Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 10-08-2003, 11:44 AM   #1
justlikethat
Member#: 44934
Default 4AT - I need to make it stronger
guys/gals,
It is my first post so, I apologize in advance if this is an old topic.
I have set up a BAJA for my father as follows:
AVO 2.5L turbo kit
BORLA Header
Modded BORLA Exhaust
lift kit
springs
strut tower brace
rear sway bar
17" wheels
removed all of the lower body cladding and had it painted black
tinted
hard tonneau cover
boost gauge
I am told that we are making between 265 - 280hp at the engine. I need to either strengthen the stock 4AT or replace it with another 4AT - something that can get the power down.
If you have any input about transmissions or if you know of any aftermarket manufacturers that could help - please share some info.
Thanks.
justlikethat is offline   Reply With Quote
Old 10-08-2003, 03:05 PM   #2
jimqpublic
Member#: 38155
2004 ForesterXT Auto
Default Re: 4AT - I need to make it stronger
There's a simple but expensive fix.
1. Wait a few months.
2. Remove the following from the car:
Originally posted by justlikethat
strut tower brace
rear sway bar
17" wheels
hard tonneau cover
boost gauge
3. Install the parts removed into a 2004 Baja Turbo with VTD/Sportshift 4EAT.
But seriously, the VTD transmission seems like a much better choice for high power applications. The big question is whether the computer in your Baja could handle a VTD trannie out of a Legacy GT or 6 cylinder Outback. If so, start checking the salvage yards. There's one here in the Los Angeles area that specializes in Subarus (World Salvage).
jimqpublic is offline   Reply With Quote
Old 10-08-2003, 05:53 PM   #3
justlikethat
Member#: 44934
jimqpublic,
Thanks for your reply!
I will check into the VTD from one of those two vehicles that you mention and if it fits I'll see if I can get a hold of that salvage yard.
I actually ordered a Turbo BAJA last March but, was the only person in Canada who ordered one so, guess what, Subaru isn't bringing them into the country....that's ok though because I can rest assured that I will for sure have the fastest one up North now eh?!
Thanks again, I'll post back if I get this sorted out.
Old 10-08-2003, 06:38 PM   #4
scoobysnacks89
Member#: 6560
03 Baja
Could you post some pics of that monster when you get it all done. I'd love to see how it looks.
scoobysnacks89 is offline   Reply With Quote
Old 10-08-2003, 09:20 PM   #5
jimqpublic
Member#: 38155
My first reply was obviously partly joking. Replacing the transmission certainly isn't the first thing to do.
You imply that it doesn't "get the power down". Any symptoms?
The Baja has the "Active All Wheel Drive" that uses a clutch to transer power from the predominantly front drive to the rear. normally the clutch doesn't clamp down until some wheelspin is detected. With the gear selector in "1" or "2" the clutch is mostly locked. The TCU or Transmission Control Unit manages the clutch as well as shifting. It would be possible to trick the system into locking the clutch up for drag racing type starts. There was discussion of this (for off-roading) in the Yahoo Forester Group http://autos.groups.yahoo.com/group/subaruforester
WRX folks with autos like to get their torque converters modified for higher stall speeds. Search nasioc over in the transmission section for links to the vendor that does this mod. I don't know if the TC is different.
Most importantly, transmission temperature is critical. If you haven't done so already, get an auxillary transmission fluid cooler. One with its own fan would be good for drag racing type applications.
Jim
Old 10-09-2003, 08:38 AM   #6
justlikethat
Member#: 44934
Jim,
Basically what it feels like is when you step on the throttle, it seems like the transmission doesn't catch for a second (feels to me like its slipping) and then all of a sudden it hooks up.
I've been told that I should look into a transmission cooler (do you know what brand or model would be a good fit for a BAJA?), full-synthetic oil and then (if necessary) upgrade the torque converter.
I will go outside here shortly and try the vehicle in 1st and 2nd gear and see what the effect is.
I apologize that I don't know more about transmissions but, what does a "higher stall speed" mean when you are talking about the torque converter?
Scooby,
I will definitely try to post some pics. I think that you will like the look. It's completely blacked-out with anthracite gray six spoke wheels.
Thanks guys for your interest and help.
Old 10-09-2003, 09:31 AM   #7
dragonglen
Member#: 38692
2003 Baja Sport
I think I've only seen pics of maybe 2 modified Bajas, not including the Scorpion Lift Kit pics. And I won't be able to mod for a while
Oddly enough though, my Baja was pulling on my buddies stock 00 Civic Si. I have no explanation other than he's a really crappy driver.
dragonglen is offline   Reply With Quote
Old 10-15-2003, 08:28 AM   #8
justlikethat
Member#: 44934
Default picture
dragonglen,
i took a side on pic of the BAJA on the weekend with a digi-cam now how do I post it?
sorry, I'm a newb.
thanks.
Old 10-15-2003, 09:15 AM   #9
scoobysnacks89
Member#: 6560
03 Baja
You'll need to post the pic on a webpage then link to it. If you have any personal webspace provided by your ISP that will do just fine.
Or, if you want to i can host the pic for you. You'd have to e-mail me the pic. I'll get to it when i get home tonite from work. PM me if you want to do this.
Old 10-17-2003, 01:57 PM   #10
justlikethat
Member#: 44934
Default pics of the BAJA
Not sure if I did this right.
