Old 10-08-2003, 08:13 PM   #1
Dr Ken
Member#: 5885
2000 RS (GME)
SilvAr
Angry Need replace wing's Brake LEDs
Stupid-me hooked up the LED cluster of an aftermarket wing with reversed polarity and .... all is dark... I think they are shot with nothing conducted on a voltmeter. I don't see evidence of a circuit protector, but I haven't cracked open the unit's housing. Anyone know a source of LED strips for this sort of thing? It's a strip of about 20 or so LEDs. THanks.
Dr Ken is offline   Reply With Quote
Old 10-08-2003, 09:25 PM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Are you sure you fried them? I thought LED's didn't pass current the other way (very high impedance... diodes only allow current flow one way) - so unless you hit them with a real high bias, which you really can't do with a 12V car battery, the LED's should be fine - maybe the wiring is messed up somewhere?
Old 10-09-2003, 10:27 AM   #3
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
depending how the leds were set up, it could blow them, but most likly it did not. try switching the leads. If they are still blown please PM me and i might be able to work something out (and make it bright as hell too )
Shane
PARANOID56 is online now   Reply With Quote
Old 10-09-2003, 05:00 PM   #4
Dr Ken
Member#: 5885
2000 RS (GME)
SilvAr
Thanks guys,
I'll do some more experimenting and researching.
Thanks, Shane, will do.
- Ken
Need help - Rear Brake parts replacement wrxdaddy Brakes, Steering & Suspension 0 04-26-2007 09:15 PM
How obvious is it when brakes need replacing? snorekl Brakes, Steering & Suspension 9 11-27-2006 10:08 AM
Brake Pad replacement vs brake replacement on TS stoney98 Brakes, Steering & Suspension 14 02-28-2006 03:41 PM
2004 Impreza, rear brakes need replacing first? Smart_alek Impreza Forum 9 05-23-2005 09:21 AM
Q: Any speacial tools needed for rear brake pad replacement? aov Service & Maintenance 5 09-25-2002 11:43 PM
