM   #1
lag
Member#: 34631
to live in fear
Default So I plan on changing my timing belt soon,
I have the imfamous oil leak as well. What parts do I need to fix this leak while things are apart?
lag is offline   Reply With Quote
Old 10-07-2003, 08:04 PM   #2
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
depends. it could be the valve covers, could be head gaskets. could just be bad oil pan seal. where is the oil coming from?
subiekid is offline   Reply With Quote
Old 10-07-2003, 08:12 PM   #3
lag
Member#: 34631
to live in fear
Seems to be coming from the front center of the engine
Old 10-07-2003, 10:00 PM   #4
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Could be the front crank seal. In that case it wouldn't be too hard to change while doing the timing belt.
ws6fiero is offline   Reply With Quote
Old 10-07-2003, 11:34 PM   #5
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Poke around here for good info:
Poke
Peaty is offline   Reply With Quote
Old 10-08-2003, 01:09 AM   #6
subiekid
Member#: 25516
try to look around a bit and see. some times you can see an area that has a large amount of dirt stuck to it and that will be the leak, but if you dont keep your motor clean then its gona be hard.
Old 10-08-2003, 11:46 AM   #7
lag
Member#: 34631
to live in fear
Default thanx
Poke
This is great information, thanx worlds.
Old 10-11-2003, 02:45 PM   #8
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Your cam seal/seals might also be leaking and "draining" down toward the center too so check them out, when you're under the timing belt cover. If the front cam seals are leaking/seeping, recommend checking the rears too because when there's one leaking, there's the potential for the other end to leak too.
Just a thought.
Br, Dale
Subietonic is offline   Reply With Quote
SFL - Change my timing belt please LionJ5 South East Region Forum 0 10-18-2008 03:55 PM
Time to change my Timing Belt kastkc Normally Aspirated Powertrain 27 07-11-2006 02:49 PM
I need to change my timing belt, MY99 Aaron'z 2.5RS Normally Aspirated Powertrain 6 06-04-2005 10:44 AM
What do I need to change my Timing belt on my 1996 Legacy Outback? osirus23 Service & Maintenance 1 06-29-2004 09:31 PM
Who can change my timing belt tensioner? STEALTH-WRX Southern California Impreza Club Forum -- SCIC 1 12-20-2003 04:38 PM