Thanks to Scooby for hosting the pictures.
I would like to hear opinions on how it looks.
Thanks
Old 10-17-2003, 02:22 PM   #11
justlikethat
Member#: 44934
Default updates
hey guys,
just wanted to post an update. many thanks to everyone for the info.
jimq - the truck definitely seems better a low speeds with the selector in 1 or 2. Also, on the highway at 75mph, if you put the selector in 3 you can accelerate up to around 100mph as fast as you want with absolutely no drama.
We took the vehicle to a transmission shop and their opinion was that the torque converter was not acting as it should.
So, I think that we'll be sending the torque converter to 'ProTorque' in NJ to get modified -- apparently they have set up numerous WRX's and Legacy's.
We are also having a transmission cooler installed and switching to full synthetic fluid.
My next question is: can the stock Subaru transmission control module be modified by a dealership?? Apparently, the LINK ECU covers engine management only and will not over-ride anything in the TCU >>> do you guys even think that this will be necessary once we've made the changes above?
Thanks for your help.
Old 10-17-2003, 02:46 PM   #12
hatake
Member#: 34811
04 Baja T
OMG, she is a beautiful thing! That's better than Baja T that's not even out there yet! You did an excellent job. Hope your next project (tq) goes well, too. Thanks for sharing!
hatake is offline   Reply With Quote
Old 10-20-2003, 12:07 PM   #13
dragonglen
Member#: 38692
2003 Baja Sport
Wow, that does look nice. Definitely makes me jealous. Where did you take it to get painted?
Seeing these couple of turo'd Bajas brings a tear to my eyes. I wish I had the money.
Old 10-22-2003, 01:20 AM   #14
Paisan
Tri-State Track Instructor
Member#: 197
'14 Touareg TDI '14
BRZ http://48hrs.info
No need to strengthen it IMHO. An ATF cooler is what you need to get in there. Get the biggest honking unit in Summit Racing, put in an ATF Temp guage.
I run my SVX pushing about 250ish HP and 3600lbs on the track at 5000-7000 rpm for an hour at a time and she runs just fine.
-mike
Paisan is offline   Reply With Quote
Old 10-22-2003, 08:15 PM   #15
adhong
Member#: 44666
Default Painting the Cladding
so how difficult was it was rip off the cladding and paint it black? i have an 03 outback, and the paint on the cladding sucks big time. i want to just take off the cladding and the rest of the titanium colored bumpers and paint them all black.
adhong is offline   Reply With Quote
Old 10-27-2003, 04:42 PM   #16
justlikethat
Member#: 44934
I actually had a local paint shop do it and they told me that it was very easy.
Get your Subie dealer to remove the cladding (they'll ensure that nothing gets damaged) - get it to the paint shop - get them re-installed and you are back in business.
no sweat.
Old 10-27-2003, 04:44 PM   #17
justlikethat
Member#: 44934
By the way,
My torque converter is coming back from ProTorque tomorrow, we have installed a transmission cooler from a local outfit and have switched to full synthetic.........cross your fingers.....
cheers.
Old 11-17-2003, 11:37 PM   #18
dave_t
Member#: 48729
2002 legacy wagon
black
justlikethat, now you say you have this tuned for your dad can i ask where you live? because there is a guy who works with my mom who drives a silver wrx who's dad has an all black baja with a turbo and i cant imagine there's more than one, it's an amazing car/truck if its the one i'm thinking of they say it's here in pei almost every weekend but i havent seen it in person yet
dave_t is offline   Reply With Quote
Old 11-20-2003, 04:58 PM   #19
FaastLegacy
Member#: 11671
Those wheels don't look right on a Baja with a lift. They don't fill the wheel wells enough.
-faast
FaastLegacy is online now   Reply With Quote
Old 11-20-2003, 05:09 PM   #20
dave_t
Member#: 48729
2002 legacy wagon
black
the rims are awsome but big tires would look good
Old 11-30-2003, 12:05 AM   #21
justlikethat
Member#: 44934
Hi Dave T,
We actually live in Halifax and I drive a silver STI.
The BAJA is on PEI pretty well every weekend, we have a cottage over there.
Are you in Charlottetown?
Old 11-30-2003, 04:10 PM   #22
dave_t
Member#: 48729
2002 legacy wagon
black
ya i live right in charlottetown my dad is one of the two subaru salesmen here do you have a brother or someone who works in the national park that drives i think it's around an '02 wrx thats silver?
Old 11-30-2003, 08:52 PM   #23
justlikethat
Member#: 44934
hi dave,
yeah, brother in law, works for the gov't, drives an silver impreza ts? rs? wagon.
he lives in ch'town.
97 brigton 1.8/2.2 swapwhat do i need to make it work? willyp Normally Aspirated Powertrain 2 11-28-2009 09:47 AM
carbon fibeer is dull need to make it needsboost2005 Interior & Exterior Modification 4 06-25-2007 07:29 PM
stock intake everything needed to make it work properly! lilmeze Private 'Wanted' Classifieds 3 06-05-2004 04:45 PM
If I got an EJ22T motor and oil pump, what else would I need to make it work SpamMansXe Subaru Conversions 19 07-29-2003 04:59 PM
Upcoming order- is this all I need to make it work? mike270 Car Audio, Video & Security 19 05-24-2002 12:19 PM
