Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 10-08-2003, 03:55 PM   #1
iceboy
Member#: 44951
1995 saab 9000
300 whp
Default head gaskets...
hi im new to nasioc but been on scoobymods for quite awhile...ive got a 97 outback 6 spd the 2.5L with 123,000 miles on it. I was readin some posts either on here or scoobymods about people having blown headgaskets. Is this common in scooby's?? is there any certain point when it most commonly occurs? and what are the symptoms cuz at the moment im having some really bad power loss in all gears
thanks...iceboy
iceboy is offline   Reply With Quote
Old 10-08-2003, 09:04 PM   #2
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Default Re: head gaskets...
thanks...iceboy
Uh, 6 Speed OB? Or is that a typo?
Anyways, the Phase 1 EJ20 DOHC that were in the Legacy GT/Outback on years MY99 and lower were prone to headgasket failure. This normally occurs during the 75K-100K miles lifeline and depends on your driving style and how you take care of the car.
Symptoms include, but not limited to; white smoke comming from the exhaust, loss of coolant, significant change in engine operating temperature, and visual inspection of any leaks or fluid from the gasket sealing between the heads and block.
I'm a noob when it comes to the MT. How long have you replaced your clutch? I'm guessing it maybe one of your problems.
I have a MY98 OB with 55K and still running strong except for an odd throbbing noise. But I fear one day it will go . Just a flawed design with Subaru, which is why the new ones are all SOHC, for their Normally Aspired engines for that matter as well.
-paK +12
Pakin is offline   Reply With Quote
Old 10-09-2003, 05:39 PM   #3
iceboy
Member#: 44951
1995 saab 9000
300 whp
yeah..typo...its a 5spd...but i thought it was a 2.5 liter dohc not 2 litre. But anyway...im still on the original clutch...is that bad seeing as im at 123,000 miles? lol. It was my moms and she was kinda rough on it so i dunno...
thanks iceboy
Old 10-09-2003, 07:39 PM   #4
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Oh yea that another typo.
Yes its suppose to say EJ25
As I've said before I'm not much of a MT guy. But since it was your mother's, and she was hard on it the first place, it's kinda hard to believe its still in work. I'd replace it.
If it feels like it takes a long time for the clutch to grab from the moment you start releasing it after you pressed it wall the way down, then it is indeed time for replacement.
If you are still unsure try asking a friends or neighbor to help you feel it out. They should know, as I'm not where you are so I wouldn't.
Good luck
-paK +12
Old 11-01-2003, 01:24 AM   #5
Rally Medic
Member#: 28249
1998 Outback Sport
Dirty with some mud flaps
i replaced mine at about 56 k. and im not talking about my bandwith . i had all those normal problems accure with mine white smoke. leaking and shatty hp threw all gear's.i have a short ram , headers, and a full exhaust system to a spin tech muffler. and i rally mine so i beat it up on the regular
RALLY ON
WWW.GravelCrew.Com
BAN THE BANANA !!!!!
Rally Medic is offline   Reply With Quote
Blown head gaskets, warped heads and a piston melted to the cylinder wall Borjaq Warranty Issues & SOA Problems 13 05-22-2010 10:16 PM
Help! FAST! Do I need to use gasket sealer, when replaceing my head gaskets?! wighti Tri-State Area Forum 5 10-05-2003 10:19 PM
Which head gaskets on EJ22T with EJ25 SOHC heads? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 22 05-11-2002 11:08 AM
Leaky Head Gasket & Water Pump Gasket - MY00 Forester lark6 Normally Aspirated Powertrain 20 11-10-2001 10:22 PM
EJ22T with 2.5 SOHc heads. which head gasket? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 10 10-03-2001 11:40 AM
