Welcome to the North American Subaru Impreza Owners Club Thursday January 29, 2015
Old 10-08-2003, 07:24 PM   #1
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Default Blown Motor Pics
Clutch at just under 19K. Started off with Stg4 since 3K miles.
Connecting Rod going through the block.
Closer look at the connecting rod.
Engine pulled out
Anyone know what this sensor it? When the connecting rod blew out, it damaged this sensor.
Need4Boost is offline   Reply With Quote
Old 10-08-2003, 07:29 PM   #2
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
denied pix
IA Performance is offline   Reply With Quote
Old 10-08-2003, 07:29 PM   #3
IA Performance
Member#: 25194
Dark Gray
denied pix
Old 10-08-2003, 07:31 PM   #4
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Doh, let me try this again.
Edit: Now does it work?
Old 10-08-2003, 07:36 PM   #5
WRXsPWN
Member#: 35989
2011 Sti sedan
still dont work.
WRXsPWN is offline   Reply With Quote
Old 10-08-2003, 07:39 PM   #6
Subie Nut
Member#: 4821
2004 STI
Blue on Gold
Default Nope
I'm blind! I'm blind! ........... oops....... my bad the pics don't work
Subie Nut is offline   Reply With Quote
Old 10-08-2003, 07:52 PM   #7
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Fixed.
Old 10-08-2003, 07:55 PM   #8
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
I see them.
Looks like similar to east coast scooby's motor.
Rod through the block is nasty.
Coolant temp sensor
mr2guru is offline   Reply With Quote
Old 10-08-2003, 07:59 PM   #9
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Originally posted by mr2guru
I see them.
Coolant temp sensor
Thanks!
Oh, how is the 2.4L engine treating you? I am either going with that or a V7 motor. Opinions? Thoughts?
Old 10-08-2003, 08:28 PM   #10
Si2WRX
Member#: 13173
309 hp on 93 + W/I
on Dyno Dynamics
Sorry if it was mentioned in another thread... what caused the failure?
Si2WRX is offline   Reply With Quote
Old 10-08-2003, 10:21 PM   #11
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
Pfft.. you said 'blown motor' and I enter the thread expecting to see a damned blower on top of your engine... aka supercharger.
Bah..
Speedwagon is online now   Reply With Quote
Old 10-08-2003, 10:55 PM   #12
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Well, I think that the motor took enough of a beating and just took a crap on me.
The tuning was conservative and my A/F's were a bit on the rich side (based on the w/b reading when I was on the dyno). My EGT's never went above 800C on any of my 1-2-3-4 gear runs.
The engine has been through hell since I first got the car. Something had to give and it happened to be the connecting rod.
Old 10-08-2003, 10:57 PM   #13
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Bah..
Ok.
Old 10-09-2003, 02:12 AM   #14
mrubino83
Member#: 22987
2010 PB EVO X GSR...
.. It's All Stock Officer
what r your mods need for boost? and how much were you boosting at the time? what octane were you running?
mrubino83 is offline   Reply With Quote
Old 10-09-2003, 02:19 AM   #15
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Can you explain more into detail what your mods were, drivinbg style (although that should be obvious from the look of your clutch ),WHP, etc?
jigga is offline   Reply With Quote
Old 10-09-2003, 03:05 AM   #16
IA Performance
Member#: 25194
Dark Gray
Dang, looks like I set the bar and you just beat me out. 2 hole to my one :P
Let the motor build up begin.
Old 10-09-2003, 04:46 AM   #17
DemiGod
Member#: 44323
how much are used sti motors going for these days???
DemiGod is offline   Reply With Quote
Old 10-09-2003, 10:25 AM   #18
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
That sucks dude! Pretty brutal.. but after the teardown on my motor last night.. I think I have EVERYONE beat!
hehe Best of luck and getting running again!
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 10-09-2003, 11:34 AM   #19
vile
Member#: 32371
'02 t-rex wagon
platinum
damn, 3 blown motors in like 5 wks time
vile is offline   Reply With Quote
Old 10-09-2003, 12:11 PM   #20
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I've seen the STI blocks selling for $1500 new. And you just missed a brand new EJ22T block on EBAY it went for $900.
Well take it easy, Micah
Old 10-09-2003, 01:50 PM   #21
SJwrx
Member#: 14970
1997 GF8
multi
I'll buy your valvetrain off the car ...
Rich
SJwrx is offline   Reply With Quote
Old 10-09-2003, 02:04 PM   #22
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
My mods are FMIC, ECUTek, T3/T04E 50 trim, 785cc injectors, and the usualy supporting mods.
I was boosting at 21psi. I only use 100 octane.
Old 10-09-2003, 02:07 PM   #23
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
The car sees the track a few times a month (usually 2-4 times a month). I usually drive normal but get on it when i hit the on-ramps. I do some highway pulls every now and then.
I was laying down 330awhp and 308lbs. I was going to get tuned by Shiv in hopes of higher numbers but I never got to make it that far.
Old 10-09-2003, 02:08 PM   #24
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Jorge (RiftsWRX)
www.ProjectWRX.com
Thanks Jorge.
You take some pics of the motor yet?
Old 10-09-2003, 04:29 PM   #25
IA Performance
Member#: 25194
Dark Gray
Jorge, you may have some stiff competition. If you saw what I saw inside of my block through the removed oil pan We can do a collective sticky thread on blown block pictures, hehe.
As for need4boost, you can pick up a v7 JDM sti long block from Gruppe-s for a great deal. Call in and talk to max since the website does not reflect the pricing I'm talking about
Also, if you want to do a 2.5 sti block get on the phone ASAP and start calling around. Schaumberg Subaru in IL seemed to be the best price I could find. I believe it was $1500 or so shipped and with the complete OE gasket set. This set has EVERY single gasket used on our motors. Trick setup. There was a dealer in CO that had some but he wanted 1400 just for the block Then again, I say call around because last I heard they were on back order. Schaumberg did have some enroute though.
You have a PM about that sensor
Numbers to have handy are:
Subaru of Schaumberg, ask for Craig in parts:
847-884-6000
Performance Race Engineering out of Portland.
Cometic gasket, race gasket for 2.5 sti block
503-619-0055, ask for Jason
$78.92 each
2mm thick
97 or 98 LGT w/blown motor. Good 1.8 motor. Hybrid?????? davedaman77 Subaru Conversions 4 11-03-2009 11:23 AM
97 leg GT blown motor. hmm, i see a 01 impreza motor in teh corner soobaloo Subaru Conversions 6 04-21-2009 02:06 AM
Blown Motor - Pic of a "good" Piston Thoughts kurion Built Motor Discussion 24 04-09-2008 02:10 PM
Updated BLOWN motor pics IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 09-30-2003 03:42 PM
Blown motor removal pics from yesterday IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 33 09-23-2003 05:35 PM
