Old 10-07-2003, 08:10 PM   #1
Xen
Member#: 6389
2010 Inf. G37S Coupe
Moonlight White / Charcol
Default MY 02 Morrette (Lo/Hi and Fog) Bulb replacement
I want to go whiter and brighter not bluer and loser
What are my choices? Any recommendations?
Xen is offline   Reply With Quote
Old 10-07-2003, 08:20 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
For the Morette low beams you can try Hella H7 +50s, for the high beams H1 +30s. Both are available from www.rallylights.com for around $25/pair.
The Hellas will produce more light output than the stock Osram bulbs and use the same wattage. They do not have a heavy blue coating like the crappy r*cer bulbs.
As for the fogs there may also be an H3 version of these but I'm not sure.
Don't go with higher wattage like 80 or 100 watts unless you modify/upgrade your headlight wiring, even with Morettes.
Also for maximum voltage and light output with whatever bulbs you use, try directly grounding the low beams instead of using the factory switched ground. For the high beams, a relay on the ground side will help.
Old 10-07-2003, 08:31 PM   #3
Xen
Member#: 6389
Thanks!
UTEC off of my 02 w/boost controller and map switch dozer54321 Engine/Power/Exhaust 1 10-22-2006 11:16 PM
UTEC off of my 02 w/boost controller and map switch dozer54321 SWIC Private Classifieds 1 10-22-2006 11:13 PM
Used JDM STi chrome housing headlights 02-03 with ballast and HID bulb fd3s1128 Private 'For Sale' Classifieds 16 03-03-2005 08:13 AM
Sell my 02 Stage 4 wagon and get and STI or XO or just keep it? roybfr General Community 3 09-27-2003 07:06 PM
