Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Old 10-08-2003, 04:48 PM   #1
RallySport Direct
NASIOC Storefront Vendor
Vendor Sales Rating: (95)
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Default Speedware Harness Bar and Sparco 4-Point Harness GB.
Hey everyone! We have put together a Awesome deal for you all. We have had a lot of customers ask for 4-point harness systems. We have joined up with Speedware and Sparco to bring you a solution.
The Speedware harness bar features all hand built stainless construction and electro polished finish. The Speedware harness bar allows the use of racing harness in your WRX without adversely affecting the car's "people mover" capabilities.
The resulting ride stiffens the center of the car allowing the WRX to handle much harder cornering loads.
The Speedware harness bar will fit in 2002-2004 Subaru WRX’s including the New STI. Installation is very simple and is a direct bolt in. There is no need to make custom parts. You will still be able to recline your seats. If your seat is all the way back on the rails, you will still have a few inches to recline.
Sparco 4-Point Harness system. This system will include full 3” competition harnesses with a cam lock system. Included is the 48” shoulder harness, the pull down lap belt and mounting brackets to attach the lap belt to the seat belt bracket. This will include evryting that you need to install the harness bar and the 4-point harnesses. These are Sparco’s top of the line harnesses and are SFI approved.
Available Colors: Red, Blue, and Black.
GROUP BUY IS CLOSED ! ! !
1. horshack - Package E - Black Harness
2. dorongo - Package B - Blue Harness - PAID 10/21/03 - Shipped!
3. Leonardo - Package B - Blue Harness - Camera Mount
4. JBETANC - Package A - Black Harness - PAID 10/21/03 - Shipped!
5.
6.
8.
9.
10.
If you have any questions please be sure to ask us. Thank you.
Nick
RallySport Direct
www.rallysportdirect.com
[email protected]
RallySport Direct is offline   Reply With Quote
Old 10-08-2003, 06:23 PM   #2
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
where do the harness attach to? and where does the bar bolt to??
And I know this next question is wierd, but if I wanted to attach 4 pt harness in the rear, how would I go about doing so.
I do road rallies, and at times I have more than one navigator, and the one that needs the harnesses the most is the poor sap in the back. you should see them sliding along on the leather in the back of the WRX, while trying to hold on to maps and route instructions.
thanks for any info,
RR
Rapid_Roo is offline   Reply With Quote
Old 10-08-2003, 06:41 PM   #3
RallySport Direct
Member#: 33174
We are Open Late!
Rapid_Roo - The harness attaches to the harness bar. This picture might help.
The harness bar itself attaches to the factory seat belt locaton on the b-pillar and down on the floor. There is a mounting bolt between the seat rail, and the b-pillar, underneath the carpet that the bottom of the harness bar attaches to.
As far as putting a 4-point harness in the back seat, I have never heard of it being done. One thing to remember when installing a harness system, is you need the harness to run straight off the back of the seat and connect to either a harness bar or a roll cage. If you fail to do this, it renders the harness useless.
Old 10-08-2003, 06:43 PM   #4
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
thank you, that was very helpful.
RR
Old 10-08-2003, 10:33 PM   #5
dorongo
Member#: 39935
2004 STI
once installed, can you still move the seatbelt up/down?
dorongo is offline   Reply With Quote
Old 10-08-2003, 11:37 PM   #6
stirex
Member Sales Rating: (60)
Member#: 17952
Any chance of getting a package w/ a 5 pt harness?
Another thing...is that wise to have rear passengers with a harness bar installed?
stirex is offline   Reply With Quote
Old 10-09-2003, 05:17 AM   #7
8Complex
Member Sales Rating: (4)
Member#: 922
16 WRX (white)
04 FXT (red)
Just a bunch of comments, cause I'm full of them for some reason this evening.
If you buckle up in the back seat, no worries. If you're worried about hitting something with rear seat passengers, then it might be to your advantage to put some padding on the top/backside of the bars or something.
Those are nice seats in the pictures... real shame they have TV's installed in them.
Looks like a very nice bar setup. Any chances of a shot showing how they're bolted to the seat belt mounts? And maybe the floor mounts as well?
Old 10-09-2003, 09:13 AM   #8
dorongo
Member#: 39935
2004 STI
what is the lap belt connected to?
thanks
Old 10-09-2003, 09:41 AM   #9
RallySport Direct
Member#: 33174
We are Open Late!
dorongo - I'm pretty sure that you can. I will put a call in today and double check on that. I will se exactly where it mounts to on the b-pillar.
stirex - I had originally thought about putting in a 5-point harness with this, but to attach it to the wrx, you need to make a custom bracket that would run along the floor from seat rail to seat rail. If you didn't want to do that you have the alternative to drilling a hole in the floor and mounting it up that way.
Sparco's recommendation was not to run a 5-point if you can't have the sub belt run thought the seat. Either way, if you are interested, a 5 or a 6-point system can be added to the deal. Email me and we can work something out.
8Complex - I will work on some pictures.
dorongo - The lap belt connects to the seat belt brackets on the side of the seat. This is where the bolt in kit comes into play. You will mount the bolt-in bracket on the seat belt bracket and the harness will loop through the bolt-in bracket. I hope that this makes sense. I picture is worth a thousand words. I will see what I can do as far as pictures go in the next few days.
Nick
Old 10-09-2003, 11:39 AM   #10
horshack
Member#: 19236
Axis GT35/40R STi
Not back yet
Let me be the first to sign up for Package B
Package B: $669.00 - Shipped!
