Old 10-07-2003, 08:50 PM   #1
PerformanceAutoSolutions
Member#: 853
2011 STI Sedan
Satin White Pearl
Default want to shut off my daytime running lights
have a 2003 gt sedan need to shut off my daytime running lights
and want to have my foglights go on by themselves without
the headlights.
thanx,dave
PerformanceAutoSolutions is offline   Reply With Quote
Old 10-07-2003, 10:57 PM   #2
AKSubie
Member#: 6214
01.5 Audi S4
www.motorsportsalaska.com
Not sure about the Fogs on without low beam thing, but go over to scoobymods and search in the legacy section, the "disabling DRL" instructions, they have worked successfully for most those that have done it, takes about 5-10 min.
AKSubie is offline   Reply With Quote
Old 10-08-2003, 01:11 PM   #3
2000GTWagon
Member#: 13676
2005 2.5 GT Ltd. Wag
Brilliant Silver Met.
Default Very easy
Its very easy to disable the DRLs. There is a unit that needs to be unplugged underneath the steering column. Again, check scoobymods for detailed instructions.
2000GTWagon is offline   Reply With Quote
Old 10-08-2003, 09:21 PM   #4
NiTRoN
Member#: 30556
2000 Legacy GT (BE)
over 250,000 Miles
also check lightsout.org it has my post (200 Subaru Legacy).. or just read it below..
2000 SUBARU LEGACY. Look underneath the dashboard (driver side) and you will see 2 plastic modules bolted to the steering column. One is usually mounted in Horizontal (Seat Belts Module), the other in vertical (DRL Module). One will have only 1 white connector(horizontal-seat belts), the other (vertical-drl module) will have 2, one black and white. We are concerned about the one with 2 connectors mounted vertical. When you look more closely it will probably have blue label with white letters on it. Here is what my said "UNT DRL ASSY AISIN 84067AE00A," also that module has 2 aluminum plates attached on both sides of the plastic box. Don't unplug the black connector because you will loose most of the functionality of your headlights, just remove the white one. Everything else will work fine, except no more DRL's.
2003 SUBARU BAJA Same as 2000 LEGACY (above).
2002 SUBARU. Disconnect the ballast resistor (narrow silver box) behind the RF strut tower on the RS2.5 and near the cruise control on the 2002 WRX. Do it when the turbo is cool.
I feel so special to be the 1st one to do it
NiTRoN is offline   Reply With Quote
How Do i disable my daytime running lights? shauncovo Electrical & Lighting 3 10-24-2009 08:48 PM
were is the plug to turn off day time running lights please help tsubaru02 Electrical & Lighting 3 04-17-2005 07:13 AM
Turning off HID daytime running lights? rzwrx16 Electrical & Lighting 7 09-09-2004 03:21 PM
Anybody know how to get rid of daytime running lights? LttLDGN Interior & Exterior Modification 2 04-05-2001 05:53 PM
