Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 10-08-2003, 10:19 PM   #1
bringndefinition
Member#: 25197
2003 Subaru Wrx
Default Tein Flex Locks!
Can anyone help me out in person or give me sugguestions to take these adjustable locks out. I want to replace them but for some reason I can't take them off. Any shop willing to do it for money, I dont care i just want this thing off!!!!!!!!
bringndefinition is offline   Reply With Quote
Old 10-09-2003, 04:22 PM   #2
mikkyo
Member#: 25399
2003 Impreza WRX
What are Tein Flex Locks?
Tein Flex are coilovers.
What are you calling locks?
mikkyo is offline   Reply With Quote
Old 10-09-2003, 05:38 PM   #3
bringndefinition
Member#: 25197
2003 Subaru Wrx
"locks" probably isnt the correct terminology to use. But I am talking about the pieces that adjust the springs height and keeps the seats in place.
Old 10-10-2003, 01:20 AM   #4
mikkyo
Member#: 25399
2003 Impreza WRX
AH!
There is a wrench that grips the notches in the sides of those things.
The bottom one has two, you tighten the upper one of the bottom ones to relieve the tension on the lower one, then you unscrew the lower one and then move the top one to adjust height.
I don't believe they will slide over the bottom knuckle though.
So either completely unscrew the knuckle, or you may have to remove the top nut, the mount, and the top spring seat/ring, and take the spring off from the top if you want to change it out.
Hope that helps.
Old 10-10-2003, 10:58 AM   #5
bringndefinition
Member#: 25197
2003 Subaru Wrx
yah I already tried doing that but for some reason they would not move at all. I guess Im not all that strong but the since the locks are aluminum they chip off as well.
Old 10-10-2003, 12:41 PM   #6
mikkyo
Member#: 25399
2003 Impreza WRX
Do you have them off the car?
You can put some good oil on the shaft threads and let it penetrate.
If they were on the car a long time, cleaning out the threads with a brush might be a good idea.
You may find tightening the top of the bottom two a little to release pressure on the bottom one might be needed,
Old 10-10-2003, 04:33 PM   #7
imminence
Member#: 39617
2005 M3
It may be a good idea to take it off your car and check to see if you have any pebbles or large chunks of dirt wedged in between the collar and the spring seat.
I had this problem before when I had Ground Control coilovers on my old CRX. Hope that helps. There's really no point for you to struggle with it while it's on the car, since you can't even tell what's causing it to stick.
imminence is offline   Reply With Quote
Old 10-10-2003, 06:07 PM   #8
bringndefinition
Member#: 25197
2003 Subaru Wrx
it is actually off my car and I am still having trouble with it. They wont budge at all. I think I need worlds strongest male or female to help me out lol
Old 10-10-2003, 06:25 PM   #9
imminence
Member#: 39617
2005 M3
I live in the city as well, so I can take a look at it to see if I can help you out if you like. Just reply with a phone number, and I can call you. I should have some free time tomorrow afternoon, or Sunday.
Tuan
Old 10-10-2003, 06:49 PM   #10
bringndefinition
Member#: 25197
2003 Subaru Wrx
that would be excellent ill pm you my number. I have work tomorrow at 1 but before that I'm free. Most likely I'll be at MPJ's bar-b-q
Old 10-10-2003, 06:56 PM   #11
imminence
Member#: 39617
2005 M3
That's fine. Guess it'll have to be Sunday, since I am playing golf in the morning and you are working in the afternoon. I'll call you to see when you want me to attempt to fix the problem with your coilover.
FS Tein Flex w/EDFC Tein Flex won the STU Autox Nat. Championship thomasvhs Suspension/Brakes/Handling 1 08-04-2007 11:37 PM
WTB: TEIN Flex coilover front bottom brackets and perhaps locking rings gling Private 'Wanted' Classifieds 3 08-03-2007 11:31 AM
12k Tein Flex springs (1pair) for sale from an 05 STi flex setup... crystalhelix Suspension/Brakes/Handling 2 02-08-2007 08:54 AM
Tein Flex locking collars Token-Negro Brakes, Steering & Suspension 2 10-25-2006 09:13 PM
Tein Flex + MRT rear plates = fit? | Tein Flex + GroupN + spacer = fit? ebeck Brakes, Steering & Suspension 48 07-26-2003 01:20 AM