(1) Speedware Harness Bar
(2) Sparco 4-Point Harness System (Driver and Passanger)
Package B: $612.00 - Shipped!
Pleaes PM me on how and when you would like payment.
horshack is offline   Reply With Quote
Old 10-09-2003, 01:45 PM   #11
dorongo
Member#: 39935
2004 STI
I'm in for package B (I also emailed you)
Old 10-09-2003, 02:20 PM   #12
JIN
Member#: 27731
Do you guys just sell the bar alone? Already got myself racing harnesses already ..
Thanks,
Jin
JIN is offline   Reply With Quote
Old 10-09-2003, 07:09 PM   #13
RallySport Direct
Member#: 33174
We are Open Late!
horshack - Just sent off a PM with info.
dorongo - I got ya, let me know if you need anything else.
JIN - We can sell the bar alone. I sent you a PM with more information.
I did call Speedware today and they told me that the bar is easily removed in about 5 minutes once you have done it a time or two.
I'm still working on getting some pictures of the installed bar and of the harness. Let me know if you guys have any more questions.
Nick
Old 10-10-2003, 04:48 PM   #14
CRXguy
Member#: 25370
2003 WRX wagon
Played Out Blue
Nick,
Could you PM me info for just the harness bar itself as well? This will fit an '03 wagon as well right?
Thanks!
Anh
CRXguy is offline   Reply With Quote
Old 10-10-2003, 05:42 PM   #15
nqwan
Member Sales Rating: (2)
Member#: 2916
02 duburu arr exu
is that a fire extinguisher mounted to the harness bar? can you get pictures of that as well?
this is waaaaayy too tempting to resist...
nqwan is offline   Reply With Quote
Old 10-10-2003, 07:36 PM   #16
RallySport Direct
Member#: 33174
We are Open Late!
CRXguy - I just updated the information about the harness bar itself. It will for sure fit the wagon.
nqwan - I will poke around and see what I can come up with as far as pictures go. It is a fire extinguiser mount. Let me know if you have any more questions.
Nick
Old 10-11-2003, 03:31 AM   #17
Leonardo
Consigliere
Super Moderator
Member Sales Rating: (3)
Member#: 185
2009 Civic EX
I might grab this as well!
Any chance you can get camera mounts?
thanks!
Leo
Leonardo is offline   Reply With Quote
Old 10-11-2003, 11:47 AM   #18
RallySport Direct
Member#: 33174
We are Open Late!
Leonardo - I added you to the list. Let me know what color of harness want. The camera mounts we can also get you when you order up a bar. The camera mounts will be a additional 90.00 with freight included. I have been looking for some more close up pictures. I did find this one.
I hope this helps a little bit.
Nick
Old 10-11-2003, 09:50 PM   #19
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Cool, Put me down for a blue set and a camera mount.
Mind you I'm in Puerto Rico (00979)
Thanks,
Leo
Old 10-13-2003, 09:33 AM   #20
RallySport Direct
Member#: 33174
We are Open Late!
Leonardo - I got ya taken care of. Let me know if you have any more questions. Thanks.
Nick
Old 10-19-2003, 03:14 AM   #21
RallySport Direct
Member#: 33174
We are Open Late!
We need to get a few more peeps on this train. It closes in less than one week!
Nick
Old 10-20-2003, 11:43 PM   #22
RallySport Direct
Member#: 33174
We are Open Late!
We are now accepting payments for the G.B. I have sent all of you P.M. regarding the payment information. If anyone lese wants to get in on this, we still have a few more seats available. If you have any questions, please be sure to let us know.
Nick
RallySport Direct
Old 10-26-2003, 04:37 PM   #23
tm999xxx
Member#: 34408
07 Spec B
SoapBox?
i think i want in on this but i have to see how the deal goes with the sti...should pick it up on friday..Thanks Tom
tm999xxx is offline   Reply With Quote
Old 10-26-2003, 05:12 PM   #24
bbbwrx
Member#: 32734
You may want to hurry buddy the GB looks like it ends today.
BEN
bbbwrx is offline   Reply With Quote
Old 10-26-2003, 06:07 PM   #25
RallySport Direct
Member#: 33174
We are Open Late!
tm999xxx - The group buy does end today. Please let me know asap if you want to get in on this. I have already shipped three bars to customers. Thanks for your interest.
bbbwrx - Thanks for giving the peeps the heads up.
The GROUP BUY ENDS TODAY! We still have plenty of slots open if any of you are still wanting to get in on this. We will require payment for this group buy on the 10/27/03. After that, the group buy ends! Thanks for all that participated in this!
Nick
RallySport Direct
FS: Sparco Evo Seats, Harness Bar & Sparco 4 Point Harnesses (Pics Included) dcheyne55 Interior/Dressup/Audio & Security 14 11-15-2007 07:59 PM
FS: Speedware Harness Bar & Sparco 4-point Harnesses STIStalker Interior/Dressup/Audio & Security 5 02-18-2007 12:18 PM
FS: M1 harness bar and SPARCO 4 point harness SPIDEYWrX Interior/Dressup/Audio & Security 7 02-03-2007 12:14 PM
FS: Speedware harness bar and Sparco 4-pt Harnesses FTD Mid West Subaru Owners Club Forum -- MWSOC 1 11-06-2005 10:44 PM
FS: Speedware harness bar and Sparco 4-pt Harnesses FTD Private 'For Sale' Classifieds 4 11-06-2005 10:25 PM
