Old 10-08-2003, 12:49 AM   #1
VOLTIS5
Member#: 2353
98' LegOver GT
dark whiteish pearly red
Default Adjustable vs NONE-Adjustable sway bar
since i'm on the market for suspention parts, which one would be an ideal type for regular driving and some spirited driving on local twisties . Any suggestions?
BTW, i talking about the 18-22mm whiteline swaybars.
VOLTIS5 is offline   Reply With Quote
Old 10-08-2003, 01:36 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I would say you might as well go for the adjustable. If there's any difference in cost it has to be pretty small, and if you decide to change your combo later you'll already be equipped to do so.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 10-08-2003, 02:00 AM   #3
lucien2
Member#: 1519
1998 Volvo V70R
agreed. I think 18mm is generally a good setting for the BD, 20mm for the BG. Having said that, I would like to go bigger for autox if I could. But I uprated our Outback to a 18-22 first. Then when I bought the GT, I simply slapped the OEM 18mm bar from the OB onto the GT. Free part really, so I can't complain, and I have never felt I didn't have enough bar back there. If I went bigger in the front I would feel differently.
lucien2 is offline   Reply With Quote
Old 10-08-2003, 12:15 PM   #4
VOLTIS5
Member#: 2353
98' LegOver GT
would the fronts be something i should be looking into as well? haven't really heard anything about the front sway as to how well the handling gets.
as for the prices its $103.00 (classified) for the 18mm non-adj. and $165 for the adj. from PDM.
BTW, would the RS rear top hats or a rear sway bar fir into a BD?
Old 10-08-2003, 03:25 PM   #5
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
You can get the adjustable cheaper, and if you're getting an 18mm, you might as well just get an 18mm Outback bar for cheap. Just my opinion.
-Andy
ws6fiero is offline   Reply With Quote
Old 10-08-2003, 09:40 PM   #6
cowapult
Member#: 25324
2016 WRX
Dark Gray Metallic
Start with the back. Don't worry about the front until you have done a lot of other mods.
Yes, upgrading either (front or back) will increase roll stiffness, but there is something else going on too. The reason people do the back is not just stiffness, but it also reduces the car's tendance to understeer. It creates neutral or oversteer instead, which is more fun and better suited to performance driving - even if it is more dangerous in an emergency.
If you upgrade the front, on the other hand, it makes the car understeer - which sucks. So, you don't get as many benefits when you upgrade the front, and it only makes sense if you have already upgraded the rear SIGNIFICANTLY (in order to out-do the upgraded front and maintain oversteer).
cowapult is offline   Reply With Quote
Old 10-09-2003, 04:43 PM   #7
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Nope the rs rear top hats and swaybars are incompatible with the BD/Gs.
ss
subysouth is offline   Reply With Quote
Old 10-09-2003, 04:49 PM   #8
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
-Andy
Where can you get it cheaper if I might ask?
ss
Old 10-09-2003, 07:20 PM   #9
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Well, it depends on if VOLTIS5 was including shipping or not.
125.95 At AllSubaru:
http://forums.nasioc.com/forums/show...egacy+sway+bar
(that's on clearance)
Westminster Speed also has it for ~$150 without shipping.
Old 10-10-2003, 12:12 AM   #10
VOLTIS5
Member#: 2353
98' LegOver GT
Wink Thanks guys
subysouth - ahh crap, thanks for the heads up though.
ws6fiero - SHAWEET, thanks for the linky save me some $$$ while i'm at it
for eveyone else THANKS for the input and suggestions. couldn't have found a better group of LegOver brothers to help me out
Old 10-10-2003, 06:18 AM   #11
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
First, the only larger front swaybar option I know of is Whiteline's 20mm bar. The bushings it comes with are not the correct bushings for our cars - they must have different swaybar mounts in Australia. I recently installed my 20mm bar using Energy Suspension WRX stock replacement poly bushings - worked like a charm.
I know the general consensus is that a larger front bar will lead to more understeer, but based on my personal observations thus far that isn't the case. Turn in is a bit sharper, and the car doens't roll quite as much, but I really haven't noticed any adverse effect on the car's balance. Witht that said, I haven't auto-x'd the car since I added the front bar, so that will be the true test. My intention is to jack my rear adjustable bar up to the firmest setting when I install my Koni inserts and Ground Control coil-overs, and I figured it was worth doing the front bar since I'm doing all that stuff too.
Pat Olsen
Old 10-10-2003, 12:37 PM   #12
sovereignmk1
Member#: 11858
1998 Silver Legacy
Originally posted by subysouth
Nope the rs rear top hats are incompatible with the BD/Gs.
ss
I was under the impression they were, or was it GC8 fronts/wrx rears(STI top hats that is?)
