Old 10-08-2003, 07:46 PM   #1
bluebaru wrx
Member#: 40828
2003 WRX
blue
Default JDM headlights
Ever since the first time i saw a WRX i absolutely loved this look...
http://www.axronline.com/store/show_...uct_id=3869969
but they are 800 bucks and ive been told that it can screw up the electronics of the car? now the price doesnt matter to me that much cause i would pay that much cause i love those so much but could i encounter electrical problems?
bluebaru wrx is offline   Reply With Quote
Old 10-08-2003, 09:35 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Lots of people have installed these with no problems. As long as the wiring is done properly you won't screw anything up with the electrical system. In fact there are some vendors selling "plug and play" harnesses for these lights so you don't have to cut any of the factory wiring to install them.
The only issue with the JDMs is a non-electrical one. They produce a RHD beam pattern which is incorrect for driving in the US, because the beam is aimed up toward the left side which means into oncoming traffic. However if you want this look with the correct beam pattern you can get a set of the EDM (European market) lights which are basically the same but with the proper LHD beam pattern. You don't specify your location but if you're in the Tri-State area there is a set currently for sale in this thread-
http://forums.nasioc.com/forums/show...hreadid=431672
Old 10-08-2003, 10:46 PM   #3
bluebaru wrx
Member#: 40828
2003 WRX
blue
ok thanx...well this guy will probably sell them before i get the money...so do you or anyone know of a website that sells EDMs? And is the lights pointing into oncoming traffic illegal or does it obstruct the drivers view? What kind of angle are they positioned at? Is it worth spending hte extra money on EDMs for just the angle correction?
Old 10-08-2003, 11:05 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
CC-B and SubyDude are two vendors that have recently had EDM lights in stock, you can try them first. If they're currently out you might have to wait a bit for the next shipment.
The patterns of the JDMs and EDMs are both E-code but opposites of each other for driving on opposite sides of the road. They look something like this-
LHD, correct for US- __/ __/
RHD, bad for US- \__ \__
As you can see the RHD pattern shines up to the left and will be a distraction for oncoming traffic. Technically none of the aftermarket or non-US OEM lights are DOT legal to put on your car, but you're certainly more likely to get noticed by the authorities and possibly stopped and ticketed if your lights are aimed into people's eyes.
I'll also add that some people have successfully taken the JDM lights apart, and modified the internal baffle plates to eliminate the rising part of the beam so they are then neither LHD or RHD. There are threads describing the procedure, if you search (look for old posts) you can find them both here and on i-club. However to do this you have to be willing to take a risk with your $800 lights.
WTT: 04-05 JDM Headlights for USDM Sti Headlights kokopuffs405 MAIC Private Classifieds 21 05-31-2009 01:33 PM
WTB: JDM headlight parts/broken headlight. blackozone Private 'Wanted' Classifieds 24 04-20-2009 04:50 PM
EDM Headlights vs. JDM Headlights masterpickle Interior & Exterior Modification 24 05-24-2007 02:53 AM
WTT: USDM Headlights for JDM Headlights civilone Vancouver Impreza Club Forum -- VIC 5 02-26-2006 07:21 AM
One JDM headlight and one EDM headlight GoRacerXGo Interior & Exterior Modification 11 09-19-2003 09:10 AM