//M
sovereignmk1 is offline   Reply With Quote
Old 10-10-2003, 01:14 PM   #13
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
//M
The fronts(topmount bolt-pattern wise) have pretty much been the same on most of the subies since 1990. The rear bolt patterns are different. The BD/BGs share the rear topmount bolt pattern with the GD/GGs. The GCs have a different rear topmount bolt pattern.
ss
Old 10-10-2003, 01:18 PM   #14
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Thanks for the link ws6, I picked up an udjustable wl rear bar this AM. I am gonna try to do some work on the Legacy/STi suspension Ver2 this weekend. If that works out, the swaybar will be icing on the cake.
ss
Old 10-10-2003, 02:23 PM   #15
sovereignmk1
Member#: 11858
1998 Silver Legacy
ss
So if one were to order STI topmounts they should get GC fronts and GDA rears right?
//M
Old 10-10-2003, 02:33 PM   #16
VOLTIS5
Member#: 2353
98' LegOver GT
ss
YOU BASTAGE!!! So your the one that took the last rearsway I HATE YOU!!!
j/k i actually called in for the adj. just as Jamie was opening up For $125 its a STEAL
Old 10-10-2003, 02:35 PM   #17
snowone
Member#: 6035
05 92-X Saabaru
87 VW Westfalia
//M
YES... that is what you should get, correct.
snowone is offline   Reply With Quote
Old 10-10-2003, 02:45 PM   #18
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
HEHE.
Ahhh, so you were the one who she was holding the other bar for. Cool, cant wait to get it, I would say the race is on to see who can get it installed first.
ss
Old 10-10-2003, 02:49 PM   #19
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
//M
Or you could just get the GDA front and rears for simplicity. The Version8 STi suspension I bought was a complete bolt-up in my BG.
AFAIK, the GC/GFs, GD/GGs, BC/BFs, BD/BGs and BE/BHs all use the same front topmounts.
ss
edit: Forgot a big caveat!!!! The new Version8 GDs use a different rear topmount from the Ver7s. Be sure to specify the Version7 type GD rear topmounts. The Ver8s bolted right up in my car as a complete assembly(meaning the top bolt pattern is the same) but the newer Ver8 rear topmounts are incompatible with our stock rear springs.
Old 10-11-2003, 01:03 PM   #20
VOLTIS5
Member#: 2353
98' LegOver GT
HEHE.
ss
well, i still got my my strut and springs to install but i'm sure i'll get the sways first. Your on PAL
Old 10-11-2003, 01:39 PM   #21
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Funny.... the reason I didn't post the link at first was becasue I was thinking of buying one myself. I assume Jaime doesn't have any more, right?
Old 10-11-2003, 04:04 PM   #22
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
You are a little closer than me, I got an estimated delivery date of next friday. I also am gonna have to paint that bar. Its nothing personal to WL, but I cant get past that baby blue paint. Its gonna be black or red before it goes on.
ss
Old 10-11-2003, 04:06 PM   #23
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Sorry ws6 I thought you were set, she said I got the last one. Dont know if she can repeat but she does go above and beyond for NASIOC members at times.
ss
Old 10-11-2003, 04:49 PM   #24
VOLTIS5
Member#: 2353
98' LegOver GT
Unhappy sorry ws6
DAMN, now i'm feeling bad . didn't know that you were in need of one. sorry to rob you off of this one
Old 10-11-2003, 06:55 PM   #25
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Nooo, don't feel bad... I was just curious. Glad you guys were able to get them at that awesome price
I was considering getting one, but I have better things to be spending money on anyway.
Whiteline Brand New Adjustable Front and Rear sway bars wadejg Suspension/Brakes/Handling 6 09-27-2006 08:59 PM
WTB: Adjustable Whiteline wagon rear sway bar Ensi Private 'Wanted' Classifieds 0 09-16-2006 04:29 PM
SoCal FS: Perrin Adjustable 20-22mm Rear Sway Bar - 96-01 Imprezas = $80 wal.lin Private 'For Sale' Classifieds 6 08-17-2005 02:40 PM
Whiteline Adjustable Heavy Duty Front Sway Bar for 04+ STi GNV Motorsports Suspension/Brakes/Handling 36 07-12-2005 01:39 PM
Free Shipping on Progress Lowering Springs and Adjustable F & R Sway Bars! OAKOS Automotive Vendor 'For Sale' Classifieds 26 12-04-2003 08:34 PM
